05-18-2014, 11:45 PM | #1 |
Rep 44
M235i Cooling Problem?!
Hello guys,
i have a Problem... Yesterday on a tour, I've found the following problem: i drive a long time normaly, than i go to the manuel mode and i shift late but never over 5000 rpm (i have the 8AT Sport). suddenly, came a loud whir and the steering wheel has slight vibrations emitted I think this is the cooler fan, from the outside is the be heard very clearly, but the big Problem is, the gas assumption was much worse, one might almost say the transmission went crazy and it turned much later. after I got the engine off and about 20 minutes've waited all went back to normal and the problem came all day on no longer. Have you any Idea, what could be that? and there was no error message in the display... |
05-19-2014, 03:39 AM | #2 |
1867
Rep 13,043
Drives: BMW M340I G20
The cooling fan on my M235i is very noisy. It also doesn't feel that well balanced and can as you say be felt through the steering wheel. I've noticed the fan cut in on the odd occasion, just as I'm about to come to a stop. It surprised me as I hadn't been driving hard and wasn't in traffic.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
05-19-2014, 10:33 AM | #3 |
Rep 91
I haven't noticed the fan much, but these thing do run hot. Seems the thermostat is ~220 or maybe higher. I am still breaking it in, but when I monitor the temp once fully warmed up, it is ~222-228F. This is with easy driving.
10-21-2014, 08:15 AM | #4 | |
Rep 2
10-21-2014, 08:24 AM | #5 |
Rep 862
Drives: '19 M2 '21 X5
Is it possible that this is a Euro problem? I keep hearing random posts of extra cooling on the NA models (ironically also on my Canadian model lol)
10-21-2014, 12:40 PM | #6 |
Rep 875
I have no issues with my systems/car in my area. The car is very strong in all conditions with no negative reactions from the car requiring a period of cooling. I am south of Stuttgart and use A-8/A-81/A-5 and in the Alb. City driving or open roads and the M235i responds perfectly.
10-21-2014, 01:30 PM | #7 |
Rep 5,577
With engine cool, I would remove pressure cap on cooling system and then run the engine for between 5-10 minutes - stationary - no driving - but it helps to have a breeze or air flow around the radiator grill area.
Maybe an air-pocket or bad cap |
11-17-2014, 02:48 PM | #10 | |
Rep 1
I bought my car in Belgium (Europe). |
03-03-2015, 06:06 AM | #11 |
Rep 398
Just experienced this. Normal driving and it has happened twice (I have had the car for 4 days!) Doesn't seem to be a loss of power but the fan is very loud and the vibration can be felt through the steering wheel.
What have people done? I am bringing it in to dealer for a check. |
03-03-2015, 06:07 AM | #12 |
Rep 398
03-03-2015, 07:10 AM | #13 |
Rep 1,215
You guys need to get the 850w cooling fan.
Never got this problem anymore. Everything was done without costs at my local dealer.
MANHART MH2 400 Partout FS: MANHART MHtronik Tuning Box http://www.2addicts.com/forums/showt...5#post18819345 |
03-03-2015, 07:16 AM | #14 | |
Rep 199
Did they retrofit the high power relay required for 850w fan on passenger side wheel arch near coolant expansion tank on your car? BMW changed again the reference of 600w cooling fan in september 2014 so it should be fixed with new reference and car coding. |
03-03-2015, 07:54 AM | #15 | |
Rep 1,215
I was one of the first with this problem according to bmw and as I was having the problem, they dind`t have a solution. Then I got the 850w fan. Maybe they found out that the 600w is a cheaper solution, so they are using this one now. My car is from 04/2014
03-03-2015, 08:10 AM | #17 |
Rep 1,215
There was another relay used yes.
