08-20-2014, 08:33 AM | #1 |
Rep 2,363
Jb4 Issue, Car Won't Start
Hi Everyone,
Hopefully someone can help me out on this. Ive been running a JB4 with EWG harness and no flex fuel wires for about 2 months with no issues. I just found out that if your running the EWG you should also have the flex fuel wires going. So last night I had them installed and the car ran grey last night even did some logs and all was fine. This morning I go to start the car and it cranks but won't turn over. Plug in the computer and it can't find the JB4. Anyone know what this could be? Im kind of freaking out here...
Follow my builds:
08-20-2014, 08:49 AM | #2 |
***** noob
1369
Rep 10,479
You have spark but no start....sounds like no fuel delivery
2006 325xi (Sold)
08-20-2014, 09:16 AM | #3 |
Rep 1,040
Re - check all your wired connections on the JB4. When splicing in wires they can lose contact when heat is added and removed if connections are not tight enough.
08-20-2014, 10:13 AM | #4 | |
Rep 115,980
Mike |
08-20-2014, 12:38 PM | #5 |
Rep 2,363
Emailed Jon earlier. I worked with a friend this morning seemed like the reason it wouldn't start was an issue with the can wires which are now fixed but I'm not getting no boost. Ill continue to check later on tonight.
Follow my builds:
08-20-2014, 12:40 PM | #6 |
Rep 190,777
Double check installation.
If you are still getting no boost,do some datalogs.
08-20-2014, 01:26 PM | #7 |
Rep 2,363
Whats weird is after the instal last night it started fine and drove well. Issue is that I'm not seeing any communication to the computer from the JB4 for some reason and the car is giving the engine reduced power warning which I think is related to a bad reading form the JB... not sure.
Follow my builds:
08-20-2014, 02:13 PM | #8 | |
Rep 536
where do you have the box installed ? did it rain last night !! did the JB4 get wet by any chance ?
08-20-2014, 03:19 PM | #10 | |
Rep 115,980
In my experience asking for technical support on a forum like this is just going to lead you on many wild goose chases, waste your time, and frustrate you. Don't waste your time. Let the professionals help you sort it out. Mike |
08-20-2014, 09:06 PM | #11 | ||
Rep 2,363
Follow my builds:
