2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning MHD Tuning...
      01-06-2018, 07:54 PM   #23
zipphreak
No_Country
454
Drives: m235xi
Here's a screenshot to of the flashing process. I used an old Samsung Galaxy S4 with the samsung OTG adapter
      01-06-2018, 08:09 PM   #24
ChrisFulton
Drives: m235i
Appreciate you sharing the info. Keep us posted!
I was planning to flash on Wednesday.
(Nice interior color BTW)
      01-06-2018, 08:12 PM   #25
zipphreak
No_Country
454
Drives: m235xi
The logging display is fairly useless in the MHD logging module. They really need to fix this and make it better HUD interface.
Edit: I found a gauge layout button in the app, but i haven't tried it yet. I want to see the gauges will rotate to landscape.
I plan on flashing the stage2+ once i talk to MHD about this tamper code problem.
      01-06-2018, 08:16 PM   #26
ChrisFulton
Drives: m235i
Flashing 2+ as well. Keep us posted & I'll do the same!
      01-07-2018, 02:48 AM   #27
Amack
Australia
101
Drives: EB 2016 M235i
looking forward to your thoughts on the stage 2. keep us updated!
      01-07-2018, 07:04 AM   #28
zipphreak
No_Country
454
Drives: m235xi
If only it wasn't -10 degrees here in new england
MHD replied to the tamper code. It is only disabled in Stage 1 and above maps. They said it will be added to the next app update and will be disabled in Stage0 as well.
      01-07-2018, 09:59 AM   #29
ChrisFulton
Drives: m235i
Appreciate the update!
      01-09-2018, 10:28 AM   #30
BentZero
BentZero's Avatar
Sorry for the stupid question, but if the phone is in airplane mode how is it connected to the vehicle? For some reason I was thinking that it was a bluetooth connection.
Build thread
      01-09-2018, 10:53 AM   #31
MrMoe99
MrMoe99's Avatar
Drives: 14' BMW M235i
Phone is connected through usb adapter that connects to the K+DCAN cable which is connected to the car. Its a wired connection not bluetooth
      01-09-2018, 11:05 AM   #32
BentZero
BentZero's Avatar
Ah, okay. I thought that USB cable was connected to a charger. I guess the charger referenced in the dialog is a car battery charger?
Build thread
      01-10-2018, 06:14 AM   #33
jmwilson125
Drives: 2016 M235i
Yes, they recommend a battery tender hooked up to the car while flashing.
So you will need;
- Andoid device
-bimmergeeks otg cable or similar
-battery tender
-mhd software
-the tune that you want to load
      01-10-2018, 09:16 AM   #34
cxp213
cxp213's Avatar
313
Do you know if there will be a trace of that tamper code that gets stored somewhere? If so, can it be deleted?
It updated to .93 the other day, but don't see the anything about tamper codes in their log.
      01-11-2018, 02:32 PM   #35
ChrisFulton
Drives: m235i
Just installed the initial Flash.
Took 26 minutes using the Bimmergeeks cable.
Really frustrated that so far I have not been able to purchase a set of maps from the Google Play store.
The Flasher Module purchase went through with no problem but every time I try to purchase a maps pack I get: Error - Your transaction cannot be completed. with no other information.
Soooooo Frustrating!
      01-11-2018, 03:20 PM   #36
ChrisFulton
Drives: m235i
OK, if anyone else has this issue, it's a Google Play Store issue and not the MHD App.
I simply added another payment method and when I selected the new method the transaction went right through.
I just flashed Stage 2. It took 3 minutes.
No issues.
I just took a short drive in Comfort & Sport mode. I could immediately feel the difference in Comfort, & in Sport; the car is a ROCKET! Powerful & smooth acceleration.
The car also makes more noises, in a good way. Whistles and burbles.
I am about to take it out on a longer drive and play with it.
I intend to play with it for a few days & then flash to 2+ to see if I notice another difference.
      01-11-2018, 03:46 PM   #37
zipphreak
No_Country
454
Drives: m235xi
Make sure you grab the logging module, and take a couple logs per MHD instructions. And look at them that the car is responding appropriately for your mods. IE, not cutting constantly taking away ignition timing and power. Check Boost and Boost Target, they should be pretty close to overlapping. If you see major increases or decreases, note that. You should be taking logs and sending them to MHD anyways.
3rd gear for manuals - WOT 2500 rpm to 6500, then into 4th gear for 3 seconds and off throttle
4rd gear for auto 8spd - WOT 2500 rpm to 6500, then into 5th gear for 3 seconds and off throttle
Do this three times and send the logs to MHD at f-beta@mhdtuning.com
You should also upload them to https://www.datazap.me and post it here!!!
https://datazap.me/u/lesogorp/2015-b...-tuning-stage2
I need to re-do my logs on stage2+, it's very hard to start at 2500rpm on the highway in 4th gear. Might have to sneak out at night when there is open road. It's like 50 to 110 mph!
      01-11-2018, 05:09 PM   #38
Amack
Australia
101
Does this require a 1 time dme unlock?
would love to see some dyno logs for the stage2+
      01-11-2018, 05:24 PM   #39
zipphreak
No_Country
454
Drives: m235xi
The unlock is through OBDII, there is no pulling of your DME, removing it, sending it out, to be cut open, and potentially damaged or re-sealed improperly from the elements
26 minutes for the initial unlock and stage0 flash is all it takes. Future map installs are 3-4 minutes. The change was pretty dramatic on stage 2+ !
      01-11-2018, 06:57 PM   #40
cxp213
cxp213's Avatar
313
Just wanted to add my experience regarding this. For me, even though I had made purchases before on an established Google account, it still limited me to a single large purchase per day. So, I purchased the flasher, logger, and maps separately on consecutive days.
Make sure you grab the logging module, and take a couple logs per MHD instructions. ... You should be taking logs and sending them to MHD anyways.
How many logs have you sent to them so far?
All done via OBDII cable connected to your phone. I'm sure dynos and logs will come in due time, but this is currently in closed beta testing so I don't think those will be posted publicly just yet.
      01-12-2018, 12:16 PM   #41
ChrisFulton
Drives: m235i
Yeah, was planning on it and would love to do it today if I can ever successfully buy the Monitor/Logging module from the Google Play Store.
      01-14-2018, 09:03 PM   #42
zipphreak
No_Country
454
Drives: m235xi
Anyone else do some logs for this? What kind of boost are you getting on stage 2 or stage2+ ?
      01-15-2018, 01:28 PM   #43
jmwilson125
Drives: 2016 M235i
I'm assuming the dramatic change was from fbo and jb4? What setup we're you running before hand?
      01-15-2018, 06:51 PM   #44
zipphreak
No_Country
454
Drives: m235xi
xdrive, auto 8spd, sport cat, jb4, m perf can, wagner evo2 performance IC, ER chargepipe, k&n dropin, 93 octane. camber plates
The car is very very alive in comfort mode in low rpms, and even more so in sport/sport+ with the rpm's higher. The JB4 brought the car alive more so under specific conditions, WOT. No so much in the low/mid band. Boost is allowed under load conditions, then the waste-gate can start close to spin up and make boost. The MHD flash tune has opened my eyes to the world of flash tuning I'm going to be working with Terry on getting him some logs so I can help create a BEF for MHD + JB4 together. I think this will be a good combination in the future for those still looking for additive fueling like PI or Methanol.
Bee Pee1779.00
