2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M235i Dyno'd with BMS N55 Stage 1
      04-08-2014, 09:18 PM   #1
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Finally was able to get the car on the dyno this morning. The baseline was performed with the aFe Intake installed as I didn't want to waste time/money putting the stock intake on and off. The car delivered good numbers with just the intake alone. Looks like the torque numbers were higher than expected. My tuner said the 295.57 HP and 330.75 Torque is the highest stock numbers he has seen on his dyno for any stock N55 motor. That tells me we are getting a bit more power than BMW is letting on
With the N55 Stage 1 installed we see gains in both HP and Torque, but to be honest not what I was expecting from the BMS suggested gains posted on the website. The best was 323.15 HP and 365.67 Torque. A peak gain of +27.58 HP and +34.92 Torque. That said, for less than $400 and two easy connections to insert it still is a good deal for this car. I hope the JB4 Stage 2 running Map 1 puts out better number with the added controls.
      04-08-2014, 09:54 PM   #2
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
What does the butt dyno say in terms of response?
      04-08-2014, 09:54 PM   #3
JustinCredibleM
Drives: '15 GT-R, '02 996TT
Great numbers and I hope you are happy with the car! It seems very consistent and inline with what BMS states on their site without exhaust. Hopefully we can compare when I get mine strapped on the rollers.
      04-08-2014, 10:27 PM   #4
h0pe
those are very impressive numbers, and thats a baseline with an intake.
      04-08-2014, 11:25 PM   #5
kerm1t
Drives: 17 M3 ZCP Stage 2
nice numbers, but definitely hoped for a bit more. Maybe its because its still stage 1.
you seem like you had a lil better baseline dyno. i know all cars will be different, but i hope mines near yours :P
      04-09-2014, 12:26 AM   #6
JustinCredibleM
Don't forget all dynos are different too .
      04-09-2014, 12:48 AM   #7
alexc93
Drives: na
They have stage 2 available already I believe...
      04-09-2014, 01:22 AM   #8
JustinCredibleM
For EWG cars?
      04-09-2014, 01:57 AM   #9
kerm1t
yea i have jb4 stg2 as well. waiting for my damn car to get here
      04-09-2014, 02:43 AM   #10
JustinCredibleM
I have the Stage 2 as well, but we can't use Map 2 until we get the EWG harness though.
      04-09-2014, 06:54 AM   #11
Delnari
Delnari's Avatar
Yes, really can't compare my baseline to yours, apples and oranges. But they are in the same ballpark. Both higher stock numbers than expected.
      04-09-2014, 10:51 AM   #12
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Those are great gains for the Stage1! And down the road when you're ready for more power you can upgrade it to the JB4 Stage2.
Mike
      04-15-2014, 10:04 AM   #13
Da_Meister_22
Da_Meister_22's Avatar
208
Drives: F10 M5 & F85 X5M
Good numbers...really looking into getting an M235i .....
      04-17-2014, 03:02 PM   #14
rickinaz
Drives: BMW 435i
But...doesn't the M235i come with MPPK, which is a quasi-JB4 Map1 anyway? I'm surprised that there is ANY gain at all.
      04-17-2014, 03:47 PM   #15
bimmer Don
Drives: 2012 135i m sport
If it's a 15% drivetrain loss it looks like m235i makes 340 hp and 380 tq so is say it safe to say it's under claimed like all n54 and n55 are
      04-17-2014, 04:09 PM   #16
rwalker
Drives: the wheels off
MPPK gets you about half of what JB4 map1 gets you over non-MPPK. JB4 map1 gets you the other half.
      07-09-2014, 11:54 PM   #17
HX_Guy
Drives: 2014 BMW M235i
Is the JB4 completely plug and play? No cutting or splicing? Is there any trace at all left behind when you remove it? Can dealerships tell in anyway that you had it...like maps history or something?
I know with VW/Audi chips, the dealerships could see it and could tag your car and not honor the warranty in certain situations.
      07-10-2014, 02:09 AM   #18
FunRevn
Drives: 2020 M5
+1
2011 335 E90 MSport PPK - retired
2008 M3 - retired
2007 335 E92 - Buy back
2007 X3 MSport - retired
1995 M3 - retired
      07-10-2014, 09:50 PM   #19
TunedM2C
TunedM2C's Avatar
No_Country
829
Drives: 2016 LBB M2
Plug and play and as long as you view and/or delete codes before taking it into the dealership, they won't know it was modded. Just be sure you remove the JB4 prior to any service.
      07-11-2014, 07:32 PM   #20
Delnari
Delnari's Avatar
My N55 Stage 1 for the N55 engine has a total of 2 connections. Both of which are factory style harness connectors that plug inline with the vehicle harnesses. There is no cutting or splicing of wires! No codes are present in the OBDII connection that I can read with my scanner. Return my vehicle back to stock is a simple matter of unplugging the 2 connections and plugging the factory connectors. It can swap in/out on the M235i is less than 5 minutes. This the reason I went with the Stage 1 setup instead of Stage 2 or more at this time.
For me this is a stop gap measure until the Dinan software is made available. I will sell my N55 Stage 1 for 1/2 the original cost here or EBAY once I get the new software for Dinan installed. The N55 Stage 1 is very small money for nice gains and you can add the 2nd module from Burger for under $200 to go additional stages.
      07-11-2014, 07:36 PM   #21
alz0rz
What goes here?
alz0rz's Avatar
450
Drives: 2019 G30 M550i
So the JB4 Stage 2 requires additional connections?
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      07-11-2014, 09:41 PM   #22
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
I want to see a dyno with the JB4 and CAI.
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
