2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Enzo Performance N55 Tune - Independent Dyno Results
      12-05-2015, 03:43 PM   #23
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Originally Posted by boost82
I asked them a couple times but never got a response about fueling. Are you running meth or any other supplemental fueling to run full boost on that turbo?
The jb guys need meth to run 24 25 pds of boost
To run max boost you will definitely need some type of additional fueling. Personally I'd rather avoid meth and plan on eventually adding the fuel-it tbi kit and lpfp. Right now I'm on stock fuel system using 93 pump and have had no issues. Looks like the current tune is peaking at 21psi but tapers off as rpm increases. Will experiment with adding a bit of e85 and see what happens, on the stock turbo I could add as much as 5 gallons per tank with no issues.
I had a chance to test the car last night and I have to revise my earlier comment of the car not being much faster. Even on the current tune the car feels like an absolute beast, at WOT it's frighteningly fast. It's definitely a lot faster, the power delivery is so incredibly smooth it's ridiculous, the blurb between shifts is louder and it sounds absolutely intoxicating at WOT.
Since this is my first upgraded turbo, I didn't know what to expect and was really worried about the increased spool time affecting my 0-60 times, but I am happy to report that I easily matched my record of 3.80s on the first run, with half a tank of gas.
Honestly I'd recommend this upgrade along with the dv+ even for people who don't plan on running max boost, I feel it's really improved the overall feel of the car, not sure why that is but I assume it's because the turbo just runs more efficiently vs a maxed out stock turbo.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-05-2015, 08:03 PM   #24
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
I'm dying here!!
My Build Thread can be found HERE
      12-06-2015, 03:21 AM   #25
Luminous
Luminous's Avatar
743
Update:
So it feels like the car is getting faster the more I drive it, as though the ecu is adapting to the bigger turbo. I don't know enough about engine management software to know whether that's even possible, I'm just reporting my subjective impressions.
I did manage to set a new personal record for 0-60 times: 3.67s and acceleration of 1.35Gs
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-06-2015, 04:14 AM   #26
chaddy74
chaddy74's Avatar
Australia
231
Drives: M135i
Sounds and looks very promising
Update:
      12-06-2015, 08:34 AM   #27
boost82
Cool man. My problem with the fuel it tb kit is it uses a boost switch. To me that's no different than or more reliable than a meth kit.....
Don't run ethanol you will need more fuel volume. If you get the fuel it kit then you can try some mixtures
      12-08-2015, 02:54 AM   #28
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Welcome to the Pure Stage2 club
      12-08-2015, 02:59 AM   #29
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
I don't see the problem with the Fuel-IT TBI kit. The hobb's switch is pretty reliable. You set the load of the spring. You get pressure in the CP and it makes contact. Completing contact opens the solenoid and the TBI nozzles start spraying. It sprays in tank fuel. So it works perfect on an E30-E40 mix in my car. I have been running it since summer. No issues at all.
      12-08-2015, 11:40 AM   #30
boost82
No problem I just think it's no more or less reliable than boost switch meth kit, that was my point. I didn't say it wasn't quality parts or anything I'm sure it works great
      12-08-2015, 11:51 AM   #31
boost82
I haven't ruled out buying the kit cause I want to run ethanol but just wish it was controlled a bit more advanced than a on off boost switch.
      12-08-2015, 12:07 PM   #32
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
How much more simple can you have it than a analogue boost trigger signal? And the difference with meth is that you spray the same octane as without it because it runs from the in-tank fuel. I think there are fewer points of failure. Then again i have been running both tbi and meth for some time.
Its hard to let the meth go... Like its an addiction
      12-08-2015, 04:49 PM   #33
boost82
The problem with using boost is it's not a good indicator of engine load. You can be in 5th or 6th gear at low rpm and spool your turbo fully up at like 3 to 4k rpm. That's what I mean... Same thing with the meth kits that why I bought an Aquamist kit because at least I can trigger on rail pressure and injector duty cycle. Even if we could integrate an rpm input into the controller I would love that.
BTW, I am def addicted to meth haha
OP, sorry for the thread jack haha
      12-09-2015, 09:30 AM   #34
LimeRockM235
LimeRockM235's Avatar
57
Drives: M235i Xdrive
when you said you dropped your car at ACM was that short for Autocouture? ive been looking for a shop in NJ
      12-09-2015, 10:18 AM   #35
Luminous
Luminous's Avatar
743
Yes, great shop, highly recommended.
Here's a pic of my car from their fb:
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-09-2015, 10:27 AM   #36
LimeRockM235
57
awesome im going to head over some time this week once i get my car. im going to have them do my flash ive been in contact with lalit. got his info through my dealership. seems like an awesome guy.
who actually does the tuning for the shop though?
      12-09-2015, 10:44 AM   #37
Luminous
Luminous's Avatar
743
Honestly if you're looking for flash tuning you're probably better off checking out Enzo Performance in Long Island.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-09-2015, 11:25 AM   #38
LimeRockM235
57
question about flashing the ecu. if i needed to bring the car in for service would i get the oem tune back on. would i have to take my car back to enzo first. what work do you have ACM do for you also? My boss is friends with one of the guys there thats the only reason i considered them for tuning.
a for a quick newb forum question. is FBO full bolt on? lol
      12-09-2015, 04:08 PM   #39
alexc93
Drives: na
To flash back to stock you'd have to send in to enzo again im pretty sure.
Yes FBO is full bolt on (downpipe, intake, front mount intercooler fmic, charge pipe) and sometimes people consider exhaust part of it too but catbacks show minimal gains on our cars.
      12-09-2015, 04:52 PM   #40
Luminous
Luminous's Avatar
743
I don't know where you live, but Enzo can flash your car back to stock via obd so if you swing by the shop it should only take a second.
Only work I had done at ACM was the turbo install, all other bolt ons were installed by Frank at Enzo's, really great guy. I would have done the turbo with them as well but they were a bit backed up and I'm too impatient to have the turbo sitting around in a box
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-09-2015, 04:57 PM   #41
ronanz
ronanz's Avatar
Just take it into service as normal. Flash tune is not detectable unless the dealer knows EXACTLY where to look within ECU...could be detectable if ECU is sent back to BMW tho.
Piggybacks are detectable as they have to direct connect to ECU, then be hidden.
      12-09-2015, 04:59 PM   #42
Luminous
Luminous's Avatar
743
I agree, if just routine service I wouldn't worry about it, I recently took my car in for warranty oil change and had no issues. If you're going in for warranty work I would flash back to stock just in case.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-09-2015, 11:04 PM   #43
jcruz3
jcruz3's Avatar
Drives: M235i AW
Originally Posted by ROBNYC
Originally Posted by jcruz3 View Post
great results! gives me an idea of where I'm at . loving the Enzo tune!
good luck on stage 2!
Get ready, Luminous SuperBran mge92 shivaswrath R32DBP Crashnbrn5 and I we'll be going for Dynojet soon .. to show the community all EnzoTuned Flash cars Numbers, with diff mods, and engines.
Can't wait for drag-season again !
Great numbers and thanks for providing the community with this info!
412/462 Dynojet on stock turbo with catted Dp on 93 EnzoTuned
vs
377/417 Dynojet 95 octane JB4 map7 catless Dp
359/400 Dynojet 95 octane JB4 map2 catless DP
when..and where...!?
      12-09-2015, 11:38 PM   #44
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
As do intakes
