2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Left rear tail light out....warranty denied
      03-12-2018, 04:07 PM   #23
Rayscott
Drives: BMW 228ix
Originally Posted by IndyRed128i View Post
Hey all,
So long story short, about 8 months ago I purchased an auction 2016 228XI. When I purchased it, I was aware that it had some previous hail damage and body work, but was under the impression that my warranty would still cover anything not affected by this.
Yesterday, out of the blue, I get the message on idrive:
*Left rear turn signal malfunction
*Left reverse light malfunction
*Two stage brake light malfunction
Upon taking the vehicle in to BMW and having it taken apart, I am informed by my service advisor that because the car had previously been resprayed, and there was some bondo visible on the back side of the light that this would not be covered. At this point, they are saying that both the wire, and the entire lighting assembly need to be replaced.
I feel that this is unreasonable because there is no evidence that any go this body work caused the light to fail, and furthermore, it concerns me that they will try to deny further work for these reasons.
So at this point, my 3 options are:
1.Try taking the car to another dealership
2. Open an appeal with BMW Warranty
3. Suck it up and pay the money out of pocket(not sure what the total for this repair will be)
What do you guys think?
I never assume anything when purchasing a used car especially if it had previous damage. Sorry for your trouble but I always get a car fax and detailed report on any damage that may have occurred on used cars I have purchased and have never had any issues. The BMW dealer is correct in not assuming responsibility for this issue.
      03-12-2018, 09:19 PM   #24
gtmax500
Drives: 2016 MW M235xi
2016 BMW M235xi  [0.00]
For what it's worth since it seems you pretty much got the info you need but, the problem you're experiencing is a know issue. I had the same problem with very similar error codes you had. BMW covered the repair under warranty which was a burnt up ground cable on one side causing a short. They claim the other side was going to short soon as well so they replaced both tail light wiring harnesses with a retrofit kit. No problems since. There's a forum thread around here somewhere where a bunch of us had the same problem.
I have a pretty serious upgraded sound system installed in my car with about 10 feet of 1/0 gauge wire running up to my amps and they still covered it so that was fortunate.
Viffermike1753.00
      03-13-2018, 10:47 AM   #25
USA-RET
USA-RET's Avatar
605
Drives: Estoril Blue M240i
If it were me, I'd take the info provided from others with a similar issue that were fixed under warranty to another BMW dealership and talk to the Svc mgr.
I'd elaborate that when this issue occurred you went online to see if others may have had a similar issue....blah blah blah. Give him the SIB # and see what shakes out. Who knows.
Since this issue was covered under warranty w/ others a different dealership may do the work (as warranty) and charge it to BMW w/o question. Worst case, they deny it also.
If denied, you can go the DIY route or find a good local mechanic to do the replacement.
      03-13-2018, 12:07 PM   #26
Rayscott
Drives: BMW 228ix
Too bad you are not close to Delaware. I use a garage that only services Eureopean vehicles and he is better than the dealership and cheaper. I may call him and ask for his advice on this if you don't mind.
      03-13-2018, 09:08 PM   #27
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
My 2003 E46 had a similar issue where the ground wire was not thick enough. Thanks to alert from forum members, I was able to beef up the ground wire and prevent a short. Interestingly enough, about 6-7 years later, I get a recall notice from BMWNA about this same issue with the ground wire problem. Go figure...
      03-14-2018, 10:54 AM   #28
IndyRed128i
IndyRed128i's Avatar
223
Drives: 2022 BMW 230I(Red)
Well good news, after a 3rd visit yesterday to the original dealership for a second look, a second service advisor(who I have worked with before) called a few hours later to inform me that the dealer would be covering the entire repair under warranty. Picked the car up this morning and everything seems fine. Per the repair ticket
Performed SIB 630517
-right bulb socket
-left bulb socket
-repair cable-tail lights
-cable connector
-shrinking hose
You guys were right, that original assembly was fine. Hope this post will help other who are having this same issue go in the right direction
Thanks again!!
Appreciate 4
overcoil3073.50
Viffermike1753.00
Poochie9104.50
      03-14-2018, 10:59 AM   #29
USA-RET
USA-RET's Avatar
605
Glad it worked out for you.
