2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Valentine 1 install.
      10-22-2014, 09:19 AM   #1
rosenbergendo
Drives: 2016 Porsche GT3RS, F80 M3,997
Anyone installed a V-1 into the car? Also where did you tap into at the fuse box?
Thanks
Dr. R
      10-22-2014, 09:54 AM   #2
msingh637
Drives: 2019 JCW / 2018 M3
Thanks
Dr. R
I got mine installed and the guy hardwired into the rear view mirror. The fuse box is under the hood, it took him half an hour to do the job.
      10-22-2014, 12:29 PM   #3
BEM-S4
BEM-S4's Avatar
Mirror tap is best by far search for the thread but I did mine in under 5 mins. You don't need to go anywhere near the fuse box.
      10-22-2014, 12:54 PM   #4
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
just get the mirror tap with fuse included... i got one from invisicord
      10-22-2014, 01:00 PM   #5
rosenbergendo
Then u can't use the Savvy.
      10-22-2014, 02:42 PM   #6
rickinaz
Drives: BMW 435i
Instead of SAVVY, I use the app named "stealth assist". $10, and it communicates using Bluetooth. But...you need the Valentine Bluetooth accessory ($50) and you need to activate the stealth assist manually every time you enter the car. That said, stealth assist, has more features than SAVVY.
      10-22-2014, 04:49 PM   #7
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
Does the 2 have the cigarette lighter port underneath the passenger foot well like the 3 series? I wired my V1 there - it gets tapped out by passengers occasionally but its easy enough to push in from the driver seat and didn't require any hard wiring (which is useful for a lease).
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      11-12-2014, 12:37 AM   #8
Two11
Drives: '15 M235xi '16 M4
Location: New York, Boston, Philly, Edgewater NJ, the DMV, The Triangle NC, Charlotte, Atlanta, Miami
I used SAVVY
SAAVY install
      11-12-2014, 12:39 AM   #9
Two11
5 minute install.
Stealth display next to right leg. V1 mounted high against roof liner as not to be so conspicuous in the middle of windshield or mounted under the mirror.
Sun Visor can be pulled down to hide V1.
      07-22-2015, 02:10 PM   #10
PDACPA
Drives: F33 M Sport 435i
Nice intsall Two11, but why not program those garage door openers to the Mirror buttons?
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk
      07-22-2015, 05:47 PM   #11
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I need this in my life. I'm pretty sure it will pay for itself in the first month I'm back from Europe. Ha ha. Nice install.
78' Honda CB400A project
      08-08-2015, 12:43 PM   #12
Solarphil
Drives: Nickole - MG & CR M235i
If you use Savvy, it provides the power. No need to tap into mirror or go to the fusebox.
      08-09-2015, 11:29 AM   #13
chemh0ser
Drives: M235ix Mineral Grey
I tried using the mirror tap but the pins weren't holding in the molded plug. Went to the savvy. It worked out better because I used a splitter in the ACC port to connect my concealed display and mute button. I just hid the connections under the panel under the steering column by the knee airbag
2015 ///M235iX | Mineral Grey | Dakota Black | Premium | Tech | Cold | Driver Ast | HK Sound | Black Kidney Grilles | M-Performance Exhaust | Front Splitter | Carbon Fiber Mirror Caps, Rear Spoiler and Exhaust Finishers
      08-10-2015, 02:01 PM   #14
isthar
Drives: M235i xDrive
Mine was done myself, 10-15 minutes tops - mirror mount.
Now I'm going to install the concealed/stealth display next, so I have to go back up there and shove more wires around... I used to like putting it in the far corner of the dash, so you see it while driving. Those putting concealed displays into the footwell area, you guys have to take eyes off road to see it...
//M235ix Alpine White
      08-19-2015, 10:15 PM   #15
quinntheskimo
I agree the mirror tap makes it look sharp, but a big thing for me is having a mute button close to the shift knob so im not constant reaching up to mute the RD. But I also dont want the cord constantly in my way. What do you guys suggest?
      08-20-2015, 09:01 AM   #16
Zooks527
  • V1 power adapter in the trunk, fuse tapped off the the back side of the lighter socket fuse.
  • 4-wire line from the unit socket in the adapter to the v1, run under the right side floor edge, up the door seal, and across the front windshield edge to the V1, mounted high and to the right of the rearview mirror. There's enough room to run it completely hidden.
  • 4-wire line from the acc socket in the adapter to the remote display, run under the left side floor edge, up the dash edge to wherever you want to place the display. There's enough room to run it completely hidden.
Under 30 minutes to set mine up this way. I subsequently removed the remote display, as I wasn't happy with the look of the remote display anywhere where I didn't have to shift my head around to see it.
