2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Is leaking oil filter housing leaking (image attached)?
      03-19-2018, 05:29 PM   #1
Bimmer Pleaser
Bimmer Pleaser's Avatar
205
Drives: nothing
I was just at a dealership (non BMW) looking at a 2016 228i. There was some oil and grime around the oil cap as you see in the picture. Can you take a look and make an educated guess as what caused it? I asked them and they said they just changed the oil. It was a Ford dealership so I can't really trust their expertise although I personally think the gasket is fine because there was no oil on the left...
Thanks,
      03-19-2018, 05:39 PM   #2
overcoil
Drives: M235i 6spd
No rubber seal or didn’t remove old rubber seal so two are on or just spilled oil - wonder if a ford dealership used the correct oil and reused old oil filter.
And be extra judicious buying frm a dealership.
      03-19-2018, 06:22 PM   #3
p912guy
Probably just a bit of oil residue from previous oil filter changes. It's pretty hard to change the filter without dripping a few drops of oil.
16 Audi Q5 3.0T (Wife's Daily Driver)
66 Porsche 912 (Project)
17 GMC Canyon Denali Long Bed 4x4 (Tailgatin, Haulin & Towin)
various 'one design' sailboats / stinky hockey gear
      03-19-2018, 07:34 PM   #4
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Having changed my own oil on the 228 multiple times I can tell you it's very easy to drop oil in that spot if you are either in a hurry or don't know how to avoid doing so. Since it's a Ford dealership I would think both probably apply.
78' Honda CB400A project
      03-21-2018, 09:29 AM   #5
Charles B
Charles B
Charles B's Avatar
Drives: 335 M235 Z4 944 Turbo
2013 BMW 335  [9.17]
2016 BMW Z4  [10.00]
1986 Porsche 944 Turbo  [0.00]
it's spilled oil, you should not need an OFHG until about 80k miles.
      03-21-2018, 10:03 AM   #6
3rdcoast228i
Drives: 2016 228i Msport
Crank it up, if its leaking you will see it. The filter housing is under pressure when the engine is on. More than likely it's just spilled oil as stated above.
