2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Enzo Performance N55 Tune - Independent Dyno Results
      12-10-2015, 06:37 AM   #45
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Originally Posted by Luminous
Originally Posted by boost82
I asked them a couple times but never got a response about fueling. Are you running meth or any other supplemental fueling to run full boost on that turbo?
The jb guys need meth to run 24 25 pds of boost
To run max boost you will definitely need some type of additional fueling. Personally I'd rather avoid meth and plan on eventually adding the fuel-it tbi kit and lpfp. Right now I'm on stock fuel system using 93 pump and have had no issues. Looks like the current tune is peaking at 21psi but tapers off as rpm increases. Will experiment with adding a bit of e85 and see what happens, on the stock turbo I could add as much as 5 gallons per tank with no issues.
I had a chance to test the car last night and I have to revise my earlier comment of the car not being much faster. Even on the current tune the car feels like an absolute beast, at WOT it's frighteningly fast. It's definitely a lot faster, the power delivery is so incredibly smooth it's ridiculous, the blurb between shifts is louder and it sounds absolutely intoxicating at WOT.
Since this is my first upgraded turbo, I didn't know what to expect and was really worried about the increased spool time affecting my 0-60 times, but I am happy to report that I easily matched my record of 3.80s on the first run, with half a tank of gas.
Honestly I'd recommend this upgrade along with the dv+ even for people who don't plan on running max boost, I feel it's really improved the overall feel of the car, not sure why that is but I assume it's because the turbo just runs more efficiently vs a maxed out stock turbo.
Did they install the DV+ for you?
My tune feels a little lumpy in first and second gear, I think my 2012 DME needs a little TLC.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      12-10-2015, 07:05 AM   #46
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Yea I had it installed along with the turbo.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-10-2015, 11:12 AM   #47
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
Originally Posted by jcruz3 View Post
when..and where...!?
+1 When and where? I would love to get an updated HP & TQ dyno!
      12-23-2015, 01:55 AM   #48
le enox
Drives: m235i
any updates on that pure stage 2 tune?
      12-23-2015, 08:14 AM   #49
Luminous
Luminous's Avatar
743
No updates yet, I know Enzo is still working on the install and tune for ronanz's pure stage 2 435. Looking forward to the results!
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-23-2015, 07:20 PM   #50
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
My updates can be found HERE
My Build Thread can be found HERE
      01-22-2016, 12:17 PM   #51
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Originally Posted by ROBNYC
Darkiedm4 how's your setup running?
ronanz hi5 for the link
My car is running great on stock tune with just speed limiter removed and jb4 tuning only! Can run any boost i want without issues!
      02-13-2016, 04:37 AM   #52
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
So your flash just moved the limiter and coldstart ?
Then everything else jb4 is controlling it ?
Just speedlimiter. I still have cold start.
      02-14-2016, 10:03 AM   #53
BKBMW335I
Drives: '11 E93 335I
Originally Posted by Luminous View Post
I just thought I'd share the results of my independent dyno testing of the Enzo N55 flash tune.
Back in March I did a baseline dyno when I was switching from the Dinan stage 1 to the Manhart stage 1, and hadn't made it back to the same dyno since upgrading to the flash tune.
The dyno is a mustang awd, according to the shop it reads 17% lower than the dynojet they compared it to. Either way I was more interested in seeing the gains vs absolute numbers. All runs were done in 4th gear on 93 pump.
Stock baseline: 265hp/283tq
Enzo FBO: 355hp/395tq
Gains: 90hp and 112ft/lbs!!!
Best 0-60 is 3.80s
Best 1/4 mile was just over 12.4s, but I feel this number could be better, this was on a summer night with high humidity and stock tires at a sub par track.
I'll post a pic of the graph, the dotted lines were my previous best with the Manhart.
For those interested in "dynojet numbers", I did the calculations for you: x1.17
Stock baseline: 310/331
Enzo FBO: 415/462
Pure stage 2 being installed tomorrow, please send happy thoughts while my car is under the knife!
Nice, looking forward to your numbers after the Pure dyno
      02-24-2016, 10:45 PM   #54
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Subscribed and very interested in this. Will have to contact Enzo and find out if there are local solutions in VA beach area!
      02-25-2016, 01:58 PM   #55
Happy to announce that we now offer Enzo Performance tunes, downpipes and exhausts
Phone number 702-494-9435
Appreciate 4
      02-25-2016, 05:26 PM   #56
ronanz
ronanz's Avatar
      02-25-2016, 06:14 PM   #57
Die ///M Rakete
Die ///M Rakete's Avatar
Drives: 2016 F80 ZCP 6MT
For the M2 ?
      02-25-2016, 06:16 PM   #58
Originally Posted by Die ///M Rakete View Post
For the M2 ?
LOL
Once Enzo products are available for the M2, we will be the first to have it
      02-25-2016, 06:20 PM   #59
Die ///M Rakete
LOL
Can't wait...you'll have my business
      02-26-2016, 09:53 AM   #60
EEBreh
Drives: "M" 235i
LOL
Mike, can you please expand on this? Do we have to send our ECU out or is there a flasher that you send us?
      02-26-2016, 10:45 AM   #61
At this time, all F chassis ECU have to be sent to Enzo for a flash.
Turnaround time is 24 hours
      04-06-2016, 10:38 AM   #62
dAPEX
Drives: 2015 m235i with FBO
2015 BMW m235i  [0.00]
Enzo will adjust the tune accordingly for the new turbo. I know a few people ended up stacking the jb4 with a flash tune, I'm hoping I won't need a jb4 for now...
Why would you need to stack the JB4 with the flash tune? For methanol control? Or ethanol use?
      04-06-2016, 10:48 AM   #63
Luminous
Luminous's Avatar
743
It's only necessary as a boost controller when running a larger turbo. Depending on my fueling I can adjust the boost targets at will. All other parameters are still controlled by the flashed ecu. It's the best of both worlds, smoothness and reliability of a flash tune with the ability to change maps and control boost on the fly. Im loving it!
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      04-06-2016, 10:58 AM   #64
hoppy6698
hoppy6698's Avatar
Question - APR tunes have a method to switch between fuel types or even back to stock using the stalk controls. Does the Enzo do that or is it always active?
      04-07-2016, 12:00 PM   #65
Info@EnzoPerformance
Info@EnzoPerformance's Avatar
587
Drives: F10 M5 700R+
The tune is very adaptive, it will adapt to 4-5 gallons of E85 very well, 91, 93 etc. As for different boost levels no, the tune is always active. Luckily the JB4 allows you to change maps. For guys running a JB4 our N55 tune is $995.
Cheers,
Chris
      04-08-2016, 09:03 AM   #66
Tricki
Tricki's Avatar
Australia
215
Drives: BMW M2 Comp
Cheers,
Chris
With your tune alone what boost levels is it achieving ?
