2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning MP: Dyno day with Stage 2 M235i. JB4 and Flash Tuning results
      06-15-2016, 04:15 PM   #89
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Originally Posted by Anthony235
Looks like you're having some serious timing issues in your latest log on n54.
I looked at the last log you posted here. Seems the timing isn't as bad then, but still not the best. When I first looked at it I didn't really look at all cyl.
You might be mistaking me for someone else, I have a different username there sc67065
I'm not having any timing issues in my recent log, but rather HPFP not being able to keep up.
Haven't been focused on my cars the past few weeks but I'll be in touch with Alex soon
FBO M235i r
F80 M3
      06-16-2016, 10:01 AM   #90
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Disregard. I can't read.
      06-21-2016, 02:16 PM   #91
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
      06-21-2016, 04:13 PM   #92
ocN55
ocN55's Avatar
Actually the logs you posted here and the logs sc67065 posted on n54 both have the same VIN listed on the logs.
But that's not your car?
That is my username as per my other post.
FBO M235i r
F80 M3
      06-22-2016, 09:56 AM   #93
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Wow I can't read sorry.
Did you get your boost and timing smoothed out? Or is MP saying it's fine?
I'm deciding whether to go with this flash or hold off until more users are running it.
http://www.n54tech.com/forums/showthread.php?t=40265
      06-22-2016, 05:52 PM   #94
ocN55
ocN55's Avatar
I haven't reached out to him yet, car still feels great though. Ignorance is bliss lol
When I was running just the jb4, I would consistently be in limp mode when doing pulls at this torque level.
I'll have to see what he thinks.
FBO M235i r
F80 M3
      06-22-2016, 09:53 PM   #95
ocN55
ocN55's Avatar
I feel like both of you guys should have pulled the trigger right now. You guys have been reading up on flash cars like mine and others for months now and still haven't flashed your cars lol
You guys have read enough to make an informative decision on whether or not to flash by now.
FBO M235i r
F80 M3
      06-22-2016, 09:56 PM   #96
ocN55
ocN55's Avatar
Interesting on the comments they're saying there
I think it was bad gas? Went to a weird gas station.
Haven't had the same issue since using 76 again
FBO M235i r
F80 M3
      06-23-2016, 12:00 AM   #97
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I've put in bad gas once from a Mobile station and I never use Mobile. Sure enough stutters and weird behaviors so I suspected bad gas. I put in turbo 108 fuel additive and bam! Bad gas problem solved. I know putting in constant MMT is no good for the plugs, but if there was water in the tank or the octane rating was false the fuel additive fixed it.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      06-23-2016, 09:33 AM   #98
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
That would have to be some seriously bad gas.
I would like to see more cars running it and more logs. So far I've only seen logs from ocN55.
MP is new to me and I'm not going to jump into a tune with them. I've had lots of tunes on my previous cars and the right tuner makes all the difference.
Would be nice if MP posted here.
      06-23-2016, 12:44 PM   #99
ocN55
ocN55's Avatar
As someone who also came from Japanese turbo cars, I have to say the story is different on these cars. BMWs are no wear near as naggy as boosted Japanese cars; subarus, evos, GTRs, turbo civics, you name it. I've yet to see a horrendously tuned modern BMW, which says something about how well these cars respond to flashes. These DMEs are quite robust and extremely intelligent.
You can keep reading logs and dyno graphs, but you will never truly know until you try. Gotta pay to play right?
Since you're in SoCal, we can set something up and get your behind the wheel of my car
FBO M235i r
F80 M3
      06-23-2016, 12:52 PM   #100
ocN55
ocN55's Avatar
Also I wouldn't count on seeing more logs of flashed cars anytime soon. I don't know of anyone else with the same setup who is keeping me JB4 as a logging tool.
