11-16-2014, 05:20 AM | #45 |
Rep 321
I wanted the xenons, but my dealer had a leftover car that had been sitting a long time. It has the halogens on it. Honestly, I'm not disappointed in their performance, and only really miss the cool halo look.
What is disappointing to me is the fact that for $45,000 I don't even get projector lenses... |
11-16-2014, 09:47 AM | #47 |
Rep 272
The only reason I got the xenon lights was for the LED angel lights.
I felt it was kind of ridiculous to drive a premium modern car with an outdated daylight driving light. I don't drive much during night time and BMW standard halogen lights are actually pretty decent. The xenon lights are brighter but it doesn't really mean you can see better |
11-16-2014, 09:57 AM | #48 |
Rep 6,028
My first car with Xenon and I don't think I will ever go back. I haven't assessed the specific different in range of illumination, but there is a white crispness to the light which gives me the subjective feeling of seeing better, further, wider. Also, the turning feature is very helpful. Don't care much about the DRL rings about the headlamps which light up....just another appearance fad like Audi's design. The data I've seen on DRL is not persuasive as to their value, as most of the work was done in Canada where dusk/dawn hours are quite different. And, when the sun sets, the automatic headlamp feature does the job.
11-16-2014, 10:26 AM | #49 |
Rep 272
While xenon lights give whiter and appeareance of extended range coverage they do not provide more contrast information.
This has to do with human eye different sensitivities at different wave ranges. You can easily test this with different LED flashlights with different color temperature pointed at text on white sheet. It is easier to read text with LED flashlights with lower color temperature than those with brighter light with higher color temperature. |
11-16-2014, 10:30 AM | #50 | |
Rep 6,028
11-16-2014, 10:37 AM | #51 |
Rep 272
Xenon light does have one advantage of providing more even coverage (in addition to the added adaptive feature) due to use of projector lenses.
11-16-2014, 10:45 AM | #53 |
Rep 272
11-16-2014, 11:54 AM | #55 |
Rep 6,028
11-16-2014, 03:56 PM | #56 | ||
Rep 755
Drives: '14 228i
That said, Consumer Reports (which I believe performs objective tests on headlights) rated the xenons quite poorly: Quote:
However, they didn't compare the xenons to the halogens, so it's not clear whether the halogens would be even worse. They also didn't specify whether the distance was poor with the low beams, high beams, or both. If it's just the low beams, it may be an adjustment issue. Subjectively, I find the low beams pretty good and the high beams absolutely brilliant. I definitely prefer them to my E90 328i, which also has adaptive bi-xenons. The adaptive feature itself is probably only marginally useful, but it's certainly fun. Even if the xenons don't provide a huge benefit in terms of safety, they sure do make the front end of the car look better and more modern.
2014 228i
alpine white | sport line | 6-speed manual | lighting package | driver assistance package interior - black Sensatec | aluminum & red trim |
11-16-2014, 04:58 PM | #57 |
Rep 272
One of the drawbacks in using projection lenses is sharp drop off in illumination outside the projected area.
I believe that is what Consumers Reports was pointed out. I don't drive much a night time but I do see a much bigger illumination cut off at top on my 228i when projecting light to a wall in comparison with other cars I've driven with xenon lights. Having this much light cut off is a disadvantage for seeing objects outside projected illuminated area as your eyes have beed adjusted to brighter illuminated area. |
11-16-2014, 08:12 PM | #58 | |
Rep 755
Drives: '14 228i
2014 228i
11-16-2014, 08:22 PM | #59 |
Rep 835
I had the halogens on my first BMW and I immediately replaced the DRL rings with LEDs and lived with the halogen at night. I didn't make the same mistake this time around, the brightness of the rings are 5x better than anything aftermarket and they just complete the look of the modern BMWs. The visibility is increased by 5x as well, I can see everything now and with hi beams on it might as well be the afternoon. It's impossible to see in the rain with halos or xenons, its just shitty driving conditions so to me thats a wash. Also they will not go out nearly as often despite being more expensive to replace, but I wouldn't plan on having that problem for 5 years.
The effect they have on resale value is huge, people want a used car that looks like a new one, so there you go. Safety is always important so there is that and they look amazing if its me I would trade tech for xenons, yea i said it.
2020 X3M Comp., Alpine White on Black/Beige
RETIRED: 2018 440xi GC, Carbon Black on Black/Blue 2014 M235i Black on Black, DINAN Stage 2 |
11-16-2014, 09:42 PM | #60 | |
Rep 2,527
Drives: 2011 328i Wagon
The resale argument is only valid for people who failed math in the 3rd grade. You spend $1200 to get $600 more when you sell the car.
11-18-2014, 12:41 AM | #61 | |
Rep 835
11-18-2014, 05:46 AM | #62 |
Rep 1,077
ive got xenons on my car and made sure to get them.
logically there is no reason to get them. i mean i have excellent night vision (They are really bright though), so i'd be fine without them (helps being partially colorblind). that said they look cool. they should just be standard. if you don't care how they look then save the $1000, because personally i think the main reason to get them is they look cool (and yeah i'd get them every time). its probably the one cosmetic thing i'd always get. that and well some sort of sports package on a bmw. |
11-19-2014, 01:39 PM | #64 |
Rep 14
Stuck with halogens
Hey guys, I was on the fence about the lights since it was a pretty hefty price. and when the car came, I immediately regret not getting the LED. does anyone know if I can get them aftermarket? and any website that might have them? I dont even like the plain non angel eye look of them during the day. So can even the plain angel eyes without anything else would be awesome? If anyone could lemme know
11-19-2014, 02:18 PM | #65 | |
Rep 33
