2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Determinate Differential type
      12-03-2023, 04:18 PM   #1
Arca46
Drives: Bmw M240i Lci
How can I determine the type of differential fitted to my 2017 m240i Lci which no longer has the label with the code above?
I attach photos of the differential
      12-04-2023, 09:47 AM   #2
SpencerC_6MT
SpencerC_6MT's Avatar
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
From what I remember, the M Performance LSD is visually identical to a stock open diff. Your best bet is probably the good old fashioned, put both wheels in the air and see which way they spin.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
      12-04-2023, 09:53 AM   #3
Arca46
sorry, I wasn't clear, my differential is open, I already know that, I would like to understand if it is a 188LW or a 215LW...
      12-05-2023, 12:13 PM   #4
Dom147
unfortunately you'd have to lower the diff and check the part number located on the top.
      12-05-2023, 12:17 PM   #5
Arca46
I looked at the top of the diff with a mirror but unfortunately the white label with the BMW OEM code is no longer there…
      12-05-2023, 01:19 PM   #6
Dom147
hmm. perhaps there is a way to calculate the final drive using the rolling diameter of the rear wheels and inputting them into a calculator to find out what RPM's produce what speeds? This may be the only way outside of that. Unless there is a way to check in ISTA. I have heard of some people mentioning a "relearn final gear ratio" button somewhere on there.
      12-05-2023, 01:48 PM   #7
Arca46
I'll try to find out more about both methods, thanks
Dom14790.50
      12-06-2023, 04:20 PM   #8
SpencerC_6MT
If xDrive it's the 188, if RWD it's the 215. Should be simple as that, unless it's been changed at some point in the past.
n55david1295.50
