12-27-2014, 04:50 PM | #1 |
Rep 189
Popping noise?
Anyone else notice a loud popping noise when backing up slowly with wheel turned all the way to one side? It's been going on for a while, it surely can't be normal, almost sounds like a bad cv joint or hub bearing. Just seeing if anyone else has this going on. Car only has 7k miles on it.
12-27-2014, 04:58 PM | #2 |
Rep 5,577
Happened to me 2 or 3 times.
Backing out of parking space & wheel turned all the way. I believe it's simple stiction from the front drivers side suspension joint (ball joint ?). I never thought if it as a defect or problem - but I'm curious if steering racks should be turned all the way to lock? Last edited by overcoil; 12-28-2014 at 09:03 AM.. |
12-27-2014, 05:00 PM | #3 |
Rep 190
That is kind of normal if its ALL the way turned while backing up. I drive them all day and if its a very slight noise i think i know what youre talking about. I never force the wheel all the way.
12-27-2014, 06:54 PM | #6 |
Rep 350
Drives: 2014 BSM/CR M235i
Wow. Thought I was the only one this was happening too. Happens mostly with my wife, she insists on locking the steering when backing up. What could it be?
12-28-2014, 04:01 AM | #8 | |
Rep 250
Mine is 4k miles when i started noticing its a tik tok sound lol like a bad cv joint. |
12-28-2014, 11:13 PM | #11 |
Rep 162
Could it be the performance tires are too cold? I have heard that some tires cause pop noises when its cold and you are turning all the way. There is even a YouTube video of a Porsche 911 doing it. Take a look.
12-28-2014, 11:28 PM | #12 |
Rep 721
That could be possible, the first time I noticed it was once it got cold.
12-29-2014, 11:03 AM | #13 |
Rep 347
I was getting this too, fairly often when reversing with the wheel cranked. Even in warm weather. Has not happened since I switched to the winter boots.
F22 * (N55 + 6MT) ÷ PSS = FUN
05-06-2015, 11:16 AM | #14 |
Rep 2
Hi, I've just picked up my new F22 a month ago (1000 km) and a couple weeks ago I also started to ear a popping noise (like "troc", it's just an isolated noise) coming from the steering when I park the car or when I turn the wheel when I am in reverse at low speeds. I notice that the quicker I turn the wheel the louder the sound is. The odd part is that sometimes it happens sometimes it doesn't.
It's seems that I am not the only one having this "problem" and I was wondering if any of you asked your BMW dealership about it and what was the answer they gave you. Thanks, |
05-06-2015, 01:42 PM | #15 |
Rep 199
Drives: M235i alpine white on black
front strut tower caps. had mine replaced and it took care of the problem
01-27-2017, 06:06 AM | #16 |
Rep 1,151
