2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning B58 oil pumps failing disastrously in cold climates
      03-09-2021, 12:18 PM   #1
BrettKA7
Drives: F22 M240i
User mariusrisan posted to the BMW subreddit today with these photos of oil pumps that are seemingly becoming brittle and taking the engine out when they break down.
'G-series B58 owners in cold climates - check your oil pumps! We've had two almost new cars in our shop since february with blown engines due to the oil pump failing in freezing conditions. BMW have made an updated oil pump which replaces duoplex plastic with metal. The pictures speak for themself'
I wonder if this will eventually translate to breaking down due to age? I'll never understand why the German companies use so much plastic where there should be metal…
M240i | Mineral White | Coral Red
      03-09-2021, 12:23 PM   #2
KennyFSU
KennyFSU's Avatar
1104
Drives: Lexus RC F
How many miles on his engine and what mods?
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115
Ultra White Lexus RC F
      03-09-2021, 12:31 PM   #3
BrettKA7
Drives: F22 M240i
The Reddit thread is a little unclear. Here's a link:
https://reddit.com/r/BMW/comments/m1...es_check_your/
OP just said "almost new cars"
      03-09-2021, 02:37 PM   #4
TonM3
TonM3's Avatar
Drives: 2006 E46 M3 / 2017 M240
Curious how much the new part costs and how much labor is involved?
E46 -> E90 -> F30 -> F23
      03-09-2021, 02:54 PM   #5
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
FWIW the G series uses the B58D and a quick check of Real OEM shows a different oil pump PN for our engines (M240) compared to what the G series are running. Now that does not mean we don't have plastic in ours but it is a different pump.
      03-09-2021, 03:04 PM   #6
BrettKA7
Drives: F22 M240i
You're right! I misread G-Series as F-Series for some strange reason.
The F-series engines show a different part number, but there's understandably no teardown of the OG B58 fuel pump.
      03-09-2021, 03:13 PM   #7
Aspen235
Drives: 2014 X3 35i, 2018 M240i 6mt
Geez, how cold are we taking about?
      03-09-2021, 03:30 PM   #8
aerobod
aerobod's Avatar
3626
I've not heard anything of B58 oil pump issues here in Alberta, with thousands of vehicles in the BMW line up using them here and operated in temperatures down to -40C or so in the winter.
Although the engine may be started with oil at -30C, the oil is at 0C within 2km or so of starting, at +50C within 6km and +100C within 10km of a cold start at low temperatures, all with gentle driving until the oil is fully warm.
WolfGTI716.00
dradernh4413.00
      03-09-2021, 06:09 PM   #9
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
Originally Posted by POMFKIMOCHI View Post
Sounds like they didn't have properly weighted oil for the temperatures and the oil pump took the brunt of it? �� Like aerobod said, us Canadians deal with colder temps yearly. I imagine this happened someplace where it is usually warm, got hit by some cold fronts and didn't know how to react?
Hard to understand, the G01 M40i comes factory fill with 0W-20 and only 0W-30 is an acceptable alternative. Both have a pour point south of -40.
Maybe some rube put 10W-60 in it, because M oil. Have seen a couple people report garbage Euro shops putting 10W-60 in N55 and S55 cars.
If I were to guess, the plastic heat cycles with the oil and became brittle at low temp.
      03-15-2021, 10:18 AM   #10
AleksanderSuave
Drives: 2017 M240iX Coupe
Im in michigan and so far have had a few record cold days here in the last few years (-45 without windchill I think 2 years ago?)
Havent had any issues. This winter has been particularly cold too. Cold enough to where my window motor would freeze and the window wouldnt "slide up" when the door was closed.
I would be more worried about that then the oil pump at this point. Cant drive it in that condition since the door wont actually lock shut.
      01-17-2024, 08:36 AM   #11
iksana
Drives: g20
Hi guys. There is an revised oil pump for the B58TU that has the rotor housing made from steel not plastic. i just did one today and i can confirm it.
I have uploaded the images in this gallery : https://postimg.cc/gallery/LjMMvcw
Hope it helps. Cheers.
