2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Retrofitting NBT-Evo ID6 unit into a 2015 F22 stock equip. w/ ENTRYNAV+ConnectedDrive
      03-05-2023, 09:57 AM   #1
boldorider4
Drives: BMW 220i F22
Lightbulb Retrofitting NBT-Evo ID6 unit into a 2015 F22 stock equip. w/ ENTRYNAV+ConnectedDrive
Hi all,
Thanks a lot in advance for reading. I'd especially like to tap into shawnsheridan 's extensive knowledge of coding, if he was so kind to provide support.
Here's a very quarky project I'd like to embark on:
I have a 2015 F22 (pre-facelift, Typschluessel 1J11) equipped with an ENTRYNAV head unit w/ ConnectedDrive.
I'd like to retrofit an NBT Evo ID6 and flash/code all that needs to be flashed/coded. I'm not so concerned with feature unlocking through FSC codes at the moment, as I'd like to figure out the basic steps to get the HU to work at all first.
I will get a used NBT Evo ID6 unit, so VIN will not match my car at first. Display and iDrive controller will also be changed to match donor HU.
Please note that I have the Connected Drive option on my original ENTRYNAV. I'm not sure if this means that my car is equipped with an ATM module or equivalent. Not sure if this complicates the coding further if I want to retain the Connected Drive functionality.
Here's the steps I've figured out so far:
1. *** First and foremost ***
1.a Install E-Sys with compatible PSdzData
2. *** Now onto the new HU_NBTEvo, after its successful retrofit installation ***
2.a Connect to target via *donor* VIN
2.b Go to Expert mode --> Coding
2.c In the Vehicle Order section (top-left) click on Read
2.d Right click on FA --> Activate FA
2.e In the SVT-Actual (SVT-Ist, mid-right) section click on Read ECU
**** non-mandatory steps ****
2.f Save FA from 2.c (just in case something goes wrong later)
2.g Save SVT-Actual from 2.e (just in case something goes wrong later)
**** end of non-mandatory steps ****
Here the part I'm not so sure about:
3. *** Writing current VIN to donor HU ***
3.a Go to Expert mode --> FSC Extended
3.b Click on Identify
3.c Add WriteDataByIdentifierVIN to job list and write *current* VIN (the original one the car came with, not the donor one)
3.d Click on Start
3.e Go to Expert mode --> Coding
3.f FA should already be activated from 2.d
3.g SVT should already have been read in 2.e
4. *** existential questions ***
4.a from the KIS/SVT Target section (middle-right) should I click on "Detect CAF for SWE", select a CAFD file from the list and then click on "Code" to code it to the NBT_HU?
4.b Should I "calculate" the CAFD in the SVT-Target section instead?
5. *** FSC code installation ***
But to my best understanding I may have to worry about this at the in order to get the features I want (Maps, Fullscreen Carplay, ConnectedDrive, etc.).
But I'm trying to get the donor HU to work first even without such features. One step at a time.
These are many questions, I know, but it's so difficult to get this information as a newbie by scouting the web.
Any help is soooo appreciated!!!
      03-05-2023, 10:44 AM   #2
TheNine90
Drives: bmw
use Detect CAF for SWE to code the HU, its faster than calculating SVT target.
The steps are okay.
In step 3b write 0x63 to choose NBT.
3g code the HU.
After coding the NBT would work but the features would not be available. If you want you can get the FSC to activate and patch the NBT. I can get the FSC for you.
If you need any assistance PM me.
      03-05-2023, 02:09 PM   #3
boldorider4
The steps are okay.
3g code the HU.
Thank you so much TheNine90!
So I'll post here the steps edited to your remarks:
3.b.1 write 0x63 to choose NBT
3.b.2 Click on Identify
3.d Click on Start
3.h Click on "Detect CAF for SWE", select a CAFD file from the list and then click on "Code" to code it to the NBT_HU
Does it look good now?
Because I'm a noob, I don't have PM capability yet. But hopefully soon I will!
      03-05-2023, 02:38 PM   #4
boldorider4
The steps are okay.
3g code the HU.
By the way, few more questions:
1. Because I haven't had the guts yet to tear my car apart, I don't know if I have a proper ATM module. Given that my ENTRYNAV HU has ConnectedDrive capabilities, I would assume I have an ATM module or equivalent. Do you know if this complicates the coding of the donor NBT Evo ID6 unit?
2. Some (or perhaps all) NBT Evo ID6 HU I find for sale online come with a flat connector below the quad lock. I'm guessing the flat connector is to wire the ATM module, but then it's unclear to me whether connecting my (supposedly existing) ATM would work when paired to a non-stock NBT Evo ID unit and if I would need a retrofit quad lock harness with an emulator module.
Regardless if a retrofit harness with an emulator module is required, will I lose ConnectedDrive capabilities?
3. Some NBT Evo ID6 HU I find for sale online also have a blue connector for a GPS antenna, some do not. If I buy one with a blue connector and connect an aftermarket GPS antenna, would I be able to get a GPS signal even if an ATM module is not working properly because not matching the HU?
      03-05-2023, 02:44 PM   #5
TheNine90
Drives: bmw
It looks good now.
Pm sent
      03-05-2023, 03:25 PM   #6
boldorider4
Hi TheNine90,
I don't know if you can receive my reply, since I'm still under the 10 post mark and I registered just today.
      03-26-2023, 01:53 AM   #7
b0ssk1
Drives: BMW F22 Pre LCI
Perfekt job. Do you already done with everything and setup is fully working?
      03-27-2023, 03:18 PM   #8
boldorider4
Not yet but very soon
      05-10-2023, 04:35 PM   #9
boldorider4
Hi guys,
just letting you know this retrofit was a complete success!
I will post a step-by-step tutorial also highlighting all the impediments I encountered en route (there were A LOT).
If you guys need my help in getting unblocked, do not hesitate to ask!
      05-15-2023, 01:52 PM   #10
Mr. F22
Drives: m235i
Originally Posted by boldorider4 View Post
Hi guys,
Very cool. Did you end up doing this with an emulator or without? I have a similar retrofit using a emulator (with a matching donor ATM and ID6) but would be curious if there is another way!
      05-22-2023, 04:46 AM   #11
boldorider4
Hey there, sorry for the late reply!
So, I decided that buying an ATM and repining the TCB connector to make it compatible with the ATM, plus rewiring the emergency microphone, was going to be too much hassle, so I only retrofitted the NBTevo HU. Since I don't have to have a VIN-match between the ATM and the HU (because ATM is entirely missing!) I VO-coded the HU with my VIN and therefore did not need the emulator.
Mr. F2228.00
      03-05-2024, 08:14 PM   #12
Ordoni
Drives: BMW X3 2016
Thank you for the write up. I am about to replace my NBT ID4 on my 2016 X3 to NBT_EVO HW 4.1 with a blue gps cable.
Ideally, i would like to program the unit on the bench first but I do not think I have the proper hardware for connection.
I just want to confirm, after I retrofit the hardware (New NBT EVO HU)
all I need is
1. E-sys
2. ENET Cable
3. Instructions to code the vin to the new NBT EVO HU
Am I missing anything? Thanks again!
