2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning 2018 m240i transmission operating temp 6mt
      02-27-2024, 11:18 PM   #1
Davemiss
Drives: BMW m240i
Question regarding 6mt transmission operating temps. I have searched and searched and haven’t been able to find a definitive number for the transmission operating temp of a bmw m240i 2018 6mt.
I ask because I recently applied a MHD stage 1 tune running on 93 octane. I also have a high flow, non-oiled air filter, as well as an ARM Midpipe with both resonators deleted.
After monitoring the transmission temps after the tune , which fluctuated between 190 degrees F and 230 degrees F, I am concerned about an increase in transmission temps.
After flashing back to stock and then monitoring the transmission temp, it would seem that the tune is more than likely responsible for a 7 degree increase, with number fluctuating from around 190 degrees F and 223 degrees F.
This increase seems marginal and I’m willing to accept that temp increase for the benefit of the tune, as long as these numbers fall within a normal operating range. BTW, engine oil stays solid at 228 degrees F to 231 degrees and boost never exceeds 17.3 psi.
Thanks in advance.
      02-27-2024, 11:35 PM   #2
SpencerC_6MT
SpencerC_6MT's Avatar
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
As far as I'm aware, the "transmission temperature" parameter is just based on formulas for 6MT cars, rather than an actual sensor. 230 Fahrenheit is just about what my car always reads once it's up to temp, I wouldn't be concerned. If you're really worried about it, change to a higher viscosity gear oil.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
      02-28-2024, 01:31 AM   #3
n55david
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Thanks in advance.
Normal
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
