M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > DSC settings on the M2: what the Manual, Press Kit and Technical Training say
      12-19-2015, 02:43 PM   #1
Artemis
Moderator
Artemis's Avatar
29681
Drives: BMW M2 Competition
1. Transcript of the "Driving stability control system" (DSC) and "Driving Dynamics Control" sections of the M2 instructions manual (DSC OFF, TRACTION, SPORT+, SPORT, COMFORT, etc.):
EDIT: the original section #1 was replaced by pages 114 to 118 of the M2 owner's manual 2016 (US version) (which was not yet electronically made available at the time of creating this thread).
2. Excerpts from the M2 Press Kit (that you can find here | M2 manuals sticky: here) about M Servotronic steering (EPS), Active M Differential and MDM:
Two settings for the Electric Power Steering.
The standard-fitted Electric Power Steering of the new BMW M2 also helps to imbue it with the unique BMW M driving feeling. The development of the system prioritised hallmark M attributes, such as direct steering feel, precise feedback on the driving situation and driving at the limit. The integrated Servotronic function with M-specific characteristics controls the level of steering assistance electronically according to the car’s speed. Added to which, the steering of the new BMW M2 also offers two settings – COMFORT and SPORT/SPORT+ – which can be selected by pressing the Driving Experience Control switch. This allows drivers to adjust the steering’s power assistance at any time to the task at hand or to their personal preferences. SPORT mode can be configured via iDrive. The engine and steering settings can be stored in SPORT mode either as a combination or individually.
Unlike conventional hydraulic steering systems, the new BMW M2’s Electric Power Steering does not require any energy when the car is being driven in a straight line or standing still with the engine running. This enables a reduction in fuel consumption of 0.3 l/100 km.
Permanent, fully variable differential control.
The Active M Differential in the new BMW M2 optimises traction and maximises directional stability. This electronically controlled multi-plate limited-slip differential takes traction and directional stability to a new level.
The multi-plate limited-slip differential is proactively controlled with extremely high precision and speed. The locking effect can be varied between 0 and 100 per cent according to the driving situation. Sensors including those of the DSC (Dynamic Stability Control) system determine the car’s steering angle, accelerator position, brake pressure, engine torque, wheel speed and yaw rate. The control unit uses this analysis of the driving situation to detect the threat of traction loss on one side of the car and calculates the required locking effect, which is engaged by an electric motor. Full locking power of 2,500 Nm (1,843 lb-ft) is available within 150 ms. This allows the system to prevent a wheel from spinning in extreme conditions on slippery road surfaces or when the two rear wheels are experiencing significant differences in friction coefficient.
In certain situations the Active M Differential even works proactively. When pulling away on slippery surfaces, the lock is closed by a defined percentage even before a wheel can start to spin, to ensure that both wheels develop equal slip at the same time. This optimises traction and stability. The lock is also closed by the required percentage through enthusiastically driven corners, according to the levels of lateral acceleration and drive at work. This prevents the low-traction inside wheel from starting to turn too quickly.
This permanent and infinitely variable differential control also increases agility, avoids understeer on the way into corners and improves directional stability under braking and load changes.
Drifts on the race track.
M Dynamic Mode (MDM) also enables the new BMW M2 to satisfy the demands of drivers looking for a little extra on the dynamic front. MDM is a sub-function of Dynamic Stability Control (DSC). DSC effectively counteracts incipient oversteer or understeer or a loss of traction by taking steps (reducing engine power, braking individual wheels) to stabilise the car. However, in certain situations – e.g. sporty and dynamic driving on the race track – a greater degree of wheel spin can be an advantage.
Here, M Dynamic Mode, which is activated automatically in the recommended track mode (SPORT+) or can be engaged with a short dab of the DSC button, allows greater slip. The stabilising measures familiar from DSC mode now intervene later, increasing the freedom available to drivers at the dynamic limit.
The extra wheel slip enhances traction and therefore propulsion. More significant oversteer and understeer are possible, as are moderate, controlled drifts, but the Dynamic Stability Control active safety aids can still be relied on in critical situations. In any event, responsibility for stabilising the car always lies with the driver.
