05-19-2017, 03:31 PM | #1 |
Rep 24
Steering Wheel
Anyone else's M-Performance steering wheel (stock on M235 and M240) making a lot of noise? Not the column, but the actual plastic itself. Lots of creaking / cracking anytime I turn the well / pull on it / etc etc.
Update: A lot of the noise seems to come from the middle / bottom part (where the M logo is). But it's also pretty prevalent wherever the plastic parts are on the wheel. |
05-19-2017, 03:54 PM | #2 |
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
I had the same issue when they changed my steering wheel for the first time. There should be a screw or nut there behind the logo, you can try to tighten it
05-19-2017, 07:00 PM | #5 |
Rep 610
I think the problem is that they designed it to come apart easy so the covers can be changed out. Its a compromise to be able to customize the steering wheel.
I find that mine doesn't make noise if I dont touch the plastic. Even if I do, it's not that loud. I hope they do improve it though, being that this is what you touch the most, it should feel more soild. |
05-19-2017, 09:34 PM | #6 |
im a car
734
Rep 1,117
Drives: 220i M Sport | 520i M Sport
My steering column cover(s) rattle quite a bit over rougher roads
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
05-22-2017, 01:37 PM | #8 | |
Rep 102
The simple fix is to tighten the screw behind the steering wheel. If you find that it's still making noise after tightening that screw, then you need to tighten the other two screws that hold this entire piece together. To get to those other screws you need to remove the airbag. It's not hard at all. You just need to disconnect the negative end of the battery and proceed with steps 1-3 in the thread below. In step 2 you don't even have to unplug anything since you'll have access to the two screws you need to tighten. Just simply tighten the two screws and the push the airbag back into place and your done. Mine was squeaky before I installed my M Performance Electronic wheel and tightening these three screws took the problem away. http://f80.bimmerpost.com/forums/sho....php?t=1204092 |
DrunkPandaBear8.50 xojustin22.00 |
05-23-2017, 11:52 AM | #9 | |
Rep 24
05-23-2017, 01:53 PM | #11 | |
Rep 24
First time they over-tightened that middle screw to where the noise was even worse and you can tell it was over-torqued to where the pieces almost overlapped instead of being flushed (if that makes sense). Took it back again and was met with the response of "We tested the steering wheel on other 235/240's and they made the same noise so this is not an issue / everything is working normal". |
05-23-2017, 03:33 PM | #12 | |
Rep 102
Why take it to the dealer and spend 1-2 hours of your time for them to come back and tell you that there's no problem, or even worse, for them to make some other part start squeaking because they don't know what they're even looking for. This is a 10-15 minute job at most. I know it sounds very daunting taking the airbag out, but it's a very simple job. The hardest part is probably disconnecting the negative cable from the battery! Which reminds me... don't close your trunk once you disconnect the battery. Keep it open fyi! |
05-24-2017, 06:50 AM | #13 |
Rep 275
I don't mean to hijack the thread, but I've never spent 1-2 hours at a dealer. If I bring a car in under warranty for any reason, I request a courtesy car and they are happy to give me one. My take is that BMWs are expensive and we deserve our asses kissed.
Tags |
cracking, noise, steering wheel |
