2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning 2nd gear grind in manual transmission
      07-10-2014, 09:16 AM   #1
Wheelwright
Wheelwright's Avatar
Drives: M235i (6MT fakerich edition)
When I accelerate briskly and shift into 2nd gear at around 5000-6000 rpm it sometimes grinds. It doesn't pop out of gear, it still engages though. I don't think this is normal. Does anybody else have this problem ?
      07-10-2014, 09:43 AM   #2
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
Normal for 1st-2nd gear shift at higher RPMs. You will need to drop the RPMs a little more (more clutch in time) to get a smooth shift. High RPM shifts in lower gears can hurt the transmission in the long run. Try using 2nd-3rd shifts for higher RPM shifts for smoother action.
      07-10-2014, 10:27 AM   #3
Wheelwright
That's extremely disappointing that I have to granny-shift a car which allegedly has a manual transmission "borrowed from M3/M4" (quote from official BMW propaganda brochure).
      07-10-2014, 10:44 AM   #4
Ritz42
Drives: F22 & R56
Does make a weird power drillish sound and still go into gear? Or does it just grind and not go in? If its the first, you've got a bad syncro/transmission.
      07-10-2014, 10:58 AM   #5
Wheelwright
It is the first (the power drilish sound and extra vibration I feel in my wrist as well) but it still goes into gear.
      07-10-2014, 11:05 AM   #6
Ritz42
Drives: F22 & R56
Yeah, that may end up being a bad transmission. It happened to my families 1m, and several other 1m owners. With our 1m at first it was just high rpm shifts from first to second, eventually it just became any quick shift from first to second.
I hope its not the same situation for you.
      07-10-2014, 11:19 AM   #7
Wheelwright
Thanks for the reply. I will test it today, depress clutch fully, wait one full second and then quickly shift so at least I know it is not clutch delay valve.
      07-10-2014, 11:20 AM   #8
Cybertronic
Drives: G30 M550i, E30 M3
You can absolutely shift 1-2 at high RPM with no issues. You are either not pushing the clutch all the way in (or pulling down before its completely disengaged) or you have a bad synchro.
      07-10-2014, 11:32 AM   #9
overcoil
Drives: M235i 6spd
Some things to consider.
The synchromesh rings between first and second can be designed for more stresses / the first to second shift traditionally being the most abused or taking the most wear.
You can actually shift too quickly, if you attempt to shift as fast as possible you can overwhelm the synchromesh and the second gear teeth.
So there is a optimal speed of which to shift, don't slam but feel the meshing as you traverse the gearbox from first to second. It can still be quick but not nanosecond fast.
Finally, try not grabbing the shifter with the palm of your hand vertical up against the right side of the shifter (left hand side configuration) but clasp the top of the shifter with the underside of your fingers and pull back with your distal phalanges and when pushing forward use the more carpal portion of you palm.
But it could be a linkage issue.
      07-10-2014, 12:12 PM   #10
plien69
Drives: 2014 M235i
I need a degree in anatomy to understand this post.
      07-10-2014, 12:25 PM   #11
kerm1t
Drives: 17 M3 ZCP Stage 2
mine doesn't grind, but the noise in 1-2nd gear is pretty notchy and clunky. does anyone have this issue? doesn't seem like the smoothest of transmissions
      07-10-2014, 12:30 PM   #12
overcoil
Drives: M235i 6spd
What I should have said, it's better to pull and push the shifter with your fingers and palm rather then grasp the shifter like a ski-pole.
      07-14-2014, 03:45 PM   #13
Wheelwright
Thanks for all the advise vis-a-vis driving smoothly. By the way I think it may be clutch problem, not synchros, because it grinds when I put it into second with the clutch still pressed. The synchros are not involved yet because they only start working later in the process (aka. after the clutch is released).
      07-14-2014, 03:56 PM   #14
overcoil
Drives: M235i 6spd
I do believe the syncromesh discs are used while clutch is depressed to floor and gear lever is sliding through from one gear to another - but I'm not questioning your diagnosis.
Actually a clutch repair is quicker and easier then a gearbox exchange.
BMW dealer tech can probably find the cause in five-minutes.
Very interested in how things develop, keep us posted.
      07-14-2014, 08:23 PM   #15
Wheelwright
I am going to see the dealer tomorrow. I hope this is an isolated case and the gearbox can handle spirited driving for more than 3-months 4000km (that's how long I owned the car).
      07-15-2014, 09:10 AM   #16
Wheelwright
The foreman and I drove the car today and while he couldn't replicate the problem I could. I scheduled the next appointment on July 24th. Hopefully they will fix it then.
      07-15-2014, 11:48 AM   #17
ciwhamc
Drives: M235i Alpine White
2014 BMW M235i  [0.00]
I shift mine very fast from 1-2 and have never heard any bad noises. You can have the foreman go with you while you drive too. If you can replicate the situation.
      08-05-2014, 02:59 PM   #18
Wheelwright
I just got a confirmation today the new transmission (pending BMW confirmation) will be arriving from Germany. I hope it was just a bad luck because you don't hear often about blown BMW manual transmissions.
      08-05-2014, 03:02 PM   #19
ciwhamc
Nice. Hopefully all will be resolved.
      09-12-2014, 04:00 PM   #20
Wheelwright
I had a new transmission put in yesterday. Just in time because the old one was grinding more and more and I worried it could disintegrate at any time. At least something good came out of it because I learned to start in 2nd gear smoothly so I could bypass the dreaded 1-2 gear grind (makes me cringe just thinking about it now).
      09-12-2014, 04:18 PM   #21
overcoil
Drives: M235i 6spd
Do you have to break-in the new unit?
Clutch wasn't touched ?
Enjoy the new trans. Really curious what went wrong on original transmission.
      09-12-2014, 06:12 PM   #22
Wheelwright
Thanks, I will try. Clutch wasn't touched. I suppose you need to break the new gearbox in so I will ease off on those torque-intensive 1-2 and 2-1 shifts. I would also like to know what went wrong but I don't think BMW will admit they produced a shitty gearbox.
