2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning JB4 Interface Updates - Restore Passive Delete Feature (For PC or Android)
      10-15-2017, 12:52 AM   #45
zipphreak
No_Country
454
Drives: m235xi
I updated to 9/1/2017 version. Did the same change, and it works still. So your doing it wrong, or your editing the wrong file.
You will not find the file in your install files, those are just used for install. The installer puts it in your profile directory/AppData/Apps/2.0/ Then the directories are random, you need to use the taskmgr method to find the right folder
      10-15-2017, 09:02 AM   #46
SSM6
Drives: F13 M6
SUCCESS!!! It works! Tell me where to send the beers
      10-15-2017, 10:57 AM   #47
mcamera
Drives: 2013 BMW 335i M Sport
You are a god among men. I see the passive delete option now! Thank you very much. I'll see how it works throughout the week.
      10-15-2017, 11:21 AM   #48
zipphreak
No_Country
454
Drives: m235xi
Nice! Good luck, let us know. I'm glad we found a reasonable fix for this lol.
      10-17-2017, 01:18 AM   #49
tbaig
Drives: None
I recently purchased and installed a JB4 rev3 with Bluetooh. I am using iOS. Should i not register my Jb4 with my iPhone and instead use an Android?
      10-17-2017, 06:35 PM   #50
Switched Passive Delete "off" in the mobile app. All good now, no codes for over a week. Even before that I'd only get one every other day, usually when cruising during warm up...
D
      10-22-2017, 07:45 PM   #51
mcamera
I've driven for a week and 600 miles and still have no CEL! Tested and approved.
      10-22-2017, 07:49 PM   #52
tinpot
Drives: 2015 F82 M4
about to go for state inspection. Once the CEL is cleared are you taking any other steps to get sensors to "ready"? As an example, in this thread the advice is to switch to Map 0 and drive for 100 miles http://f30.bimmerpost.com/forums/sho....php?t=1171953
      10-22-2017, 11:36 PM   #53
drivef30
drivef30's Avatar
Drives: 17' 340i xDrive M-Sport
So when I enable (check mark the box) passive delete on the jb4 computer interface, do i have to go into the map settings on the cars gauge and enable it aswell through the car (for n20 ewg, tach on 4 setting and rpm on 1k). Just slightly confused.
Thanks for you sharing btw!
      10-23-2017, 10:29 AM   #54
mcamera
While connected to the car, I checked the passive delete box on the computer interface and then clicked the save button on that same page. Then in the top left of the computer screen, it'll say something like "settings saved!" to confirm it was uploaded to the car. That's all I had to do for my N55 F30 335i.
      10-23-2017, 10:30 AM   #55
zipphreak
No_Country
454
Drives: m235xi
Just do it through the windows interface or android interface.. This is where it is blocked in the US. On the n55 EWG F series we don't have passive-delete option on the MPH/TACH options.
passive-delete on, and save settings. Done!
FSociety3812.50
      10-23-2017, 10:45 AM   #56
beMtroubleYou
beMtroubleYou's Avatar
67
Drives: M2C '18
2018 M2C  [0.00]
Guys. This deletes all CEL right?
What if it throws a missfire and you wont see it?
I would leave it and just read the CEL, the "cat not efficiant" dont come too often..
      10-23-2017, 11:22 AM   #57
zipphreak
No_Country
454
Drives: m235xi
Yes it periodically clears all codes. Then the CEL's are suppressed it is not a good solution if you have problems It's a misunderstood feature. If you are trying to suppress cat codes, look at CAT specific solutions, thread in o2 simulators, or active plug in suppressors.
http://www.bigdaddiesgarage.com/straight-cel-fix.html
http://www.vr-speed.com/vrsf-catless...-bmw-335i.html
      10-23-2017, 12:03 PM   #58
beMtroubleYou
67
Drives: M2C '18
2018 M2C  [0.00]
My point exacly. I rather just keep the feature off and be aware of the codes. Thats just me
      10-24-2017, 09:12 AM   #59
The codes that were coming up were different for me. More along the lines of “aftermarket intake/dp detected”?
      11-08-2017, 04:25 PM   #60
kenbrinkman
kenbrinkman's Avatar
Drives: '16 M235xi
For those of us with Rev 3 and iOS on the most recent software/firmware, I was able to restore the passive delete feature by deleting the JB4 app and connecting the phone to a VPN to any country other than the US (I just used Canada). I used Private Internet Access for the VPN. They have an iOS app with makes configuring the phone as easy as an on/off switch. Once the VPN is connected, redownload the JB4 app. When it asks to use location service, just say no and log in as normal. Go to your WMI settings and the Restore Passive Delete feature can be enabled.
If you change these settings often, you'll need to use the VPN every time. Otherwise if you're like me and just change maps once in a while, your WMI settings will never update unless you hit the save button. This has been working for me so far. This is a pretty easy solution for those of us that use iOS and bluetooth or those who don't want to deal with hacking the app.
      11-08-2017, 06:49 PM   #61
zipphreak
No_Country
454
Drives: m235xi
Great, the VPN workaround was already proposed in this thread and works for any platform IOS or Android.
      11-08-2017, 10:36 PM   #62
kenbrinkman
Drives: '16 M235xi
Oh sorry, I read through the thread but missed your one post.
      12-06-2017, 01:12 PM   #63
OverRev
OverRev's Avatar
Drives: E92 M3 & F22 M235i
If I purchased my JB4 from BMS directly this year in April, do I need to update the firmware? what benefit/change does the update make?
I couldn't find any info on the web site, thanks for answering.
      12-15-2017, 11:36 AM   #64
Realdread1
Drives: 16 235i
Any chance on updating the install file for OS X?
I do not want to run a virtual machine.
      12-16-2017, 11:38 AM   #65
Their thread on N54tuning.com shows the update dates, and what was associated to it.. In the last 12 months it's been mostly small tweaks, but if you have the BT setup, it only takes 2 mins to update..
      12-16-2017, 12:23 PM   #66
Realdread1
Drives: 16 235i
To clarify, if im not updating firware then can i use OS X for datalogging without worrying about the location check for passive code deletion? I am happy with my firmware.
I just dont wont to plug in on the mac and deal with that CEL