FBO M235i r
F80 M3
      06-28-2016, 12:44 PM   #101
Secret_Asian
Drives: f10 lci luxury line
I'm tempted to keep the jb4 on for a few logs after the tune but most likely will remove it when installign the ecu. At the very least I will remove the flex fuel lines which are a bit of a pain to reach otherwise but most likely jb4 is out and being listed in the classifieds
      06-28-2016, 01:37 PM   #102
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
I say keep it.
If I go with a flash I'll still keep my JB4 for logging and other features that it has. Also I run e35 99% of the time so I will use JB4 for map 6 boost tables on top of the 91 pump flash.
Run map 4 on jb4 when I have 91 pump in the car.
Not to mention jb4 stack is good if you upgrade your turbo.
      06-28-2016, 01:44 PM   #103
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Originally Posted by FSociety View Post
Yea thats true!
Keep the jb4 and re-evaluating your revisions i'd say.
Thanks Anthony235 and you for all the work and update here.
You def should keep it regardless of what tune you go with, since you have already invested in the jb4 keep it as a logging tool.
I have a friend that is going to test his full flash with jb4 on map4, he will dyno before/after, drag as well and then go back to his tuner for backend flash to use with his jb4 (stacked) and repeat Dyno and drag for his testing purpose.
No problem. I'm just wary of new tuners from previous experiences. MP is at the top of my list because they are local and offer OBDII flashes. I like the AFR and timing adjustments they can make too. Which JB4 can't.
Wish MP would post updates here about the revisions and updates to their flash. Would also like to see more dyno and log data. I think ocN55 has gone through multiple revisions now.
      06-28-2016, 02:42 PM   #104
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
You can get your flash tuner to optimize for E30-E85 without jb4
But you can also do it that way!
Yeah, but what happens when I'm stranded on a desert island with only 91 pump gas?
I don't think a flash that is specifically based on e35 will be good or safe with 91.
I have a feeling the flash is based on 91 which means you can run e85 no problem, but you're not taking advantage of the ethanol to it's fullest.
      06-28-2016, 03:40 PM   #105
ocN55
ocN55's Avatar
Alex is still doing almost everything himself. He has made quite a reputation for himself over with the F10 M5 guys and will be flying out to Bahrain more, much bigger market than our cars anyways. So his attention for us unfortunately is going to be a bit less for now. I'm starting to think he is doing me a personal favor
If you're serious about flashing your car though, just come out and see us at our next dyno day so you can see what its all about.
FBO M235i r
F80 M3
      06-28-2016, 03:52 PM   #106
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
That does make sense. I was thinking the same thing. Our market is relatively small. Especially for the price point of a full flash vs a piggy back.
I tried to join one of your dyno days before. He never replied back to me with the details.
Please post the next time you have a dyno day. I would be willing to flash on the spot if I'm convinced
      06-28-2016, 11:51 PM   #107
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
My car is in with Alex and Kareem for body work, new lip and some custom painting of the side signals and door handles. The have a shop called Mission Collision and a lot full with BMW's. During this time Alex is modding my turbo inlet to house the maf and then we're going to the Dyno with an M5. I'll post back here with the exact date if you want to join. It's the final tune to my stage 2. Should be about another 7 days from now.
IG: @bmwdoubles
Appreciate 4
      07-20-2016, 03:19 PM   #108
wakeofdeath
Albania
71
Drives: X6M
Any updates ?
      07-21-2016, 12:06 AM   #109
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Any updates ?
344/505 for a N55 f10! Got to hangout with ocN55 M235 and apexlocator M5
http://f10.5post.com/forums/showthread.php?t=1284730
http://f10.5post.com/forums/showthread.php?t=1281849
http://f10.m5post.com/forums/showthread.php?t=1285575
IG: @bmwdoubles
      07-26-2016, 10:16 AM   #110
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Question for MP.
What if all I want flashed is:
AFR correction so AFR target is 12:1
Top speed limiter removed
Catless downpipe coded
Cold start removed
Is this possible? If so, how much? (with and without M boot option)
I will just use JB4 for boost control.
