2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Best Catted Downpipe to run with MPE?
      01-10-2017, 02:38 PM   #23
MeanMGN_F22
Drives: 2016 M235i
Originally Posted by Fabspeed Motorsport View Post
I can get you set up! I'm running the CF tips on my M235i as well. I get compliments on them all the time.
Check your PMs!
Placed an order today! 3 week lead time though
      01-10-2017, 02:43 PM   #24
MeanMGN_F22
Drives: 2016 M235i
Thanks for all the replies guys. Much appreciated.
For those with the DP, did you run a tune? I plan on holding off for a while b/c of warranty.
If not tuned, does the car behave weirdly at all?
      01-10-2017, 02:46 PM   #25
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
The car will respond exactly like stock with a increase in throttle response and boost hits a lot harder!
      06-20-2018, 10:01 AM   #26
digisides
Drives: m235i
Wagner
What advantage does the fabspeed catted downpipe have over the Wagner and ER which are also very popular? Does it have better power gains or sound better? Can anyone chime in here?
      06-21-2018, 04:09 PM   #27
BentZero
BentZero's Avatar
Go with BM3 for the tune. You can revert back to full stock including the stock flash counter.
Build thread
      06-21-2018, 05:48 PM   #28
Guitarman15
Drives: 2015 M235 Xdrive
Hey guys,
I plan on getting MPE soon and was hoping to drop in a catted DP in the meantime. Anyone run a similar setup? How is the sound?
There's lots of suggestions for Fabspeed/Wagner/ER etc.
Is there a "consensus" on the best one?
About me:
DD the car about 60+ miles a day (very often in traffic) so can't have drone.
Live in CA so emissions . . .
Dislike CEL (plan on a tune much later when I've run the warranty)
Thanks.
I have fabspeed sport cat and MPE sounds amazing. Also AA stage 2 flash tune. Love it I'm pumping out 415 hp
Dylan861330.00
      06-22-2018, 05:27 PM   #29
digisides
Drives: m235i
Protuningfreaks told me today there is no advantage to running bootmod3 stage 1 with a downpipe. Can anyone comment on this? They do NOT recommend running stage 2 without FMIC
      06-23-2018, 03:25 PM   #30
Reason they told you that is the Stage 1 tune will not have the parameters to leverage the higher flowing DP. You'll make more noise, and a few hp more in power, but the real difference comes from the tune associated to the downpipe upgrade (Stage 2 and beyond).
      06-23-2018, 07:01 PM   #31
BentZero
BentZero's Avatar
You could always try it and revert back if you're running into temperature issues. If you'd rather not chance it you can ask for a custom tune.
      06-28-2018, 05:07 PM   #32
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Since the tune is designed for an FMIC, that means a typical FMIC will combat intake air temperatures a lot better then the factory intercooler.
Couple that with your 91 octane and potentially hotter climate, you will be riding the knock sensors and have an otherwise lower knock ceiling.
It's best to run the appropriate map not only from a performance aspect but consistency as well as safety of the engine. Although these cars are pretty smart, sometimes more boost and timing will result in a slower feeling car, especially as it heat soaks.
With FMIC's like VRSF 5" Street HD at the price point they are at, it's a no brainer should you want to upgrade, they are great value.
Tags
downpipe, mpe
