2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Rattle Sound Under Acceleration Fix
      03-12-2021, 03:34 PM   #1
drodrig2
Drives: m235i
I finally found a solution to my 2015 M235i rattling sound during hard accelerations that I have had for years. The rattle sound seems to be coming from underneath the center console and/or underneath the rear seats. The rattle is coming from the hand break cables that are underneath the car. The retainer clip (34406854898) breaks and then the cables bang against the underside of the car. See this video for the sound and how to remove it. (see link
The removal is very similar to the video however the install is different. I did not take off my muffler, there is enough space once everything is loosened. Also, I guess our 2-Series cars have less distance between the drive shaft and the bracket so there is no way to install the bracket with the drive shaft installed. So what I did was cut a channel on the bracket that would allow it to slide in without removing the drive shaft. I used my dremel tool to complete cut through the plastic, rubber, and metal of the bracket, as shown in red on the picture. I hope this helps others.
https://www.2addicts.com/forums/atta...1&d=1616272902
Appreciate 5
dradernh4413.00
MLJR235116.50
Devils41262.50
overcoil3075.50
a_dev1.50
      03-30-2021, 08:26 PM   #2
drodrig2
Drives: m235i
I found a metal bracket called AGA Park Cable Clip Repair Kit that is so much easier to install. see link https://agatools.com/products/brake-...b0ae1e8f&_ss=r?
      03-30-2021, 09:08 PM   #3
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
Originally Posted by drodrig2 View Post
I found a metal bracket called AGA Park Cable Clip Repair Kit that is so much easier to install. see link https://agatools.com/collections/bmw...37934145536191
Is this the kit: https://agatools.com/products/brake-...b0ae1e8f&_ss=r?
      03-31-2021, 03:37 PM   #4
drodrig2
Drives: m235i
yes, you are correct.
      03-31-2021, 04:41 PM   #5
dradernh
dradernh's Avatar
4413
Drives: 2017 M240i
Neat – thanks for posting this!
      02-26-2024, 09:26 AM   #6
overcoil
Drives: M235i 6spd
Appreciate this video. Well done.
Scott
Baltimore
