08-04-2015, 04:39 PM | #1 |
Rep 159
M235i CLICKING NOISE
Has anyone experienced a noise when turning under load. It sounds almost like I'm dragging sticks along the road, it's defo a revolution noise. I've had the car into my local dealer (Elms Cambridge) 3 times for separate investigations to no avail. New callipers, new disks, some kind of pin in the callipers. They also carried out a fix that meant removing all the headlining?? The last visit it had almost 19 hours work and still I have the problem. Help!!
Estoril 11 F31 Msport & Mineral White M235i M Performance with MPE
08-04-2015, 05:20 PM | #3 |
Rep 159
Looks like this is a common problem after searching the thread. I've passed the info to the dealer. I'll update on the progress. many thanks
08-04-2015, 05:25 PM | #4 |
Rep 470
I definitely hear clicking noises very intermittently as well. Sometimes it sounds like something is hitting the undercarriage. Would be interested in getting more info on this.
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
08-05-2015, 07:11 AM | #8 |
Rep 199
Both myself and another 135 owner that I autox with have the exact same noise. I'm assuming it's nothing to worry about. I just had all 4 rotor replaced due to pulsating so we'll see if the noise is gone this weekend since I have an autox on Saturday.
08-08-2015, 05:59 PM | #9 |
Rep 108
I've been hearing a clicking sound during hard cornering as well (ESC on or off). It sounds like a rock is stuck in a tire.
2024 BMW 340i xDrive |
09-06-2015, 11:02 AM | #11 | |
Rep 108
Fixed it...I hope
Lug Torque Thread: http://www.2addicts.com/forums/showthread.php?t=1008231
09-06-2015, 11:44 AM | #12 | |
Rep 860
09-06-2015, 12:26 PM | #13 |
Rep 108
Reading a thread over on 1addicts, there were more than a few people that had the same clicking sound go away after new wheels/tires were put on.
Originally I was planning on pulling the front wheel off to check for nails and inspect the the brake rotor/dust shield but that didn't happen because I need a low-profile jack. A bit off topic but how the h*ll are we supposed to lift the car and use a jack stand? The whole under side of the car is covered with plastic and the lower control arm bushings don't look beefy enough to put a jack stand under.
09-06-2015, 01:09 PM | #15 |
Rep 108
I doubt it, the lugs weren't that loose. This is a guess but I bet the lugs were set around 80ish ft/lbs. They only needed 1/8 to a 1/4 turn.
If the wheel would have really been flopping around I'd be worried.
09-07-2015, 12:23 PM | #16 |
Rep 2,897
Strange clicking from front wheels when turning in '14 M235i (MP3 included). http://www.2addicts.com/forums/showthread.php?t=1130937
This is your answer Think question comes about every month or so Please spread this answer |
09-08-2015, 07:00 PM | #17 | |
Rep 555
09-09-2015, 01:01 AM | #18 |
Rep 19
I too was plagued with this problem. Went to the dealership two times and there was no fix.
However... I found the fix... 1. Buy a torque wrench 2. Set that bad boy to 105 ft-lb 3. Torque your wheels 4. SHAAAZAMMM noise is gone. Frustration over. You're all welcome xD |
09-25-2015, 04:06 PM | #19 |
Rep 1,078
Just went to the dealership today. My service rep knew of the problem before I even finished explaining so it is a pretty common problem for the m235i. He said it was related to the suspension and would be a 2 day fix so I gotta bring it back to get a loaner car.
09-25-2015, 05:29 PM | #20 |
Rep 860
Wow, what with the suspension could possibly take them more than a few hours to fix? Not only that, has anyone here heard about a common M235 suspension issue? This seems to be new news.
09-25-2015, 06:46 PM | #21 |
Rep 1,078
I should have clarified.. the 2 days is due to parts they did not have, not because it takes that long to fix and he was trying to avoid having me go back and forth.
09-28-2015, 03:37 PM | #22 |
Rep 65
My car is in the shop for the clicking noise issue, showed them the SIB, did test drive heard the noise. They have no idea what is going on, since my car is Canadian, mechanics are not sure if American service bulletin still applies. Will update later on details.
