2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions ENAV EVO to NBT Evo - 6 vs 20pin OABR
      09-26-2023, 05:33 PM   #1
Jimmythetee
Drives: M240i 2019
Hello all, I’ve installed an NBT Evo HU into my car (2019 m240i) today with screen, display cable etc..
Everything is working apart from the USB (differently keyed plug + pinout is rotated 180), I’ve bought an adapter to solve this.
The other issue is no connected drive or nav, now as I have the ENAVEVO I have an oabr plug, but it’s a mini 6 pin instead of the 20 to go into the new HU.
2 questions from this.
1. Do I still need to move the 4 cores from the main plug or is this not necessary for an enavevo to NBT evo or is this step meant for just normal nbt/enav HUs?
2. Do I just swap/move the 2 cores connected to the 6 pin to the 20 pin plug?
I think everything should work then, the new HU is FSCd to the vehicle and coded with my cars VIN also.
Thanks!
      02-19-2024, 03:58 AM   #2
hmaarouf
Drives: BMW X2 F39
Hello, I have the same issue with my x2 F39... from ENAVEVO to NBT EVO...
USB not working, and ATM (6 pin OABR) needs to be connected to NBT EVO (20 pins OABR)...
Please let me know if you found a resolution? Thank you.
