02-16-2021, 10:04 AM | #1 |
Rep 76
Battery Tender
I need one because I’m working from home and cannot drive it often enough. The dealer says the kind they install requires me to unhook it under the hood every time I drive it. I have a bad back and don’t want to do this. I have one on my Miata that just requires me to plug and unplug it in the trunk. Is there an easier setup up for my 228i?
Thanks. |
02-16-2021, 12:41 PM | #2 |
Rep 1,188
Drives: 2008 e92 335xi
The tender attaches under the hood on the passenger side close to the firewall. There's not much bending over, if that's what you're concerned about. You can attach it standing up straight after opening the hood.
Trying to attach a tender to the battery itself would put significantly more stain on your back since it's located in the trunk in a well.
02-16-2021, 04:28 PM | #5 |
Rep 2,200
02-16-2021, 05:04 PM | #6 |
Lucky13
212
Rep 1,762
My BMW branded battery tender is made by Deltran. It looks just like the Battery Tender brand but a BMW logo on it. I use mine one night a week and my battery is original on a 2014 M235 with only 20,000 on it.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
02-16-2021, 05:14 PM | #7 | |
Rep 6,032
The hookup does not challenge my bad back. Opening the hood is as easy as the trunk, and then the terminals for attachment are directly and easily accessible. This is an easier reach for a challenged back than reaching down into the trunk.
Artdnj394.00 |
02-16-2021, 05:18 PM | #9 | |
Rep 8,942
I stuck with BMW brand purchased at my BMW dealer simply because there's no possible way they could hassle me about it if a battery warranty issue ever came up.
02-16-2021, 05:31 PM | #10 | |
Rep 6,032
https://smartercharger.ca/collection...-multi-us-7002 BTW, this is $118 on Amazon. I had paid $110 in 2017. https://www.bmwblog.com/2016/01/28/b...ttery-charger/
Artdnj394.00 |
02-16-2021, 06:32 PM | #11 |
Rep 213
I've been using CTEK MXS 5.0 for a few months now.
Paid ~$80 on Amazon. I got this one since it has maintenance option specifically for our AGM battery Not sure but looks like it's the same as the BMW rebranded unit. |
02-17-2021, 08:25 AM | #13 | |
Rep 8,942
That seems sketchy at best, no way I would do that without some sort of assurance directly from the manufacturer.
02-17-2021, 10:24 AM | #14 | |
3626
Rep 3,594
02-17-2021, 11:29 AM | #15 |
Rep 970
I bought this one from Amazon:
CTEK - 40-206 MXS 5.0 Fully Automatic 4.3 amp Battery Charger and Maintainer 12V (40-206) https://www.amazon.com/CTEK-40-206-5...xpY2s9dHJ1ZQ== Initially it said it was not compatible with my M240i, Called CTEK and was told it is compatible. Have been using it w/o any issues. It is simple to use, open the hood, attach the clamps to the red and ground and plug charger in. I have a bad back and this routine doesn't affect my back at all. I do not go into the trunk at all. Amazon sells other CTEK chargers with BMW logos for more $. The above models works fine. |
02-17-2021, 11:34 AM | #16 |
Rep 117
There is an accessory that allows for permanent connection to battery. I use my CTEK MXS 5.0 under the hood so not sure if there are limitations for our cars.
https://smartercharger.ca/collection...t-connect-m8-1 |
02-18-2021, 07:00 AM | #18 |
Rep 2,873
They also sell a very long extension wire with battery connectors, so the unit can stay indoors and power a car in the driveway. I am about to order mine, so no direct experience, but I'm told they also get fairly hot at times, so don't rest the unit on upholstery or plastic trim panels.
02-18-2021, 10:36 AM | #19 | |
Rep 65
The MXS 5.0 manual shows the following: |
02-18-2021, 11:02 AM | #20 | |
Rep 65
Battery chargers for the vehicle battery can work with high voltage and currents, which means that the 12 volt on-board network can be overload or damaged. There is a risk of damage to property. Only connect battery charger for the vehicule battery to the starting aid terminals in the engine compartment. Last edited by qlaval; 02-18-2021 at 07:50 PM.. Reason: spelling... |
02-18-2021, 05:11 PM | #21 |
Rep 213
On the MXS 5.0 on 'car' mode there is 'normal' or 'AGM'. I use Car / AGM mode. Both lights ( Car and AGM) will be lit when charging and in maintenance mode.
From my understanding, normal will work just fine but in AGM mode these batteries can take a higher charge rate than normal lead acid batteries so if your in a hurry to top it off then use AGM mode, otherwise normal will work just fine too. But again, i set it to car/AGM mode and let her sleep. Last edited by jv92red; 02-18-2021 at 05:19 PM.. |
qlaval52.50 |
02-18-2021, 05:36 PM | #22 | |
Rep 318
18 M240i RWD auto
Previous: 01 Z06, 99 323i |
qlaval52.50 |
