08-02-2016, 12:43 PM | #24 | ||
Rep 1,084
https://www.ecstuning.com/b-genuine-...r/11122334344/ Here's the realoem.com info about the part number: http://www.realoem.com/bmw/enUS/part...&q=11122334344 The difference is a big hole cut in the front of the airbox.
08-02-2016, 12:47 PM | #25 |
Rep 26
I often hear a whistling sound upon acceleration.. All my prior cars were NA so I just assumed this sound was the turbo spooling up, but I'm no Mr. Goodwrench. My intake and such are stock.
08-02-2016, 01:19 PM | #26 |
Rep 237
Right from BMW. They'll have it next day typically. There were 3 left in the country when I ordered it.
08-02-2016, 01:28 PM | #27 | |
Rep 5,369
08-02-2016, 01:59 PM | #28 |
1006
Rep 1,653
I have our Sport Cat and Muffler Bypass installed on my car and from the outside you could hear some turbo spool. This past weekend I installed my intake and that really opened up the sound!
08-02-2016, 03:47 PM | #29 | |
Rep 227
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
08-02-2016, 04:04 PM | #30 | ||
Rep 237
08-02-2016, 09:00 PM | #32 |
Rep 1,084
it definitely makes a noticeable sound difference
08-03-2016, 01:46 AM | #33 |
Rep 509
Drives: 2016 M235i RWD 6MT
hm.. I've been mostly driving in eco pro, occasionally jumping to sport+ in the lights. Wow.. the difference & I think I can hear the turbo... but then again I'm not paying much attention to that when my face is smiling from ear to ear.
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
08-03-2016, 01:05 PM | #36 |
Rep 237
My first true engine product install EVER(give me some credit). I had no idea where to begin and just went at it. I removed the drop in filter out first. I pulled off from the center rubber adapter and it come right up and then pull up on the airbox itself and it came up. At this time I had enough room to pull the airbox right out. Then went backwards and its in. NO CEL!!!!!!!
There's a slight difference in comfort mode and sport mode with sounds of forced induction, but not comparable To other "true" CAI intakes I've heard. The problem really is the wind noise with windows rolled down and the stock exhaust noise are still overpowering in most driving situations. When I found an opportunity with less traffic noise and wind noise the drop in filter plus mppk box really prevailed. The diverted valve is more prominent of an increase in sound vs the spooling up of the turbo with this box. I was hoping for more spooling. With windows rolled up and radio on, there is no difference. You can not hear the difference in car. FYI I asked BMW how much to install and they said .5 hours for 75$. Happy I saved my money! Hope this helps! |
10-17-2017, 09:42 PM | #40 |
Rep 1,804
To answer the OP's original question - when the car was completely stock I could hardly ever hear the turbo whistle. I did the MPPK airbox and now I can hear the turbo if the music is low and a really get on it. It's pretty subtle, but that's fine with me.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
10-18-2017, 10:02 AM | #41 |
Rep 2,214
Installed a BMS intake and you can hear all sorts of spooling noises, along with some chirps and whooshes from the DV. I’d do it just for the sound alone, was totally worth it.
10-18-2017, 10:45 AM | #42 |
Rep 556
I've got one and also have the MPE. Even with the top down I haven't noticed any difference over the stock air box, the only thing I hear is the exhaust, no turbo spool or intake noises. If it's there it's covered up by the exhaust sounds.
10-18-2017, 11:27 AM | #43 | |
Rep 2,214
I can hear turbo spool from the inside of the car, windows up. With windows down I rarely have the music on because the sound is so intoxicating. I'm sure it helps having a catless DP, etc..
10-18-2017, 11:38 AM | #44 |
Rep 980
The tune makes a huge difference. With tweaked boost settings I can hear the merry whistle of the turbo at almost any level of throttle input that is the slightest bit insistent.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
