04-24-2015, 01:18 PM | #1 |
Rep 678
Run flats save the night
Hit a wicked pot hole that took out my passenger front and rear tire. Indicators light up, 0 psi showing for those two tires so I pull over in a parking lot check it out and can see that they are both flat and proceed to hit my bmw assist button. That all worked as designed they figured out where I was and offered to send a tow truck and take me to the dealer of my choice. Then they noticed I had the run flats and noted that if my indicator lights are amber I can drive a good 50 miles at 50mph. I hit my nav button and see home is 34 miles out, turned on my hazards and made it back to the house.
I made it to discount tire this morning and fortunately no rim damage, tires had 50% tread life so there is a bit of loss but I do have some new rubber on my rear wheels. I was thoroughly impressed with the option the run flats provided me as I was not in the best section of town, it was after 9 pm so it was getting dark, things were closing up and it was starting to rain. I was itching to get some sticky summer tires but after what happened to me last night, I'm a run flat believer. Friggin pot holes.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold Last edited by G-Mann; 04-24-2015 at 01:27 PM.. |
04-24-2015, 01:25 PM | #2 |
Rep 980
What a fantastic and reassuring testimony to both BMW's tire design and its roadside service (with honorable mention for the nav). Sorry you had this experience but thanks for the positive report.
04-24-2015, 03:32 PM | #4 |
Rep 855
That is the plus side to run flats...the negative is they cannot be repaired. You run over a nail coming out of the tire shop....your brand new tire has to be replaced...cannot be patched.
04-24-2015, 03:38 PM | #5 | |
Rep 886
Many Run flats can be repaired as long as you don't drive on them. It varies by manufacturer. You can see a list of who does / does not allow repairs here: http://www.tirerack.com/tires/tirete...jsp?techid=226. Many places won't fix them because they don't want to take any potential liability. However, if you have a nail puncture in the tread area and don't drive on the tire while it's flat, it can be safely repaired using an internal patch over the puncture. Here's the quick rundown, lifted from the page listed above:
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 04-24-2015 at 03:48 PM.. |
04-24-2015, 03:41 PM | #6 | |
Rep 855
04-24-2015, 03:46 PM | #7 |
Rep 886
Yeah, Pirelli does go the "Not Endorsed" route, but they do pro-rate the replacement price right down to a fully worn tire, which is a decent policy.
Still, if I had an AWD car with half-worn Pirelli RFTs, I'd get a punctured one patched if I could, rather than play the "What's the circumference difference?" game. But, I'd never try to repair one on which I'd driven any distance.
04-24-2015, 03:52 PM | #8 | |
Rep 2,942
They plugged/patched it, with the stipulation that the tire loses its speed rating and shouldn't be driven over 100MPH. I can live with that until I replace 'em at about 15K miles (or whatever the 280 AA treadwear rating gets me). Moral: it can be done, but only to the tread area and only if the tire hasn't lost all of its pressure.
04-24-2015, 04:08 PM | #9 | |
Rep 855
04-24-2015, 04:20 PM | #10 | |
Rep 2,337
I had runflats on my last car. Got one puncture, but I was home when I noticed it. In Cali there is lower risk of blowouts than other parts of the country, so sticky summers all day. If I take road trips in the car, I might have to invest in a spare though... I think this is the best solution, but it won't help OP who goes through two at a time.
04-24-2015, 04:26 PM | #11 |
Rep 855
No they were not....they are an add on to new tires purchased from them. The manager did it to make sure I always buy my tires from them. Hell I had just purchased a set of Yokahamas for my wifes Pathfinder from them two weeks before. Good business on his part because I will come back!
04-24-2015, 04:38 PM | #12 | |
Rep 308
I bought the wheel and tire package based on that exact statement (or rather, lie) and when I ran over a nail the tire guys at BMW patched my tire. When I told them the salesman told me I couldn't patch a run flat they acted like I was making the story up. I've never bought wheel and tire since, and I've also never gone back to that dealership. (Hendrick in Charlotte BTW - they're crooks). |
04-24-2015, 05:35 PM | #13 |
Rep 441
I have gotten a Potenza RE050a dismounted and patched. Saved me $460 on a new one. The tech wasn't supposed to patch it as his boss told him not too, but he did it anyway to see if it worked to prove his boss wrong. Never had an issue with 15k miles.
04-24-2015, 07:30 PM | #14 | |
Rep 855
04-24-2015, 08:04 PM | #15 | |
Rep 678
Discount did go over which tires could be patched and of course with the road hazard warranty its a non issue. I did go with a run flat again vs the PSS I had coveted. Went with the RE960 that also has a 40k mile warranty, one of the few run flats that offer a tread life warranty. Certainly not the fastest tire but then again I am not building the fastest car. Funny thing is I ditched the run flats on my last ride and drove for 3 years without a spare or run flats and rode that 96.8% rate and was not a believer until last night. Not sure how long I would have waited for that tow. I used the service with an infiniti I had a few years back and the tow drivers were taking on too much work and took over 2.5 hours to get to me. Hopefully BMW's program works better, hope last night was as close as I come to figuring that out.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
04-24-2015, 08:14 PM | #16 |
Resident BMW Fanboy
259
Rep 866
Not a fan of run flats. The rigid sidewalls bend your wheels when you hit nasty potholes. I'd rather keep a spare in the trunk. Not to mention the absolutely terrible ride quality.
Current: '20 F82 M4cs SMB / '13 640i M-Sport Carbon Black
Past: F30 330xi Luxury Line / F22 M235i 6MT / E92 335i / E46 330ci / E36 328i 5MT |
04-24-2015, 08:41 PM | #17 |
Rep 675
Drives: 2010 128i, manual, sport pkg
not a fan of run flats either, when I found a flat tire in the morning, no one would repair it. But at least the experience taught me how to plug a tire with a $10 kit.
2010 128i manual, sport package, performance exhaust, Vorshlag camber plates, Bilstein B6 struts/shocks, 245/40/17 ZIII square on et 40 with rolled rear fenders.
04-24-2015, 11:21 PM | #19 |
Rep 917
Drives: 2015 BMW M Sports Convertible
New tyres should go on the front not the rear if tyre wear is down 50%. Their is a small area on run flats that can have nail holes etc repaired and my insurance says repaired or replaced free.
My Z4 run flat was able to be driven home after getting a flat out of town but it had to be replaced later. I have no problems with run flat tires.
2015 220i M Sport convertible.
2016 225xe M Sport. |
04-24-2015, 11:48 PM | #20 | |
Rep 855
04-25-2015, 12:37 AM | #21 |
Rep 530
04-25-2015, 04:18 AM | #22 | |
Rep 886
Repeat after me: Best tires in back. Again: Best Tires In Back. One more time: BEST. TIRES. IN. BACK. New tires go on the rear. Always. FWD, RWD, AWD, 4x4, summer tires, winter tires, or all-season tires, none of them change anything. If you're replacing two, they go on the back. Nothing says "Ain't got it!!" like the back trying to pass the front when you don't want it to. Same with a bike. You may recover a front wheel skid. You won't recover a rear. Worst case situation is standing water or snow/ice where the back end has broken free. If you apply the brakes, the car's weight shifts forward onto the (already) higher traction front end and away from the lower traction rear end. The sideways situation increases. In the opposite situation, where the front is free and the rear is still attached, better tires in the rear increase rear traction. Having the car's center of mass ahead of the point of drag will straighten you out by itself, assuming you don't add more energy to the situation.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 04-25-2015 at 05:27 AM.. |