3. Excerpt from the M2 Technical Training (tables) (that you can find here | M2 manuals sticky: here):
Forum fellow Tag retooled the table to make it more intelligible:
///M is art Artemis
Last edited by Artemis; 05-17-2017 at 09:11 PM.. Reason: Original section #1 was replaced by pages 114 to 118 of the M2 owner's manual 2016 (US version)
Appreciate 12
      12-19-2015, 02:56 PM   #2
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
Thanks for the info. Based on the information, it is not possible to fully deactivate the DSC...
      12-19-2015, 03:37 PM   #3
twboy1999
Drives: 1994 honda accord
You can deactivate it
Just press the dsc button
Is in the manual
2019 M2 HS 10000km and counting
      12-19-2015, 04:47 PM   #4
JustChris
General
JustChris's Avatar
No_Country
17549
Drives: Tesla MYRWD
Is in the manual
Yes press and hold for a few seconds I'd imagine like in all Beemers?
My car made front page of Bimmerpost
AndrewC198910941.50
      12-19-2015, 05:30 PM   #5
swagon
swagon's Avatar
No_Country
13568
Drives: F80 6MT
TL;DR edition
- COMFORT, SPORT, SPORT+,
- MDM is activated by pressing shortly the DSC OFF button or by selecting SPORT+
- SPORT can be customized to some extent in iDrive
- EPS has two modes - COMFORT (lighter) and SPORT/SPORT+ (heavier)
      12-19-2015, 05:50 PM   #6
SW19
SW19's Avatar
2468
Drives: 2016 Alpine White M2
I don't get the specs on brake assistant:
When you apply the brakes rapidly, this system automatically produces the greatest possible braking force boost. It reduces the braking distance to a minimum during emergency stop.
This system utilizes all of the benefits provided by ABS
Do not reduce the pressure on the brake
I thought that brake assistant on the M3 and M4 will brake the car for you,if you get to close to th car in front of you.Shoudn't the system on the M2 be the same?I just want to make sure because I definitely do not want that feature on my M2.
It's an option on the M3 and M4,so hopefully it is also an option on the M2.
      12-19-2015, 06:11 PM   #7
PackPride85
Drives: M2
Adaptive brake assistant doesn't brake for you. When you press the pedal, it automatically calculates the required pressure to stop in an emergency situation by calculating distance to bumper in front of you.
http://www.bmw.com/com/en/insights/t...assistant.html
AndrewC198910941.50
      12-19-2015, 07:02 PM   #8
SW19
SW19's Avatar
2468
My mistake,I was remembering the wrong option on the M3.It is a feature in the drivers assistance package,called the collision avoidance system,which will automatically apply the brakes for you,if you get to close to the car in front of you.It is terrible feature and I won't be ordering it on the M2.
      12-19-2015, 07:42 PM   #9
Artemis
Moderator
Artemis's Avatar
29681
Translation into 1M language (except if mistaken):
  • 1M: regular mode | all nannies active (sensible)
    M2: COMFORT mode | low steering force for the driver | all nannies active (sensible)
  • 1M: push the M button (instrument cluster: "SPORT" icon) = M mode (aka SPORT mode) | all nannies active (sensible)
    M2: push the Driving Dynamics Control button to setting "SPORT" = SPORT mode | high steering force for the driver | all nannies active (sensible)
  • 1M: briefly push the MDM button (instrument cluster: DSC icon + MDM) | emergency nannies active (drift indulgent)
    M2: either briefly push the "DSC OFF" button or push the Driving Dynamics Control button to setting "SPORT+" (instrument cluster: DSC icon + TRACTION) = SPORT+ mode with DSC ON [TRACTION] | high steering force for the driver | emergency nannies active (drift indulgent)
  • 1M: keep pushing the MDM button for several seconds (instrument cluster: "DSC OFF" icon) = DSC OFF mode | no nannies, except for Active M differential (LSD)
    M2: keep pushing the "DSC OFF" button for several seconds to setting "DSC OFF" (instrument cluster: DSC OFF icon) = SPORT+ mode with DSC OFF + high steering force for the driver | no nannies, except for Active M differential (LSD)
Points to note:
  • Active M differential (LSD) cannot be switched off;
  • steering force preset cannot be toggled in a specific mode: COMFORT mode = low driver input preset | SPORT/SPORT+ mode = high driver input preset;
  • no cruise control possible in SPORT+ mode (regardless TRACTION mode or DSC OFF mode).
