09-06-2014, 02:06 PM | #45 |
Rep 678
I had to create an account and crap to ask the question. Went ahead and registered my intake since I created the account. I'll keep you posted on their response.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold |
09-09-2014, 03:14 PM | #46 |
Rep 678
No response from them and its been well over the 48hrs they claim they will respond by. Hope they have better support for more technical related issues like with their tuner device.
09-11-2014, 06:14 AM | #48 |
3441
Rep 79,211
09-30-2014, 08:31 PM | #49 |
Rep 5
Sorry nobody got back to you about the flow.
Let me explain it for you: 30-10226 is a OE replacement filter. It fits directly into the OE air box. It flows 528 cfm at 1.5"H2O by itself (not inside the air box). OE filter flows 410 cfm at 1.5"H2O by itself 54-82202 is a full intake system that replaces the the OE air box, tube and filter. It flows 205 cfm at 1.5"H2O. OE intake system (air box + tube + OE filter) flows 150 cfm at 1.5"H2O. So you cannot compare the flow of the filter by itself versus the full intake system. The OE replacement filter doesn't outflow the full air intake system, it's just different test set up. Let me know if you have additional questions Christian |
09-30-2014, 08:42 PM | #50 | |
Rep 5,262
If you were able to measure the stock box, you should be able to do the same with the stock box and a drop in filter right?... mmmm.... if the stock box flows 150 and the OE filter by itself flows 410 and the drop in flow 528 by itself.. I guess the drop-in inside the box should flow around 193 cfm So i guess 150 (stock) - 193 (drop-in) - 205 (full intake) ... not much improvement in flow from the drop in to the full intake...? am i correct? Last edited by pikcachu; 09-30-2014 at 10:46 PM.. |
09-30-2014, 09:17 PM | #51 | |
Rep 678
I'm sure more questions will pop
09-30-2014, 09:20 PM | #52 |
Rep 5
Please also accept our apologies on that, we just found out today there was an error and these requests have not been hitting the intended targets for answers. This is being fixed.
10-01-2014, 07:14 PM | #53 | |
Rep 5
Customers are typically either in one of two categories when considering performance products, just wanting a better flowing OE filter with lifetime warranty and the ability to clean it, or are looking for a more substantial performance product like an full intake system that will change sound, have a much stronger impact on performance, etc. I don't think taking percentages of the OE-sized comparison and applying it to the intakes will necessarily be accurate, but we do not currently have the data you're asking for. There are a lot of other benefits to replacing an OE filter with an aFe filter, but most of the flow restriction is in the OE airbox design. |
10-01-2014, 10:40 PM | #54 |
Rep 5,262
I see... thanks for the explanation...
I still think it would be beneficial if you could include in the future do the test of the drop-in filter inside the OE box..... if it can be tested with the OE filter, testing with the drop-in should be very simple, just replace the filter and re do the test... despite sound, is there any other variable apart from flow that will increase the performance between the full intake and the drop-in in the OE box ? I could think temperature but both are using a box so air is coming from the outside of the car in both cases so temperature should not be a factor... |
10-01-2014, 10:55 PM | #55 | |
Rep 5
OE's in almost any instance, still develop vehicles (even performance or specialty models) with the general public in mind. We have a LOT of female customers who are as proud as any males, but most performance BMW's (we can agree on) are purchase by males, and most their daily driver, and BMW knows this, and will make concessions on performance to reduce sound. To control NVH (noise, vibration, harshness) they measure everything in a lab to try to appease everyone, not necessarily extracting all of the airflow and performance. We at aFe have the ability to strip those concessions, to 3D scan the engine bay, look at all of the space available, build an intake based upon the filter size we can, develop a new intake box to accommodate the increased size, and take advantage of what is possible, and increase airflow in the intake tract, which also lets the engine breathe and sound awesome. |
10-03-2014, 08:33 AM | #56 |
Rep 809
10-03-2014, 02:03 PM | #57 |
Rep 678
I see it as some low hanging fruit that based on the limited data I have seen seems to help torque in particular. I would do it again for the slight increases and its a 15 min swap.
10-03-2014, 04:14 PM | #58 |
Rep 809
I appreciate your response G, very useful, I'm more interested on this one you got (the closed one) rather than the open. So, no heat soaking with the enclosed model right? Sometimes I have to drive with heavy traffic and want to avoid the intake soaking very hot air. Thanks again!
10-03-2014, 09:22 PM | #59 | |
Rep 678
I believe AFE makes both types, it would be interesting if they could chime in on the subject.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold Last edited by G-Mann; 10-04-2014 at 05:18 AM.. |
10-04-2014, 12:23 PM | #60 |
Rep 3,406
Yep...there ya have it. Someone on the Internet who has tested every single aftermarket intake available for the past 30 years and has been an engineer for 39 years says they don't work.
I'm taking his word for it. |
10-04-2014, 01:59 PM | #61 | |
Rep 5,262
No idea if the fact they were tested in different conditions was intentional or not so you can't easily compare one to the other...but i'll give them the benefit of the doubt... "So i guess 150 (stock) - 193 (drop-in) - 205 (full intake) cfm" so $75 for the high perf drop in and $400 for the full intake... to me seems like drop-in is the way to go but although I'm an engineer, I'm not an aerospace one to me 10 more cfm don't think it's worth $300 at least for street driving... |
10-04-2014, 03:03 PM | #62 | |
Rep 678
I have seen a couple real world dyno's with the AFE closed box and perhaps not the most ideal tests, the results show positive gains, particularly torque numbers. The OP got 8rwhp and 25rwtq I just don't see a drop in netting these kind of results but 5rwhp and 20rwtq would make the drop in pretty damn appealing for the simplicity of it but i just don't see a drop in netting much of anything these days. I've also seen dyno results where a drop in actually resulted in loss of hp and torque, not to say that is the case here.
10-04-2014, 09:36 PM | #63 | |
Rep 5,262
10-05-2014, 08:08 AM | #64 | |
Rep 678
My DP arrives this week to add to whatever I picked up from the AFE, could not pass on the shiftech deal. Will also go map 2, can't wait.
2022 M4 Comp X 2021 M440ix - Sold 2015 M235 - Sold Last edited by G-Mann; 10-05-2014 at 08:24 AM.. |
10-05-2014, 11:27 AM | #65 |
Rep 5,262
I wish we had a dyno comparing the drop-in afe against the full afe intake...
I dont' think there should be much difference between drop-in and full intake from the flow numbers... i mean apart from temperature and flow...i don't think there is anything else affecting perf but no airflow engineer |
10-28-2014, 05:46 PM | #66 |
Rep 37
Hello Folks,
I ordered and installed an aFe Magnum force air filter. I noticed that the factory ram air vent is left open to the engine bay area. When cruising at highway speed, there is a considerable amount of air noise coming into the cabin. i took it out and reinstalled the factory intake and the noise is gone so i am fairly sure it is the aFe filter. Can anyone confirm the same noise? Thanks |
