05-13-2017, 11:50 AM | #23 | |
Rep 2,010
So yes, in this example, the engine is adding some braking, along with the brakes themselves. To me, it all seems to fit together quite seamlessly and makes spirited driving enjoyable. The car seems to know what I want, then delivers. Quickly.
05-13-2017, 05:39 PM | #24 |
Rep 80
What about long descends?
Would it still be wise to downshift for a 45 min downhill? I'm thinking of a road trip and remember there are some mountainous regions going from BC to CA.
05-13-2017, 06:09 PM | #25 |
Rep 980
You have eight gears to choose from. Just select one that stops the car from running away without constant use of hard braking but which doesn't over-stress the engine. Personally, I wouldn't want to exceed 4000 RPM for very long. With an 8AT there has to be a "sweet spot" where you can keep both the car and the engine from over-speeding without over-taxing either the revs or the brakes.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
05-14-2017, 12:52 PM | #28 |
Rep 518
The amount of misinformation in this thread is mind boggling.
No, S mode is more a more aggressive shift mode where it tries to keep you in the higher rev ranges (where the powerband is) rather than D where it shifts to a higher gear to save gas.
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
05-15-2017, 10:54 AM | #30 |
Rep 117
Yeah, and now someone is probably going to go off a cliff somewhere after heating up their brakes from trying to keep speed going downhill for 45 minutes because he didn't want to "drive it like it's 1698 [???]". There's a reason why they check the temperature of your brakes in mountains.
05-15-2017, 11:21 AM | #31 |
Rep 980
Two completely different things. The Eco/Comfort/Sport/Sport+ settings affect drivetrain, suspension and steering functions. They do not influence gear settings.
05-15-2017, 11:39 AM | #32 |
Rep 1,931
i always downshift when braking, old manual habit.
www.nybmwcca.org
05-15-2017, 01:02 PM | #33 |
Rep 275
The Eco/Comfort/Sport settings absolutely do affect gear settings. In fact, driving in sport+ will prevent the transmission from shifting into 8th gear automatically, and other shift points are also affected.
05-15-2017, 02:55 PM | #34 |
Rep 1,931
also sport+ will hang the current gear at a high rpm were the other modes would auto change into the next gear.
www.nybmwcca.org
05-15-2017, 03:25 PM | #35 |
Rep 831
Sport will do the same, i.e. there is no difference in throttle response between Sport and Sport+.
Hoc Lapidem Non Vi Sed Saepe Cadendo!
05-15-2017, 03:53 PM | #36 |
Rep 623
Shift points seem about the same rpm with sport+ compared to sport+ and the shifter in S
Much as I'd like to be able to make my car even more fun to drive with a simple gearstick click, it isnt necessary to do this? I know that to launch you need sport+, shifter in S and traction disabled. |
05-15-2017, 04:19 PM | #37 |
Rep 5,262
05-15-2017, 05:14 PM | #38 |
Rep 1,931
wrong.
www.nybmwcca.org
05-15-2017, 09:33 PM | #40 |
Rep 831
The map shows that throttle mapping is the same in sport and sport +...
05-16-2017, 10:01 AM | #41 |
Rep 1,931
Hold at redline and kick down are different which is exactly what i said.
www.nybmwcca.org
skidplate21.00 |
05-16-2017, 01:48 PM | #42 |
Rep 831
Peace
05-16-2017, 05:20 PM | #43 |
Rep 556
Well, That's a great chart, but I wouldn't use it as gospel. Kudos for the owner doing such extensive testing though.
In my 2016 (as opposed to his 2014) I've found that with the DSC off and in DS sport shift mode the shift RPM, kick-downs, shift-speed, and exhaust burble are as aggressive or more so than in Sport+ mode. One of these days at a club meet we're going to do a side by side comparison. I know Anthony235 thinks I'm crazy, Ok he knows I am... but I can still have a somewhat valid point!! |
05-16-2017, 05:26 PM | #44 |
Rep 1,931
dsc off does not have same throttle response or burble as loud as in sport or sport +. dsc off is comfort throttle mode.
I have no muffler with a catless DP, very easy to tell the difference in sound. the m2 burbles louder when you when you hit the dsc button for some reason, not our cars.
www.nybmwcca.org