///M is art Artemis
Appreciate 4
rich8566608.50
Alexxxx52.00
MASHCT679.00
      12-19-2015, 08:08 PM   #10
Transfer
Transfer's Avatar
5260
Drives: Bronco Wildtrak, Tesla MYP
With traction all the way off, all settings will be max sport except throttle response will be normal/comfort (for controlled track driving). While in sport+ the throttle is more sensitive. Sport may allow you to customize throttle. At least that is how M235i works and sport+ throttle is too jumpy IMO.
      12-19-2015, 08:09 PM   #11
sth519
sth519's Avatar
119
Drives: M135i → M2 → i4
The M135i/M235i reverts to comfort mode settings in that case (light steering etc.). DSC OFF does not respect the selected driving mode on those cars.
Would be a nice change for the M2.
      12-19-2015, 09:03 PM   #12
ClothSeats
Drives: 17 1LE
If the Sport Mode is configurable, wouldn't one be able to enable sharp throttle along with comfort steering? Or am I missing something here?
      12-20-2015, 02:25 AM   #13
WAY
Australia
460
Drives: Fast ones
Yeah I'm a bit unsure about this either. It would seem that you can configure the steering on Sport, but I don't see reference to throttle response. Also there is no mention DSC and traction control is configurable here, as with gear change speed and response on a DCT car.
      12-20-2015, 05:31 AM   #14
MR.
MR.'s Avatar
No_Country
4403
Drives: BMW M2 CSL Turbomeister
My main question is if the SPORT mode configuration in iDrive allows you to disengage rev matching for the 6MT M2.
Any thoughts on that guys?
MR
      12-20-2015, 10:20 AM   #15
Pol
Pol's Avatar
Belgium
1120
Drives: M2 CS BMS DCT August 2020
Thanks!
      12-20-2015, 12:39 PM   #16
Artemis
Moderator
Artemis's Avatar
29681
Interesting points. No info yet. We'll find out in the near future.
It looks like "DSC OFF" is the only way to deactivate rev-matching.
From the M2 press release (Oct 14, 2015):
Manual gearbox with automatic rev-matching.
The all-new BMW M2 comes as standard with a six-speed manual gearbox, which stands out with its compact design and low weight. The use of a new type of carbon-fiber friction lining enhances shift precision. Dry-sump lubrication prevents any sloshing of the transmission oil and ensures all components benefit from an efficient supply of lubricant. An engagement speed control function, which blips the throttle on downshifts and lowers the engine’s revs on upshifts, makes gear changes even smoother and lends the car additional stability during hard driving on the track. Experienced drivers can still take pride in performing the task of perfectly orchestrated down-shifts on their own by deactivating the system in DSC OFF mode.
///M is art Artemis
      12-22-2015, 06:52 AM   #17
MR.
MR.'s Avatar
No_Country
4403
That would be pretty damn crap! Still I hope someone can code it out...
MR
      12-22-2015, 09:14 AM   #18
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
MR
Nah. You ancient folk in love with the old gods can drive the car without fancy modern tech like stability control. That's how your papi learned to drive. That's how you learned to drive. And don't nobody need to tell you how to drive any different. Haha
      12-22-2015, 09:33 AM   #19
MR.
MR.'s Avatar
No_Country
4403
LOL, I ordered a M-DCT. Friend of mine is worried. He wants to drive it without rev matching.
MR
      12-22-2015, 10:18 AM   #20
Artemis
Moderator
Artemis's Avatar
29681
Let's first experience the rev-matching before drawing conclusions.
///M is art Artemis
      12-22-2015, 10:54 AM   #21
PrematureApex
Drives: N55 X1, N54 135, s54 m3
? No one is drawing conclusions regarding how well it works. People are saying we want the option of rev matching ourselves, and it stinks that you may have to turn DSC off to do so. Ridiculous.
If you buy a manual, chances are, you like driving a manual. Rev matching/heel-toe, etc. are key pieces of that experience.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      12-22-2015, 01:19 PM   #22
chris719
Drives: '08 M Roadster
It boggles the mind that you cannot turn it off independently on BMWs and Porsches. The 370Z and Corvette allow this. They can't afford another menu option in iDrive or use a button blank?
Has the aftermarket been able to control this on the F80/F82?
m2
