2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235i - Shut down suggestion
      12-27-2014, 01:48 PM   #1
M2-BM35i
Drives: M2Comp
Got my M235i after a long wait ...
Now I have to leave her in the garage as I'm away for around 3 months
As I won't be giving the keys to anyone ( - any suggestions on best way to leave her? Defin needs a battery maintainer , perhaps anyone have other good suggestions?
      12-27-2014, 02:06 PM   #2
Sportstick
Sportstick's Avatar
4654
Drives: '15 228i and '24 X3 sDrive30i
Inflate tires to the maximum cold pressure shown on the tire sidewall to help reduce flatspotting. Don't forget to deflate to normal usage upon return! Fill tank to first shutoff (never top off!).
      12-27-2014, 02:11 PM   #3
overcoil
Drives: M235i 6spd
Jay Leno's Garage has a good piece on trickle battery charges / worth googling.
Make sure car is clean - and run the heat on the HVAC real good to make sure no bacterial growth in the system.
There was a similar post a few weeks back that was informative - hope you can find it.
      12-27-2014, 02:40 PM   #4
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
I'd add some fuel stabilizer if it's going to sit for 3 months.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      12-27-2014, 02:40 PM   #5
bluemeanie
Drives: 228i=awesome
After leaving my cars in the garage last year for several months I would also suggest covering your car to avoid dust buildup. I put down several towels and used a plastic drop cloth (new) over them. Of course, a fitted car cover is even better.
      12-27-2014, 03:22 PM   #6
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
You may have this covered, but depending upon where you are leaving it, or with whom, might wish to make sure there are no other items near by.
Bicycles, gardening equipment, hanging items, bins and other items might need to be removed from area if others are using the area. I stored in a nearby garage and noted some garden items that had been hung on the wall, perilously hanging by hooks in what we call dry wall board [put up by someone who did not take the time to find wall studding.] I offered to correct that and did.
I put extra padding towels at all four corners when I do this same thing--in that, if someone is going to be near and walking around the car to "get at things" corners are usually vulnerable. And mirrors should be tucked, doors locked to shut down on excessive battery usage.
Last, you mention keys not given to anyone...BUT should the car have to be moved for any tragic reason...I would want someone trusted to have those keys. Just some thots from someone who stores all the time.
      12-28-2014, 09:06 AM   #7
M2-BM35i
Drives: M2Comp
Thanks for responses... wish I could take her with me... what a machine...
How long on average is waiting period for M235i's from ordering to arrival?
Mine took nearly 6 months...
      12-28-2014, 09:10 AM   #8
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
+1. Helps keep the tires from flat spots and sediment forming in the tank. If you store for more than 3 months then some fuel stabilizer would help too.
