03-11-2024, 03:42 PM | #1 |
Rep 43
How do you access the B58 oil filter cap more easily?
03-11-2024, 03:54 PM | #2 |
Rep 2,200
You need a 6-point 32 mm socket to use with an extension & ratchet, from a big-box parts store or:
https://www.bimmerworld.com/Tools/BM...mm-Socket.html Did you source a new cap? You can put your VIN in at realoem.com to find the BMW part # and shop with that. Good luck! https://www.realoem.com/bmw/select.do
qlaval52.50 |
03-11-2024, 05:00 PM | #3 |
Rep 1,798
A socket U joint helps with the oddball angle too. Just be aware of not over torquing or under torquing if using one.
harma24402.50 MarcoZandrini445.00 |
03-11-2024, 08:26 PM | #4 | |
Rep 744
And a baseball bat to beat the guy who designed it like that.
qlaval52.50 |
03-13-2024, 01:35 AM | #6 |
Rep 43
freakystyly3007.50 |
03-13-2024, 02:29 PM | #7 |
Rep 2,200
25 Nm is not much more than hand-tight - it's not a wheel bolt! But someone working on it previously could have put the grunt force on it, making it more difficult for you to remove!
A proper-fitting socket & the shortest extension you can get away with should be all you need. |
