2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning PLEASE, PLEASE, PLEASE change your coolant expansion tank hose
      12-02-2023, 02:34 PM   #1
2breezy
Drives: M235i vert
I had seen the warnings. I thought, yeah, I should do that. And then FORGOT.
This brittle little hose is a 5 minute job to swap. By anyone, even without tools.
It decided to shit the bed at 65k miles and blew coolant everywhere. I was 45 miles from home, so had to stop several times and refill the coolant with water to make it home without a tow.
Then it took me 1/2 a day to flush the coolant, clean up the engine bay mess and 5 minutes to change the tube. Lots of good guidance here in the forums. I love the fact that you can force the water pump to cycle the coolant. My old e30 was a PIA to bleed the air when flushing.
The funny thing is, I had changed the charge pipe before it was also going to fail. Just forgot I had read about the expansion tube. Was a $20 part then. Paid $44 at the dealer now.
Do not put this off…like me.
Appreciate 4
      12-03-2023, 08:09 AM   #2
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
Yes, hopefully the new pipe is made from improved plastic. I changed mine at 80,000km, it broke when I removed it.
Remember to lubricate the o rings before installing, never go in dry
      12-03-2023, 09:38 AM   #3
zoro2001
zoro2001's Avatar
Drives: 2014 M235i
1998 SLK 230  [0.00]
2014 BMW 235i  [0.00]
Always a good reminder.
I changed mine out at 8 years of age. Will swap again in 30,000 miles just so I don't have to worry about it.
      12-05-2023, 07:47 PM   #4
lostlife656
Drives: 2015 M235i xdrive
Forgot about this as well. Buying the part now
      12-07-2023, 07:20 AM   #5
SmellyGreek
SmellyGreek's Avatar
Drives: Estoril Blue F22 M235i
I keep a spare in my trunk, for the reasonable cost its worth the aggravation noted above.
      12-07-2023, 10:15 AM   #6
celsdogg
E4 Mafia
325
Drives: E30, E36/5, E46, F22, F30
1990 BMW 325i  [0.00]
1998 BMW 318ti  [0.00]
2003 BMW 325i  [0.00]
2015 BMW 335i  [0.00]
2015 BMW M235i  [0.00]
i also keep a spare, but at home. Every time I have the F30 or F22 hood open, I push on ends to see if it breaks.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
      12-20-2023, 07:45 AM   #7
Jaynen
Drives: M235 Xdrive convertible, F350
Speaking of which I was working on the car and it broke randomly when I was not even near it lol
      12-20-2023, 01:55 PM   #8
zombem235
zombem235's Avatar
16
Drives: 2015 m235i
Happen to my ass. Cheap easy fix before it pops.
      03-15-2024, 02:49 PM   #9
XAMI
XAMI's Avatar
Drives: 135i
Listen to the man!
I found this post, ordered a cheap replacement, then decided i wanted to use a better one (the Rein one from FCP euro) so i waited 4 more days instead of just swapping the cheap one in. And guess what, today it broke! Should have just swapped it when i got the first one. 2016 m235i 52K miles
      03-16-2024, 02:54 PM   #10
Ericwj7
'14 M235I
Drives: BMW M235i
I just replaced my VC and this happened to me. I meant to buy one a year ago Lol. The car was off and I was able to plug the connection with a screw at the top coolant hose. I ordered the part and I guess I can just replace it without bleeding it?
      03-18-2024, 08:57 AM   #11
zoro2001
zoro2001's Avatar
Drives: 2014 M235i
1998 SLK 230  [0.00]
I replaced mine without bleeding the system, but I replaced mine before it broke so maybe not the same if yours broke.
      03-18-2024, 10:00 AM   #12
celsdogg
E4 Mafia
325
if thats the only part of the coolant system that is replaced, no bleeding is necessary. If you replace it while cold, you'll probably have nothing in the hose.
Not like the built in bleeding is difficult though, lol.
      03-19-2024, 02:38 PM   #13
Ericwj7
'14 M235I
Drives: BMW M235i
Yes, I replaced my coolant and did the full bleeding process (using the Electric water pump) a year ago. By built in do you mean the screw at the expansion tank? Or the whole process using the water pump. Thanks for the replies, it was not running but still had a little coolant spilling from the connection at the top of the water hose onto my garage floor. So running and warm it would be a mess I am lucky as it was very brittle on both ends so it would have broken sooner than later!
      04-15-2024, 01:58 PM   #14
RallyXer
Drives: BMW M235i Xdrive
Tried to replace mine. The connector on the coolant reservoir came off easily but the connector on the upper radiator hose refused to budge (and, yes, the metal clip was all the way out). I didn't want to force it as the upper radiator hose where the overflow hose connects looks to be the same cheap, recycled German crap plastic as the overflow hose ends and I didn't want to break it. Any thoughts on how to get this off without breaking the upper radiator hose? Or, should I bite the bullet and order an upper radiator hose as well?
Bob
      04-16-2024, 11:32 AM   #15
USVIJIM
Drives: 2016 M235i
Ordering a valve cover from FCP Euro today. Adding this to the cart to have as insurance. Mine broke when they were prepping the car for delivery 2 years ago. New hose has 20k miles on it but for $37 and lifetime replacement it's a good buy.
      04-24-2024, 07:51 AM   #16
DBinOH
Drives: 2020 X5; 2016 M235i Conv. 6MT
Anyone have the part number? Looking for a 2016 F23.
