2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum '16 m235i. Does it have Active Sound?
      12-18-2015, 09:54 AM   #1
Robimplicit
Drives: M2; 335d
Have had my m235i for just one week and like it very much with the exception of a dull drone most noticeable above 2800 rpm. Doesn't sound good. Seems to be there in both Comfort and Sport modes. I tried calling a few BMW genius lines but couldn't get definitive info as to whether or not the 2016 model year m235 has Active Sound installed. From other posts, it seems both 2014 and 2015 do. Can anyone say for sure?
Thanks.
-Robert.
      12-18-2015, 10:00 AM   #2
wjjkoevoets
Bright Sky
wjjkoevoets's Avatar
Netherlands
1164
Drives: BMW M235i (8AT)
2014 BMW M235i  [0.00]
Thanks.
-Robert.
I am not entirely certain, but from what I understand Active Sound was discontinued earlier this year and newer cars will no longer be equipped with it.
EDIT: Here's the thread discussing it http://www.2addicts.com/forums/showthread.php?t=1112018
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive.
Last edited by wjjkoevoets; 12-18-2015 at 10:06 AM.. Reason: Added link to thread.
      12-18-2015, 10:22 AM   #3
mocohead
mocohead's Avatar
54
Drives: '16 M235i 6MT & 12 128i Msport
My August build M235i has it.
      12-18-2015, 10:42 AM   #4
Zooks527
Well, I can say my 2015 did, but after spending $65 and investing under an hour of simple work, it no longer does. And I think not having it (more correctly, not having the constant drone on the highway) is wonderful.
Details and instructions here: http://www.2addicts.com/forums/showthread.php?t=1202389
      12-18-2015, 10:56 AM   #5
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
Thanks.
-Robert.
My MY2016 M235i which was a 7/24/2015 build date has it. Personally I like it, these cars are quiet, after getting to know the engine power curve, it aids in shifting manually at the optimum RPM. I don't hear much from it in Comfort mode, maybe the drone you are hearing is just the engine and exhaust. There is a rumble from the exhaust system too.
      12-18-2015, 04:39 PM   #6
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
I think it was removed from the 228's 328's etc...
Doubt they take it off the M235 or M4 etc
      12-18-2015, 06:38 PM   #7
BMWZ4
BMWZ4's Avatar
1910
Yep. My '16 (replacement for recalled ice storm) build date was Oct 5 and has ASD.
      12-18-2015, 08:43 PM   #8
Robimplicit
Drives: M2; 335d
2016 m235i Active Sound?
Yes.
Received a call back late today from the US Genius office. Guy said it looks like current model m235 does have Active Sound (he initially thought it was only in full M cars but agreed to investigate).
Looks like I may need to learn coding or insert the wiring harness at the module in the trunk.
Thanks for the input.
-Robert.
      12-18-2015, 09:18 PM   #9
TMatt
Drives: 2016 EB M235i
My 2016 m235i definitely has it. I too notice the drone, especially in sport mode. Getting it coded out soon.
      12-18-2015, 10:49 PM   #10
MUFCbmwbear
MUFCbmwbear's Avatar
Drives: 24 M2 & 20 M340xi
I have a 14 and indeed found it annoying on a recent Chicago-Sth Florida trip. Never had a beef with it until then.
20 M340xi White Mocha
17 340i/M235i/E92 M3/135i All 6spd
Chicago-Lake County-Milwaukee-Shorewood
      12-19-2015, 04:57 AM   #11
Zooks527
Yeah, for me, it was really apparent on an 8 hour drive from New England to DC.
      12-19-2015, 07:01 AM   #12
horsepower_and_hounds
Drives: BMW
So question,
The guys on the m3/m4 forums with HK audio are just unplugging the amp. on the M235 with HK is this possible without buying the $65 plug? Just curious...was think about trying it out to see if like it without investing the $
      12-19-2015, 07:35 AM   #13
Zooks527
Originally Posted by ehagerty View Post
So question,
Only as a test. We have the downrated hk system (no equalizer, etc.). Unplugging the ASD module removes the ASD but it takes the radio out with it. I tried that before I bought the cable.
So, for a "See if you like it" test, you can certainly drive the car with the radio off and ASD on to see what that sounds like, then unplug the module to see what removing the ASD is like without the radio. It's fine for a test, but not a viable long-term solution.
EDIT: Nah, that's way too much work to see if you don't like it. Pull the radio fuse. Same effect, and only 30 seconds of effort to try it.
      12-19-2015, 10:44 AM   #14
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
Even more so in the M235i ragtop..
2019 X2
      12-20-2015, 05:02 PM   #15
Drives: BMW
Good call on the fuse deal...... Thanks
      12-20-2015, 08:37 PM   #16
ParkerJarvis
ParkerJarvis's Avatar
Drives: 2016 BMW 228i M-Sport
Does this apply to a 2016 228i? I tried the "rev the engine to 2500k in park and toggle between Comfort and Sport" -- nothing. I don't hear any difference, and I don't hear a drone at freeway speeds.
      12-21-2015, 12:50 AM   #17
AlpsRider
AlpsRider's Avatar
2865
I don't hear ASD much in Comfort mode. If the concern is that Sport mode is too loud, you can change the Sport mode setting to chassis only, then with the automatic if you want it to have sport shifting just move the shifter to manual. Now you have full sport mode with Comfort ASD sound.
      12-22-2015, 10:10 AM   #18
todd hollander
Drives: X3 30i
EDIT: Nah, that's way too much work to see if you don't like it. Pull the radio fuse. Same effect, and only 30 seconds of effort to try it.[/QUOTE]
Which fuse is the radio one? TIA
      12-22-2015, 10:43 AM   #19
AlpsRider
AlpsRider's Avatar
2865
www.2addicts.com/forums/showthread.php?t=1164951
      12-22-2015, 01:25 PM   #20
todd hollander
Drives: X3 30i
Thanks! 122 it is. I have the AWE exhaust and it is wonderful. I'll bet even more so w/o active sound. I have emailed TechnicPnP and will probably purchase one when they become available.
      12-22-2015, 01:57 PM   #21
Y0tsuya
Drives: 2015 M235i 6MT, 2016 340i 8AT
Looks like a nice clean solution. My current solution is to stay in comfort mode where the droning is minimal, and use a pedalbox to eliminate the initial dead zone in the pedal travel.
      12-22-2015, 05:06 PM   #22
Zooks527
Use the "Contact" box on his website. He should get back to you within a day.
