OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED** |
02-23-2018, 02:07 PM | #45 | |
Rep 190,805
I would not worry about them telling you to go pound sand
JP's M2xx20.00 |
02-23-2018, 10:43 PM | #46 |
Rep 26
Here's the updated power curve. It appears my settings were off. https://network.perfexpert-app.com/results/PEBSMH7QOO
02-23-2018, 11:52 PM | #47 | |
Rep 103
02-24-2018, 02:14 PM | #48 |
Rep 190,805
I have not seen any graphs with E30 ... If you already have the AA flash, let AA know and they can send you an E30 map to try
02-24-2018, 03:36 PM | #49 |
Rep 103
What about running it as a BEF with JB4 like the MHD? Could you then adjust power levels with the JB4 and have the AA running in the background creating a higher smoother baseline power curve? I would like to keep my JB4 for a lot of reasons, but I'm finding it a bit hard to get consistent smooth power in the 17-18 PSI range with 95-97 octane or a small ethanol mix. Sorry if I'm thread jacking, but I am hoping AA will wake the car up properly for me. The best PSI I can get with just JB4 and our 94 octane fuel here with FBO is 14-15 PSI and that's when the conditions are just right.
02-24-2018, 04:37 PM | #50 | |
Rep 190,805
You can if you wish stack the JB4 with AA tune
02-26-2018, 05:02 PM | #51 |
Boost Patrol
30
Rep 79
Not sure if this has been asked yet - does the AA tune hide CEL codes relating to catless downpipes?
Just trying to figure out the best option now that JB4 got rid of that feature. |
02-26-2018, 05:03 PM | #52 |
Rep 190,805
It does
jmkr29.50 |
02-26-2018, 10:30 PM | #53 |
Rep 26
Upgraded to 3.5Bar sensor on my M235i with much smoother powerband with smoothing practically off, it's on the lowest possible smoothing. This run hit 28psi but later in the day I had a misfire in cylandar 4, but cleared the misfire, backed boost down to 23-24 and it's smooth. FYI - dinantronics sport in race mode with 97 octane had boost raise from simon3's 22psi to 28.5psi. Sport cat will be installed Thursday and I'll post more then to highlight the Simon3 success on my car. The constant pull feels amazing through the powerband. I'll be installing new spark plugs too because it's time.
441WHP 506WTQ https://network.perfexpert-app.com/results/DxFAS1fMF4 |
02-27-2018, 12:26 AM | #54 |
Rep 218
I guess I'll probably be the one to break the ice and say it but: don't those numbers above look... um, extreme? It wouldn't be of concern on a PS2 turbo, catless, properly fueled N55 with FBO but those numbers on a STOCK turbo and downpipe?? Don't mean to bash or anything just wondering how is that possible and safe in the long term before something cracks...
JP's M2xx20.00 |
02-27-2018, 03:11 AM | #55 |
Rep 26
I'm not pushing this as a daily driver but with a tap of a button I can go from 22 psi or 25+ if I'm at the track or having fun as a sleeper. No one expects to see what this car is throwing out. I'm on stock cat so the downpipe and map haven't even been factored in yet. I'll have the dp installed Thursday and report back. I have stock spark plugs on with 37k miles so I'll be changing them out for ngk 97506 and eventually upgrading the fuel pump(s). Car is smooth and I log everything everyday and the car is running well. I mean what would anyone expect hitting 28.5psi on the stock turbo, but I do not think I bought this with a stock turbo because it's putting out big boost, holds boost very well, and the instant power is clean with zero dead spots. I don't know what to say, it's a good setup but if you aren't careful or know wtf your doing it'll fail.
02-27-2018, 06:45 AM | #56 | |
Rep 1,184
02-27-2018, 10:13 AM | #57 | |
Rep 5,372
As for 24 PSI on a stock N55, uhhhhhh if really true......dumb. I thought these things were well out of their efficiency range at ~17psi. |
JP's M2xx20.00 |
02-27-2018, 10:59 AM | #58 |
3441
Rep 79,211
It's a virtual dyno. So not a real dyno.
Virtual dynos are typically best if you used to compare from 1 run to another with different mods. Same road, same conditions. |
02-27-2018, 11:50 AM | #59 |
Rep 5,372
Yep, and they're all pretty terrible because of bias, data entry/manipulation, etc. I could can easily run my stock M235 with virtual dyno and manipulate the data to show the car making 500hp if I wanted to.
02-27-2018, 12:11 PM | #60 |
Rep 190,805
AA OTS map put these numbers on a Mustang Dyno, Dynojet number will be even higher
02-27-2018, 01:35 PM | #62 | |
Rep 5,372
You're in CA. There are dynos everywhere.
02-27-2018, 01:46 PM | #63 | |
Rep 5,372
Mustang dynos are great for tuning, but they are also incredibly easy to influence. This isn't my first rodeo. Burger, AA, and many other tuners have posted some rather optimistic dynos over the years with their test cars. Once the third party dynos starts rolling in will we see where the true numbers are. Yes, every dyno is different and things like ECU adaptions, density altitude, etc. all play into the numbers and are very real things to consider; however, with the data, we can evaluate a general idea of the gains. There's no doubt these OBDII/bench flashes are the way to go for overall power and driveability, but to think AA is doing something really special with this particular OBD flash that hasn't already been explored and done by others doing bench flashing for the last few years is a bit silly, don't you think?
02-27-2018, 01:58 PM | #64 | |
Rep 190,805
Its not about exploring something completely new and making more power, its about their marketing strategy. Active Autowerke do not have any custom tuners that they rely on, it is in their best interest to produce an off the shelf map that makes the most reliable power. Some companies rely on custom tuners. Custom tuners need to make money selling their maps or else they won’t push for one tune in particular. You have been around long enough to be familiar with Cobb. Cobb’s Off the shelf maps were weak. If Cobb wanted to, they could have released powerful maps but they did not on purposes so their custom tuners can sell their own maps and make money. In return these tuners will heavily advertise Cobb to their customers and on forums. Nothing wrong with either strategy but to pretend like all off the shelf maps are the same is absurd.
02-27-2018, 04:59 PM | #65 |
Rep 5,372
I'm in no way saying all OTS maps are the same. If anything, AA's tuning strategy has historically been pretty aggressive compared to others. I was seriously considering their Active-8 unit a while back until I read all the reviews about inconsistent and unsmooth power delivery, typically occurring after a some miles got on the unit. I hope that AA isn't pushing the limits with it's flash tunes just for power bragging rights and sales. I'm also a bit surprised how they were able to introduce a flash tune so quickly when others are still in beta testing. That's why in sitting back and being patient to see third party dynos and longer term usage. I would actually prefer to use their product if it does turn put to be reliable and the support is there. For some of us, modifying an ECU is a bit overwhelming. My prior car was 2012 WRX tuned with a Cobb Accessport. Cobb has stellar customer service and has a large team dedicated to troubleshooting. Does AA have the same or do they just rely on this "30 years" of experience as their guarantee? A WRX is one thing but a BMW DME is a totally different animal.
02-27-2018, 05:00 PM | #66 | |
Rep 26
And how is it too much heat if I am data logging and the heat is normal. Same as it has always been, even a little less with the FMIC. |