      03-14-2018, 11:16 AM   #30
BEM-S4
BEM-S4's Avatar
Nice, congrats on the good result. FWIW I have found that A LOT of what's covered and what's not is very much a grey area and the service folks can help you out if they want. Helps to build and maintain good relationships. I once had a rear diff and transfer case go and they offered to replace for free even though my warranty had ended 7K miles ago. It was covered by CPO but they couldn't tell that at the time since the computer system was down. That was a $8K job they would do for good will.
Unsolicited advice - leave a case of beer or something in the trunk of the loaner when you return it as a thank you to the SA.
      03-14-2018, 12:21 PM   #31
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Wow, they were going to charge over $800 unnecessarily for something that could be repaired for under 50 bucks. We don't call them "stealership" for nothing.. #InformationIsPower
      03-14-2018, 03:13 PM   #32
Elvisfan
Drives: 2018 430ix convertible MGM
So I guess dealers should now be providing free labor? Good luck on that one.
      03-14-2018, 03:32 PM   #33
BEM-S4
BEM-S4's Avatar
To be perfectly fair to all involved, a lot of car stuff you really have to get into it before getting a true cost. So an honest mechanic could tell you $100 and it turns out to be $1000, or he could tell you $1000 then after doing some exploratory surgery turns out to be a $100 fix.
      03-14-2018, 10:42 PM   #34
Elvisfan
No, I expect them ass-rape every uninformed customer that walk through their door, instead of doing the right thing and diagnose the problem and charging accordingly.
It’s a shame there appear to be no moderators on this forum.
      03-16-2018, 05:06 PM   #35
IndyRed128i
223
What he said is a true statement though(usually). Sometimes, you have to keep it real.
Poochie9104.50
      03-16-2018, 11:09 PM   #36
Elvisfan
It’s too bad that you can’t just say that a dealer is trying to screw you any more. People have to use real profanity these days. It’s not true anyway. Actually,how many dealers have you been to? That’s a real generalization.
      03-16-2018, 11:48 PM   #37
CalRick
Drives: '15 M235 & '95 M3 tracktoy ;
2016 X3 Xdrive28d  [0.00]
2015 BMW M235i  [0.00]
1995 BMW M3  [0.00]
Originally Posted by ballinisahabit View Post
I highly doubt the body work had anything to do with it, and sounds like an excuse to deny a warranty claim. I would suggest you go to the dealership and ask to speak to the GM and mention the SIB code above or try a different dealer.
They do get paid less by BMW for a warranty claim than if they can find a way to charge you, so some will take advantage. I had my Z4 if for correcting a noisy cooling fan on warranty (or was it the electric water pump - it's been a while and a couple cars ago) and they called back telling me that before they could remove the shrouds to access the area, that with the previous crash damage it would be on my ticket to cover the repairs rather than on warranty. I told them that if there is crash damage, then it happened under their care before they delivered the car, and did not disclose it upon sale. Funny that they had no problem covering it under warranty.
      03-17-2018, 05:23 AM   #38
Poochie
Poochie's Avatar
Drives: 2016 M2
It's too bad that you can't just say that a dealer is trying to screw you any more. People have to use real profanity these days. It's not true anyway. Actually,how many dealers have you been to? That's a real generalization.
Profanity? Are we on Sesame Street? I know you're trying desperately to get into Heaven (good luck on that one ) ) and what I typed on a keyboard hurt your virgin eyes but I was making a point with sarcasm, like adults do.. You must me 5 years old, so it went over your head.. And also, if you have !NOTHING! constructive to add but criticism and conjecture, take the thumb out of your ass and get off the forum!! It's a shame there appear to be no moderators on this forum to kick the useless people off! #WasteOfBandwidth
      03-17-2018, 10:09 AM   #39
Elvisfan
I guess my point was made. You are a real class act.
      03-18-2018, 03:42 PM   #40
IndyRed128i
223
Pretty sure we’re all adults here..
      03-18-2018, 04:53 PM   #41
kz1000
Mensch
kz1000's Avatar
60
Drives: 2021 230i 6mt
      03-18-2018, 05:00 PM   #42
Elvisfan
I don’t recall being asked. I may be wrong.
      03-21-2018, 05:01 PM   #43
IndyRed128i
223
Looks like someone needs to take a timeout
      03-22-2018, 08:35 PM   #44
IndyRed128i
223
Originally Posted by kz1000 View Post
Lmao
