05-17-2017, 08:00 PM | #45 | |
Kingslayer
411
Rep 1,479
Did a launch control take off from a light without warning the wifey - she got whacked with the headrest on 1/2 & 2/3 shifts. I thought it was funny, her not so much.
BarryJI423.50 |
05-17-2017, 08:22 PM | #46 | |
Rep 5,262
05-18-2017, 12:48 AM | #47 | ||
Rep 980
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
05-18-2017, 10:26 AM | #48 | |
Rep 5,262
It's easy to try.... put the car in Sport mode and leave stick on the right....go a speed that puts you in say 3rd gear at constant throttle and punch it without going into kickdown and see what it does.... then stay in Sport mode, push the shifter to the left...(wait a little bit till the car upshifts back again to 3rd) maintain throttle and then punch it again... you will see it will downshift to the same gears and shift at the same times... |
05-18-2017, 08:01 PM | #49 | ||
Kingslayer
411
Rep 1,479
05-18-2017, 09:29 PM | #50 | |||
Rep 980
05-18-2017, 09:54 PM | #51 |
Rep 5,262
I doubt it... THP is just basically an M235 without the N55 engine...
They wouldn't make that kind of software differences just for a package where in no other car the transmission in DS has no effect in Sport or Sport+ as the drivetrain (engine and transimssion) is already in Sport.... There are not 3 automatic modes for the transmission... it's just normal and D/S... But this kind of stuff it's hard to empirically probe... you would need to measure G force in both cases at the exact same speed an acceleration... If he thinks D/S does make any difference in Sport... so be it... |
05-19-2017, 09:05 AM | #52 |
Rep 2,870
Isn't there also a setting where you can specify what gets altered by the sport settings? Could it be that the noticeable difference is when you have it set so that Sport only affects chassis/throttle, and then the tranny selector would be altering the trans? BarryJI and xantdieselx - have you guys checked if you are set to have sport alter all 3, or just the chassis/throttle?
Personally, this aspect of the cars is still puzzling (when adding in the eLSD, DSC on/off, etc). That chart is helpful, but from a 3 series and some say not exactly what we have in the 2's. It is tons of fun blasting away trying to figure out what got changed, but sometimes wish it was a little simpler to set up. |
05-19-2017, 05:52 PM | #53 | |
Rep 5,262
Drivetrain and chasis Chasis only Drivetrain only So basically throttle response, transmission programming and increased sound is all bundled together into the drivetrain option. The only case where stick to the left would made a difference is if you set sport to "chasis only" cause in that case trans is in comfort mode But he said he feels the same in sport+ and there is no way to configure sport+, it's always drivetrain and chasis + DSC ON |
Maynard3833.00 |
05-20-2017, 01:25 PM | #54 | |
Rep 17
I know, controversial subject (not trying to derail here nor argue proper ways) but I think this is very relevant for your situation, especially for your geographical location. For me I did not exceed 4500rpm (ahem cheated a few times) and drove it to about 2000kms in manual mode all the time with a lot of half throttle action and a lot of engine braking which I heard was great for obtaining a good piston ring seal. The world is pretty flat where I am though. I was forced to do about half that on highway mileage but mostly at night with very little traffic so I could easily vary the engine RPM and load which it is important as well not to drive at static speeds or loads for extended periods of time. If you are past that honestly I would not worry about it too much. if it were me I would definitely be downshifting for a steep incline but steep declines I would be a little more careful and stay away from a high rpm downshift. I personally never worry about brakes. It is not an egg and meant to be driven too. Hope this helps Gabbby. Enjoy the new car! Last edited by Amiliaus; 05-20-2017 at 01:46 PM.. |
Gabbykat22.00 |
05-20-2017, 02:15 PM | #55 | |
Kingslayer
411
Rep 1,479
05-20-2017, 06:58 PM | #56 | |
Rep 80
I think for about two days in the first week, I played around with the gears and Eco mode. Even with the auto engine shut off deactivated, I don't like eco mode. It was just odd to hear from the BMW delivery specialist that I should just leave it in the whichever mode and not manually shift on my own. What is the point of having the options?! I am confused when people talk about pushing it to the red line or even to 5000 rpm+. I haven't had to go beyond 3000 rpm and I don't think I drive like a granny. I can see/hear that it is automatically shifting and the rpm goes down. Where are people driving? And how fast are they going? It is my daily car but I drive in the city, max 30 mins to work and once I was stuck in traffic for one hour. In the last 3 weeks, I have racked up about 320km. Tomorrow, I plan to drive over the border but from what I remember, the roads are always under construction so it will not be a constant speed for Long. Good to know about cruise control though. I prefer to vary my speeds on the freeway and I'm looking forward to pushing it in sport mode. I think the varying speeds makes sense. Looking online, a lot of people suggest agressive break in but I think I will be conservative with the break in. |
05-20-2017, 09:48 PM | #57 | ||
Rep 5,262
So moving the shifter in sport (assuming is configured for drivetrain or both) does nothing but downshifting one gear momentarily . You can try this. Go to sport mode and move the shifter also to the left. Drive for a 1 minute at normal speed, next move the shifter back to the right. What happens?? The answer is nothing cause the shifter program is still in sport cause the driving mode is in sport |
05-21-2017, 11:30 AM | #58 |
Rep 830
I do understand that there is no difference vs sport mode and gearshift in "s" when sport mode is defined with drivetrain settings. What I do notice though and if only in my imagination that in sport mode and gearshift in "s" I have noticeably more burbles with my MPE than when just driving in sport.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
