09-29-2020, 10:31 PM | #1 |
Rep 311
Highest mileage?
So let’s hear it. It’s been a few years since this was asked over on the 3 series forum, if I’m not mistaken. Just checking in to see if there are any high mileage 220’s/228’s out there. If so, how goes the N20 journey?
I’ve all but decided that this engine, unless heavily internally modified, should probably remain untuned as I’m in it for the long haul. But no issues here at 48k. Hoping for some good news...!
E34 525iT 5 spd | 228i ZTR 6 spd [SOLD] | MX-5 NA 6 spd |
09-29-2020, 11:28 PM | #2 |
Rep 43
46K here, 08/14 build MY '15...no issues and love this car. Put on about 20K miles after 1 year of ownership (100 mile commute), with 5K oil change intervals. It may be naïve but this has given me peace of mind so far when it comes to the N20
Current - '15 228i
10-27-2020, 07:18 AM | #3 |
Rep 922
Drives: '21 F87 M2C 6MT
Garage List 2015 MINI Hatch 5-door [0.00]
2021 BMW M2 Competi ... [9.67] 2023 BMW X5 xDrive40i [0.00] 2017 BMW X3 xDrive28i [0.00] |
MY'15 with 82K miles. no issues whatsoever. probably the best car i've owned in 35 years of driving and owning cars.
my garage: '23 G05 xDrive40i m-sport; '21 F87 M2C, 6MT; '17 F25 x-drive28i SAV; '15 F55 mini hatch 5-door retired: '87 E30 MT 'vert; '92 E36 sedan; '99 E36 MT 'vert; '06 E90 x-drive sedan; '07 E83 x-drive30 SAV; '09 E91 x-drive wagon; '12 E89 Z4 MT M-sport; '15 F22 sport line |
PeanuKeeyes365.50 |
10-29-2020, 03:53 PM | #5 |
Rep 286
57k, MY14. Fuel pump replaced in 2015, thermostat replaced in 2019. That aside, car has been rock solid. As OP sstated, with no modifications and proper maintenance these engines are reliable. Well what about the dreaded timing chain failure?... if you dont use the start/stop function and dont wait till 10k to change your oil then im pretty sure you will be okay.
11-01-2020, 06:19 PM | #7 |
Rep 380
2016 45k stock drivetrain. Second owner but had my mechanic check thouroughly. All good so far. Only issue I have had is the ac stopped blowing cold on a long trip. Hasn’t happened again, but haven’t taken it on a long trip. Not a DD.
11-03-2020, 08:35 AM | #9 |
Rep 736
Drives: Lexus RC F
I heard that is normal on long distances with ac, I guess it's like a defrost cycle.
Estoril Blue E36M3
aftercorbu404.50 |
12-30-2020, 06:49 PM | #10 | |
Rep 351
12-30-2020, 06:54 PM | #11 |
Rep 351
I'm at 80k. no major issues, just kept up with the maintenance to prevent grenades!
auto tensioner and belts (2x) water pump and thermostat 6mt fluid diff fluid ofhgs spark plugs each oil change due to tune (add coils next oil change) O2 sensor did fail, replaced no issues. looking for another 80k out of her! been running jb4 with charge and downpipe for about 30k. no issues there! |
PeanuKeeyes365.50 happyjack1657.00 |
04-07-2021, 08:37 AM | #12 |
Rep 9
I'm at 52k and had a major brake module failure. Bmw had to do the repair and ship in the part from Germany. It was 5400$
Other than that, no issues. But that one really hurt. |
04-07-2021, 09:33 AM | #13 |
Rep 105
Just got to 57k and having the car serviced early tomorrow because it gets driven hard daily. I blew a coolant pump at about 28k; around $3,000 in repair, and also had to have the parts shipped from Germany.
Any things I should look to have replaced or upgraded? |
07-04-2022, 10:58 PM | #14 |
Rep 311
Rapidly approaching 70k now. Still zero issues. Who’s got the high miles?? Don’t be shy
07-05-2022, 01:12 PM | #16 |
Rep 311
did you have an oil pan leak, weeping or just preventative? Every time I tighten that plastic drain plug after an oil change I cringe. aluminum pan mod in my future.
07-05-2022, 05:15 PM | #19 |
Rep 2
2015, 70k. New engine, cpu, turbo, waste-gate, intercooler. All covered under warranty at 45k, ultimately to replace the cat which had fouled after 2 injectors had failed.
07-06-2022, 06:59 AM | #20 |
Rep 922
i need to get the exact mileage from my daughter -- who has taken over the car as primary driver -- but it's over 92K miles on MY2015 228ix. we've really had no issues with the car...other than regular maintenance, it has only blown the charge pipe gasket / seal.
it's been my favorite car that i've ever owned and was the primary reason that i upgraded to an M2C.
08-29-2022, 12:21 PM | #21 | |
Rep 1
PeanuKeeyes365.50 |
08-29-2022, 12:52 PM | #22 |
Rep 311
That’s great news, 100k is an accomplishment. I’m up to 74k now and I recently had the shift shaft seal done and a new belt and idler pulley. That’s literally it though.
