02-07-2017, 06:16 PM | #2 |
Rep 1,154
ECO, save on gas
COMFORT, most popular mode SPORT, better power, handling SPORT+ turns off traction control Traction control, good for snow ABS, prevents locking of the wheels during braking I drive in comfort mode mostly, sport when I want to drive a little more aggressively, not much in sport+ engage traction control if I get caught in snow but I try not to to drive in snow, I have an X3. |
02-07-2017, 06:51 PM | #3 |
Rep 89
This is the most comprehensive table I have found on the different driving modes.
http://www.babybmw.net/forum/viewtopic.php?t=71296 |
02-08-2017, 07:22 AM | #4 |
Rep 2,873
I think first Nanny has to get to know and trust you, before she will even begin to share what she is thinking (but my guess is either "why aren't we going faster?" or "when will he change my oil, and what weight oil will he use?").
02-08-2017, 07:28 AM | #5 | |
Rep 1,154
BMWZ41909.50 |
02-09-2017, 10:45 PM | #6 |
Rep 525
Ok the chart mentions a couple of things:
"Exhaust valve open on throttle" ? what does that mean? "Braking energy regeneration" ? How does that work, is it even provided on a non electric vehicle? Does it put wring fuel from the air and put it back in the tank? What I was actually wondering is what it was programmed to do when the back end gets a little loose? Which brakes does it hit if any, any steering inputs, suppose I'm into the hand brake? or If i'm on black ice with a stick shift and come to a hill that I just don't have the traction to climb will it doggedly prevent wheelspin by closing the throttle till it stalls? |
02-10-2017, 10:38 AM | #7 | |||
Rep 99
Traction control in the default setting won't let your tires spin at all. In any kind of snow or ice you'll want to hit the traction control button once to get moving. In really bad snow or ice you'll want to hold the button down for three seconds to fully disable traction control. Just note that when you fully shut off traction control stability control cuts out as well. I'd personally recommend finding a nice big wide open wet/snow covered parking lot and playing around with the settings to get an idea of how much it intervenes at the different levels. |
02-10-2017, 01:13 PM | #9 |
Rep 1,931
You could read the manual?
www.nybmwcca.org
Viffermike1753.00 |
02-11-2017, 10:26 AM | #10 | |
Rep 3,395
In MY case I just want to be able to turn all of the nannies off and drive old school Unfortunately the DSC, DTC, Sport and Sport + modes battle with one another and the driver. It "appears" that you can enable sport mode (throttle response/sport suspension) AND turn off DSC by holding the DSC button for up to 10 seconds......I need to play with this and further validate The SIMPLE thing to do would have been to program this into Sport Plus........but sport plus actually turns ON the DTC (e-diff).......I found this out recently during a spirited accelleration in a straight line......you could feel the rear brakes coming on independently, back and forth the programming/electronics are maddenning Just give me an on/off switch |
02-12-2017, 03:04 AM | #11 |
Rep 5,369
The eLSD is only active in DSC OFF. That's it. What you were feeling in Sport+ was the traction control system. In DSC OFF, the eLSD is pretty good and allows for full on drifting.
My biggest gripe is with the throttle control with a 6MT. The Sport throttle is a bit too aggressive and the regular throttle is a bit numb. Something right in between would be stellar. I'd drive around in DSC OFF all the time if it weren't for the slow throttle. |
02-12-2017, 08:56 AM | #12 | |
Rep 144
02-12-2017, 03:38 PM | #13 |
Rep 5,369
Nope. DSC Off = eLSD active, 80% exhaust burble pop, Comfort throttle, Sport steering, Sport suspension. No other button pushing will change the way the mode works. BMW intentionally chose the Comfort throttle in DSC Off so that the driver had a more linear control of the power. I agree, that is a good approach, my beef is that the Comfort throttle is just a bit too neutered with the 6MT.
Tpeterson156.50 |
02-15-2017, 07:38 PM | #14 |
Rep 744
What about Traction mode? As it's meant for use on snow/ice for added traction, I wound think that would enable the eLSD.
02-16-2017, 05:03 PM | #16 | |
Rep 144
02-17-2017, 07:53 PM | #17 |
Rep 744
Then what the heck does traction mode do?
02-19-2017, 12:27 PM | #18 |
Rep 2,873
In regular nanny-on mode I seem to get some limited wheel spin, not extreme, but don't think it is totally eliminating it?
And I agree this is very obscure - I reread the manual a dozen times, and still confused by the permutations. Spent a good part of last winter with the stability off, thinking that was increased traction mode (it is, but just for straight line - getting unstuck in a driveway). Didn't really notice the lack of stability assist, but I wasn't pushing it hard. Late edit: Wanted to update - just had our superstorm - >12" on top of ice, and in this I do get a lot of power cutout if it is starting to spin, almost to dead stop as it gains traction, mostly as I'm turning into a new street, not on straight-line. Didn't need to put it into traction mode, and was able to stop on fairly steep hills and get going again (around the stalled/spinning cars that couldn't); guess I hadn't gotten into stuff bad enough to really activate the nannies, which is saying a lot given how bad our 'typical' roads are. Last edited by Maynard; 03-15-2017 at 08:25 AM.. Reason: update/correction |
02-21-2017, 06:18 AM | #19 |
Rep 3,842
The nanny modes are seriously lacking with the M235i. I drove a 911 which absolutely needs its nanny to prevent a layman driver from flying off the road, it is so smooth that you don't even know it's there. The M235i on the other hand surges and twitches like it is confused. I prefer to use DSC off for this reason, but the car has so much power that in town you can easily get into trouble with too much throttle in a turn especially if you're used to the nannies. So I've gone back to allowing nannies in town just for safety sake.
I will be upgrading my tires to 235/35 front and 265/30 rear, I hope this will give the car enough grip to quiet down the nannies because they drive me crazy, BMW should work on fine tuning there system. |
02-21-2017, 10:46 AM | #20 |
Rep 5,369
Look at it this way:
Comfort - All nannies on, light steering, soft shocks, slow throttle, quiet exhaust, quiet fake engine noises Sport (assuming you have Sport settings engage in I-drive) - All nannies on, hard steering, hard shocks, quick throttle, loud exhaust, loud fake engine noises Sport+ - Slightly reduce nanny intervention with respect to wheelspin and slide, hard steering, hard shocks, quick throttle, loud exhaust, loud fake engine noises Traction - Slightly reduce nanny intervention with respect to wheelspin and slide, soft steering, soft shocks, slow throttle, somewhat loud exhaust, somewhat loud fake engine noises. DSC Off - No stability control or traction control, eLSD on, hard steering, hard shocks, slow throttle, loud exhaust, loud fake engine noises Depending on road surface conditions (typically cold pavement, sub 50 degree temps), you can spin the tires a bit even in the modes where the nannies are fully engaged. |
02-21-2017, 03:29 PM | #21 | |
Rep 3,395
It also appears that DTC does NOT come on...... I could not generate the side to side wobble/wag induced by the brakes attempting to do its eLSD thing Seems like the nannies just let the actual LSD do what its supposed to do....push forwards...... |
02-21-2017, 04:06 PM | #22 | |
Rep 1,184
Definitely is better/ more fun to drive than just DSC off. |
