2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Seatbelt issues
      06-24-2016, 11:57 AM   #1
Teambaylagoon
Drives: 2016 BMW M235i
Seatbelt issues
Driver side seatbelt is twisted.. I though it was the clip was flipped, so I flipped it back, now I realize its the belt itself thats backwards, I assume inside the pillar but not sure how I can fix this... any easy way to get in there ? Should I just have the dealer do it ?
Also it doesn't retract with some "assistance"
      06-24-2016, 02:43 PM   #2
dcfella
Drives: 2015 M235i
Had the same issue last week. I tried to twist it back into position myself, but didn't work so I just took it to the dealer and had them fix it for free since it's under warranty.
      06-24-2016, 02:51 PM   #3
yatesfloyd
Drives: 2016 BMW 228i
I got pissed off and jerked it around a lot until it fixed itself but I don't know if I would do the same.
      06-24-2016, 04:27 PM   #4
kz1000
Mensch
kz1000's Avatar
60
Drives: 2021 230i 6mt
Dealer fixed mine 3 times before they gave up and replaced it. Not before the buckle poked a hole in the seatback so they had to replace the seat cover too.
      04-08-2017, 03:31 PM   #5
charethcstory
Drives: 2019 X3 M40i
Older thread I know, but I've had this same issue. My seatbelt has gotten tangled/twisted and turned around backward inside the B-pillar 3x in the 10 months I've had my car. Each time I take it to the dealer and they fix it in 30 min or less. They say it is just a "design flaw" and they can't do anything other than untangle it when it happens. I find it concerning that they can't/won't do anything more when it is a safety issue. There have been times when I've driven around for a week with no seatbelt because the belt is pulled so far out that it wouldn't keep in my seat and it won't retract. Any ideas or experiences with this?
      04-08-2017, 05:13 PM   #6
harma24
It happens to me frequently. I wish I did have some ideas, but unfortunately I've got nothing for you.
Family Cars: 1993-2014: 1993 Honda Accord 10th Anniversary Edition | 2014-Present: 2014 Honda Odyssey
Stable-mate: 2019 - present: 2020 230xi Seaside Blue Convertible
      04-09-2017, 12:04 AM   #7
moldcad
moldcad's Avatar
Poland
260
Happens all too often here, as well!
Piotr
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive
my AWD beater: 2015 Golf R mk7 DSG
my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD
      04-09-2017, 03:05 PM   #8
3rdcoast228i
Drives: 2016 228i Msport
I had this happen to me both times I went on test drives before I bought my car, and it hasn't happened since. I was able to fix it my self fairly quickly both times. I wasn't sure I was able to fix it at first, it just took a little bit of patience.
I'm not sure what caused it to do that, but I have a felling it has to do with how you let it go back into the piller.
      04-10-2017, 09:32 AM   #9
Maynard
Drives: 228iX & M2C
I fussed with mine the other day when it was wanting to tangle up; at the time thinking 'am I making too big a deal out of this' but it seemed to be really ready to jam up. Seeing this post, I'm glad I didn't just let it sort itself out. If I let it go quickly, the whipping around seems to make it want to loop back on itself and jam. If you can, ask the dealer what they are doing to fix it, and post the info.
      04-11-2017, 08:28 AM   #10
Sypher
Drives: '16 228i xdrive
Mine does the same thing. The only way around it so far that I've found is to slowly release it and guide it back it. It's been super annoying. Would love to hear of any ideas or solutions if anyone has any.
      04-11-2017, 09:08 AM   #11
shil
Huh? Wazzat?
shil's Avatar
Drives: 228i xDrive
Exactly that.
You have to slowly guide the belt in nice and flat, or it folds back on itself and jams in the slot.
Or the foldover gets though the slot and it's stuck on the inside.
Then everything looks fine, but the clip's flipped and there's a twist in the belt.
You've got to brute force the fold out of the slot.
It's just a bad design.
      10-17-2018, 02:39 PM   #12
john32443
Drives: 128i
I have this issue and my car is under warranty...BMW Markham says it's not covered under warranty because nothing is broken. They want me to fork over 300$ to fix it
      10-17-2018, 07:02 PM   #13
714_2er
714_2er's Avatar
108
Drives: 2015 AW M235i
Had same issue about a month ago.
Was able to fix it myself, just have to play with it a little
Retract he belt almost all the way, make sure the buckle is facing right direction, straighten it out and follow beltntonentrance of pillar, you then have to kind of bunch it up to one side (side protion of slit) try to fold it over on itself in the correct direction and pull(hard) belt back out.took me a few tries but it worked eventually.
      10-20-2018, 03:18 PM   #14
redcars
Drives: 228xi
If it jams and it won't retract, grab it where it goes into the B pillar. Pull rearward and slightly down. It should free up so you get the fold out.
