2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions F22 coding cheat sheet
      06-30-2014, 11:11 AM   #67
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Start directly into sport plus?
No
Make the crash warning assistant thing not be on on startup?
Haven't looked into it cause i don't have Driving assist plus
Default to auto start stop being off?
Yes. But you should have default to last setting already... which is basically the same... if you leave it of it says off.... if you leave it on it stays on
Originally Posted by abirmaher View Post
Anyone know if its possible to do the following?
No
Yes. But you should have default to last setting also... which is basically the same... if you leave it of it says off.... if you leave it on it stays on
Thanks!
      06-30-2014, 11:27 AM   #68
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
No
No
Thanks!
Thanks! Much appreciated. I'll be looking into this for sure.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      06-30-2014, 03:12 PM   #69
flyga3
Geboren zu Fahren!
flyga3's Avatar
Drives: F25 X3
Originally Posted by hoyasaxa View Post
I am also pretty sure that weather radio band doesn't work on these cars. I know the excel says confirmed working, but has anyone actually confirmed working in the US?
Has anyone verified if weather band works/not-works with a US build? Curious.
Have it on my X3 and use it often.
2011 F25 X3 2.8 (in service)
2009 E90 328i (retired)
2007 E92 335i (retired)
2005 R53 MINI Cooper S (retired)
2002 E53 X5 3.0 (retired), 1999 E46 328i (retired)
      06-30-2014, 03:17 PM   #70
pikcachu
pikcachu's Avatar
1403
Can you show me what it's supposed to do?... i have it active on my car but not sure what I should look for...
I'll removed it from the sheet if it doesn't work... i put it cause i saw it was comfirmed to work on other models
edit: actually i forgot to code it.... i'll do it tonight and let you guys now... i think should show "weather" under AM FM etc
      06-30-2014, 03:48 PM   #71
flyga3
Geboren zu Fahren!
flyga3's Avatar
Drives: F25 X3
Correct, it should show up as another selection under FM, AM, SAT, Weatherband, etc. Then should have multiple channels 1-10.
I'll post a pic of my X3 screen later tonight, if needed.
This would be interesting, as then the FM receiver has the capability to receive 162.xxx MHz, which previous generation BMWs have had on most their models. Only the recent 1 & 3 models did they start dropping it.
      06-30-2014, 05:23 PM   #72
flyga3
Geboren zu Fahren!
flyga3's Avatar
Drives: F25 X3
Here are a few pics from my X3 in the iDrive menu:
      06-30-2014, 09:09 PM   #73
pikcachu
pikcachu's Avatar
1403
No, i don't have before video. Was hoping someone had noticed this behavior. It's the most significant thing I noticed after removing the variable decoding but I don't know if it was part of that or if it's default behavior.
Tomorrow I'll take video.
I think this is what you mean...
You can see how the low beam goes back to the left when high beam is off and goes back to the middle when high beam turns on
      06-30-2014, 09:25 PM   #74
pikcachu
pikcachu's Avatar
1403
Enabled weather band but nothing shows up on my screen so updated the sheet
      07-01-2014, 11:22 AM   #75
flyga3
Geboren zu Fahren!
flyga3's Avatar
Drives: F25 X3
Bummer.
      07-05-2014, 09:57 PM   #76
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Originally Posted by furii
would love to see the amber lights disable added to the list
Just the front headlights??
Any pics?
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      07-06-2014, 12:44 AM   #77
pikcachu
pikcachu's Avatar
1403
What other amber lights are there ?
      07-06-2014, 07:20 AM   #78
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
You're right hahaha...had a long day and didnt think about that
2006 325xi (Sold)
      07-06-2014, 03:18 PM   #79
lichenlt
I actually like those amber lights, lol
      07-06-2014, 10:01 PM   #80
pikcachu
pikcachu's Avatar
1403
me too...
      07-12-2014, 04:33 PM   #81
furii
Drives: 2014 m235i
did my coding the other day but hadn't had a chance to come back and post. i can confirm that MAPPING_SIDEMARKER_L_OUTPUT and MAPPING_SIDEMARKER_R_OUTPUT both are working if you want to update the spreadsheet.
one issue that i am having is with CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK which is supposed to unlock the doors after turning the engine off. for some reason it is only unlocking my driver side door and not the passenger side. can anyone confirm whether it is supposed to unlock both doors or not? seems kind of pointless if it's only going to unlock the driver side.
      07-12-2014, 07:34 PM   #82
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Check your vehicle settings that you have both doors selected in the iDrive.
      07-12-2014, 08:01 PM   #83
pikcachu
pikcachu's Avatar
1403
ya check what he suggested.
i will update the sheet for the stuff you comfirmed
      07-13-2014, 09:20 PM   #84
Oyinko
I have done coding many times and successfully coded many features.
However, today, I wanted to code something else but couldn't manage to do it.
The mapping of ECU doesn't match anymore with what I have on my excel file.
For example look what I get for the FEM Body. Any idea how to fix this?
      07-13-2014, 10:59 PM   #85
pikcachu
pikcachu's Avatar
1403
What do you mean? what's wrong with what you posted?
      07-13-2014, 11:08 PM   #86
pikcachu
pikcachu's Avatar
1403
sheet updated
      07-14-2014, 11:23 AM   #87
Oyinko
My FEM Body doesn't match the spreadsheet.
For example, I used to activate the feature "close windows with FOB". In the spreadsheet, I must find the line 3053 KOMFORTSCHLIESSUNG_FB
But if you look at my sprint screen, the line 3053 doesn't match anymore.
      07-14-2014, 11:50 AM   #88
furii
Drives: 2014 m235i
that fixed it, thanks.
another note, as has been mentioned in regards to the F30 BC_V_KORREKTUR does not seem to be working. the speedometer still reports ~3 mph faster than what the waze app reports my speed is. while not a standalone gps unit it does match what we get in our other car so i assume it is accurate.
