04-17-2024, 08:54 AM | #5545 |
Rep 1,238
Anyone on here have any experience or strong opinions on using a water deionizer? I hand washed my car last week (BSM is the color) using my hose at home. After drying the car off I noticed some tiny water spots all over the car. I tried to mist n shine and the spots are etched into the clear.
I was thinking about having a shop clear up those spots and then apply some ceramic coating. Or was considering getting the spots cleared up and then buying a water deionizer for handwashing. I guess I could do both but trying not to spend too much cash. Curious if anyone else has experience with these units. I'd hate to buy one and then still get water spots so want to make sure they 100% work.
2024 M2
2019 M240i- Sold |
04-17-2024, 09:14 AM | #5546 |
recovering e36er
70
Rep 109
Drives: 2017 M240i Xdrive
Added the Bimmer Network heat shield the other day!
Can't really see it once the air box and OCC are reinstalled
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2 To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit |
04-17-2024, 11:43 AM | #5547 |
Rep 1,021
04-17-2024, 03:35 PM | #5548 |
Rep 44
04-17-2024, 05:40 PM | #5549 |
Rep 29
Drives: 2016 M235
New Apex wheels
Apex EC-7
18 x 8.5 ET35 225/40/18 Michelin AS 18 x 9.5 ET58 255/35/18 I used the recommendation from here: https://apexwheels.com/fitment-guide...-fitment-guide 2016 M235i 6MT I debated about the color but went with race silver for a classic BMW look. |
05-02-2024, 09:04 AM | #5552 |
recovering e36er
70
Rep 109
Installed a replacement Msport front spitter and rear diffuser.
05-04-2024, 11:05 AM | #5554 |
Rep 157
Drives: BMW 218i M Sport
Had the whole taillights PPF’d with Innovative PPS reverse light overlay tint installed underneath the PPF and again Innvoative PPS PPF applied on the climate control glossy surround trim.
05-06-2024, 09:28 PM | #5555 |
Rep 65
Dantesboyz69.50 SterlingE3012.50 |
05-07-2024, 08:16 PM | #5556 |
Rep 6,083
Had the tenth annual oil change today and learned that the motor mounts and thrust arm bushings have reached the ends of their lives. Considering taking the opportunity to install M2 thrust arms to go along with the M2 LCAs already onboard.
JMcLellan2103.50 |
05-09-2024, 03:26 PM | #5557 |
Rep 391
Spent the weekend fixing and spraying my splitter that broke into 3 pieces, bottom bit was black, now alpine white to match the car!😁
Current: G20 320d xDrive F22 M240i
Previous: Many, many boring BMWs, 116d (F20), 220d, M240i (F22), 318d (F30), 320d (F30 and G20), 330e (G20), 420i (F32), 420d (F32), 435d GC (F36) |
05-13-2024, 04:42 PM | #5558 |
Rep 6,083
Ordered my M2 thrust arms with urethane bushings to fit directly on my 228i to go along with my older M2 LCAs. Source is Bimmerworld who sells the package with or without the LCAs. Great local dealer will take in these parts to do the installation.
05-14-2024, 02:33 AM | #5559 | |
Rep 108
Drives: M4 Cab / M240 Cab / X4MC
Where did you buy the full kit. Front rear and side skirts, as looking to buy one this week for my F23 and concerned on quality and fit. OEM just too much really. Thanks in advance. |
05-14-2024, 05:54 PM | #5560 | |
Rep 391
Only thing I’d do differently is spray some top coat on the original splitter/wing mirror caps to give them some more protection, but they were cheap enough that it’s not the end of the world!
ajbM4cab107.00 |
05-15-2024, 07:56 PM | #5561 |
Rep 230
Simple
Just a simple oil change that wasn’t simple. That oil filter cap is a bi_-tck to get off and on.
Got it done. I won’t do it again. Off to dealer next time. Hap |
freakystyly3077.50 |
05-16-2024, 11:04 AM | #5562 | |
Rep 108
I also intend to paint them. |
05-17-2024, 09:11 AM | #5563 |
Rep 518
Replaced my worn noisy shock and dinan spring with coil..
Trying out -1.5 camber on the front and now Im ready to up to 245 from the current 225 and considering square setup |
05-17-2024, 06:45 PM | #5564 |
Rep 1,827
Finally warm enough and a long weekend to put in the Konis. The first corner's in. Going to tackle the other 3 corners tomorrow... before the beer supply runs low.
No shortage of rust here. Edit: 3 done, last one is halfway there. Doing fronts without using a spring compressor slows things down but it works. Edit 2: Finished, going for test drive. PS: use an extension when fastening the top mount screw closest to the positive terminal or you'll get sparks. Last edited by freakystyly; Yesterday at 01:36 PM.. |
JMcLellan2103.50 Dantesboyz69.50 |
