Improving straight-line launch times (+ some accelerometer insights) |
10-29-2016, 03:40 PM | #1 |
Rep 101
So, I bought a low-end accelerometer (K.A.T. Matrix 3-Axis, only about $102 from Amazon) to compare launch times on various small mods and different modes. It's a pretty good value-- more accurate than phone apps, and battery powered so you don't have to keep it permanently wired to your mirror ports. The only major downside is that some of the buttons are "sticky" and it takes some finagling to unstick them.
On a mostly stock 2016 M235i with 225/40 all-season tires + Eisenmann exhaust and Dinan intake, I got 4.84 seconds in Sport+ mode. When I tried Launch Control, the fish tailing was so bad that I'm sure it would have been 6+ seconds if I hadn't just stopped. I figured this might be because of my tires, so I replaced all of them with Michelin PSS (235 front, 245 rear) in the hope of improving traction. I attempted the same modes again: Sport+ ... 4.83 sec Launch Control ... 5.2 sec (FWIW, outside temperature was around 75, tires were warmed up from ~30 min of normal driving beforehand) The fish tailing was very slightly improved in Launch Control (subjective assessment), but as you can see, nowhere near Sport+. Other posters have commented that when magazines have tried out Launch Control, their times worsened. I always assumed (incorrectly?) that the 4.6 sec 0-60 time that BMW cites was in launch control, but maybe that's not the case? Is it worth it to try to improve traction with the MP LSD? Or get a tuner and not bother with Launch Control? Last edited by martopoulos; 10-29-2016 at 03:46 PM.. |
10-31-2016, 10:16 PM | #2 |
Rep 101
Welp, I just ordered the Dinan stage 3 ECU and Intercooler. I will report back with 0-60 times (and maybe a Dyno session) when they're installed. *Fingers crossed*
10-31-2016, 10:42 PM | #3 |
Rep 5,369
Any tests in DSC Off? I'm convinced more power is unleashed in this mode, at least in the 6MTs. On hard shifts, there's no delay in full power in this mode. In any other mode you feel the nannies trying to manage spin and power. My car is a different animal in DSC Off plus it's the only mode that the eLSD is active.
10-31-2016, 11:09 PM | #4 | |
Rep 101
11-01-2016, 03:41 PM | #5 |
Rep 716
Drives: F90 M5
have you tried launching in second at around 2k? at my local drag strip i tried launching in second and saw that my 60' had improved slightly
11-02-2016, 01:54 AM | #7 |
Rep 716
Drives: F90 M5
For sure man. Let us know if it helps
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
11-03-2016, 02:32 PM | #8 |
Rep 716
Drives: F90 M5
any updates?
11-03-2016, 02:36 PM | #9 |
Rep 101
11-03-2016, 04:05 PM | #10 |
Rep 716
Drives: F90 M5
lmaoo, i feel you im from the valley and its always crowded, what part of LA are you in?
11-03-2016, 04:12 PM | #11 |
Rep 101
11-03-2016, 04:13 PM | #12 |
Rep 716
Drives: F90 M5
11-03-2016, 04:48 PM | #13 | |
Rep 1,931
0 - 60 about 4 seconds.
www.nybmwcca.org
11-03-2016, 05:55 PM | #14 |
Rep 101
11-05-2016, 08:46 PM | #15 |
Rep 101
So, I found a new spot that's absolutely perfect (thank you, Google Earth). So perfect that two guys were down there racing with GoPros mounted on their roofs... Long stretch in an industrial park with a dead end.
The winning combination seemed to be long-pressing the DSC button to completely turn off DSC. 0-60 time was 4.57 sec. I also kept my foot on the brake until I had floored the gas to prevent the accelerometer from starting the clock prematurely (that alone didn't make a difference in launch time when I tested, for the record). I had no noticeable fish tailing or wheel-spin. As for starting in second, I noted that Sport+ does indeed start in second, FWIW. In other news, the Dinan stage 3 ECU and intercooler install is scheduled for Thursday, so I should have new numbers by the weekend. |
11-06-2016, 07:40 AM | #16 | |
Rep 27
3.9 would be great! Haha - but I don't know - I'll remain skeptical of that time until I hit a strip.
2016 M235i xDrive Black
Dinan: Stage II Tune, Cold Air Intake, & Exhaust |
11-06-2016, 08:51 AM | #17 |
Rep 3,888
Most accurate timing should be from a device using a relatively high GPS sample rate. This one samples position 20 times/sec which should provide an error of +/- 0.05s:
https://www.vboxmotorsport.co.uk/ind...ers/vbox-sport |
11-06-2016, 09:35 AM | #18 |
Rep 1,931
your best times will be with sport + using launch control.
my 60's are 1.6 - 1.8. 0-60 are 3.47s.
www.nybmwcca.org
11-06-2016, 12:23 PM | #19 |
Rep 101
Do you have an LSD? Even with 245/40 Michelin PSS tires in the back, I still had so much fishtailing and wheelspin with Launch Control that my 0-60 didn't drop below 5.2. Also, what are you using to time your 0-60?
11-06-2016, 08:17 PM | #20 |
Rep 1,931
xdrive auto. No LSD.
using Harold, and Torque pro. If your spinning, take air out of your tires, i'm on Nitto 01's.
www.nybmwcca.org
11-06-2016, 08:29 PM | #22 |
Rep 5,262
try 35 do a run, try 32 do another run try 29 and do another.... don't go below 29 or so....also just do it for the rear... no need to take pressure off the front just in case anybody wonders....
