02-06-2016, 11:35 AM | #573 | |
Rep 447
02-09-2016, 07:53 AM | #574 |
IG @bmwF9xG80
3813
Rep 7,593
moldcad I think the first post where AlexGT advices on where he puts it himself.
Also, on my N20 the only surge (too much boost) I felt was when you're running a bit high setting like in the 0-4 setting, but while I'm in C-F all is smooth. As a matter of fact, I flashed my car back to stock since I'm trading it in and decided to play with RaceChip + DP + S55 spark plugs and let me tell u, the delivery is WAY better due to the better plugs too. If you're going to run 93 or better octane and going to increase some more boost than default def try getting S55 plugs when your stock plugs need replacement. Cheers
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-15-2016, 10:25 AM | #575 | |
Rep 809
02-15-2016, 11:00 AM | #576 |
Rep 809
Two months ago, I started the car in the morning, went out my garage and like 30 seconds later of cruising driving (not hard btw), my screen showed an error that in English means: Propulsion, Drive moderately, cannot deliver full power. Schedule service check. And at the same time, the engine started to hesitate and literally there was no power when stepping on the gas pedal.
The same happened for like 3 other times (within 2 weeks / I don't daily drive this car), then it didn't appear anymore. But 3 weeks ago, I met with a friend to do a short road trip (he has an F80 LCI M3), at that time I really drove hard as you all can imagine. While driving, no error nor loss of power happened, but at that same day in the afternoon, I got the same error and loss of power while cruising at 40-50kms/h. From that day, I got that problem every single time I drove the car, regardless if I was driving hard or just cruising and it got worse, if in traffic, when I stopped, the transmission changed automatically to Neutral position and the car turned off. So, this Friday I drove again, got the error and loss of power (again), returned to my house, opened the hood, took off the RaceChip and went for a test drive. I drove the car very very hard, not a single error, no loss of power, then I cruised and no problems either. The whole weekend I used the car in traffic, open road, with automatic and manual configuration, no problems at all. I found this article last night, I guess I'm not the only one that have experienced this specific problem when using a RaceChip box, I'm glad that no one here has experienced that (I searched and found nothing here in 2addicts). http://sjuut.dk/?RaceChip Again, this is FYI for all you RaceChip owners. BTW, I tried to get comments from RaceChip guys, no response at all. |
02-15-2016, 12:21 PM | #577 | |
IG @bmwF9xG80
3813
Rep 7,593
Interesting article, and sorry to hear about the error. I hope you dont have BMS Intake. RaceChip-USA and Germany haven't responded?
02-15-2016, 01:23 PM | #578 | |
Rep 809
Anyway, I'm not installing back that thing on my precious car anymore, even if RaceChip replies, it is obvious that the box was the reason I was having those problems. No more piggy backs for me, RaceChip or any other brand. I'll wait for an ECU tuning that could be available without the need of sending the ECU. And no brother, I'm not using BMS intake, I have the Dinan carbon intake. |
02-15-2016, 04:11 PM | #579 | |
IG @bmwF9xG80
3813
Rep 7,593
Did this happen at the same gas station you've been filling up? Have you any TopTierGas.com in your country?
02-15-2016, 04:42 PM | #580 | |
Rep 809
The problem is the box, if it was the gas, I'd still have that problem. Either way, if the gas was the case, then RaceChip should advice buyers that their box will only work with some specific type of fuel Cheers man |
02-16-2016, 10:14 AM | #581 | |
IG @bmwF9xG80
3813
Rep 7,593
Contact the seller and have them replace your box. I believe there is a Racechip Guatemala Center no? I know they have one in Mexico (huge)
02-16-2016, 10:30 AM | #582 | |
Rep 809
But I do appreciate your concern and suggestions. I'm very practical when it comes to my car, if a tune is making me worry or giving me a hard time, off it goes. The M235i is a very expensive car here in Guatemala, I honestly don't have the money nor the guts to be "playing" with its integrity nor with the local dealership and all their "warranty" crap. In addition, I have way too much stress at work to be adding some more due to car tuning related stuff hehehe. I'll wait for an ECU tune when available in my country. |
02-16-2016, 02:01 PM | #583 | |
IG @bmwF9xG80
3813
Rep 7,593
I support whatever you decide to do Just for curiosity, did you inspect the box and cables and where it was installed (excessive heat) maybe?
02-17-2016, 07:34 AM | #584 |
Rep 809
02-19-2016, 09:08 AM | #585 |
General
12966
Rep 18,713
@ROBNYC and AlexGT I replied on the other thread.
Short answer, the limp mode is most likely caused by failing TMAP and/or MAP sensors by BMW.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-19-2016, 11:32 AM | #586 |
Rep 809
I already replied to you too, sorry, but until I get these problems again now that I'm running without the RaceChip, I will not believe that my sensors or any other component has failed.
02-19-2016, 11:53 AM | #587 |
Rep 447
It could very easily be a bad connector on the RaceChip or something failed in the box. Have you tried having it plugged in and using the dummy plug to bypass the unit. If you experience problems like this, then somewhere in the wire loop you've got a bad connection. If all is good, then the unit itself seems to have an issue with it's ECU or something inside.
If it's a bad BMW sensor then I think you're correct, it would should up all the time, not just when the unit is plugged in,
04-26-2016, 08:45 AM | #589 |
Rep 243
coming from an n54 motor that was tuned, try getting new coils. car untuned ran great, when tuned would misfire and all those issues you are describing. Brought the car tuned to the shop, and they confirmed the coils needed replacement.
06-09-2016, 05:45 AM | #590 |
Rep 182
Has anyone tried the Pro2 box instead of the Ultimate?
Almost half the price...
06-13-2016, 07:50 AM | #592 |
Rep 1,151
06-13-2016, 08:20 AM | #593 |
Rep 182
I has the pro2 on my E92 320D and it was brilliant.
Just wondering if there was a reason why 235i owners didn't go for the pro2...
06-15-2016, 11:28 AM | #594 |
Rep 1,151
So most seem to run C to F on the left hand dial...does anyone ever adjust the right hand dial that regulates the RPM range in which the Rc is active and deactivated... default is 1500-3500 rpm...every additional change increases it by 150rpm so im told by RC that you should not exceed 3 or 4??...this is on the pro2 which im thinking of getting in the next month
