02-23-2015, 11:02 PM | #67 | |
Rep 2,942
To point 2: Correct, in that a GPS speed reading is technically an actual and predictive average with a fairly long refresh rate and window of spatial error, while a speedo reading is a real-time electromechanical measurement with refresh rates in milliseconds (same for lasers, when conditions are ideal). However, GPS technology doesn't have padding built in for those who don't appreciate (and heed) accuracy, and does automatically account for things that an electromechanical speedo can't (wheel/tire size, for one) because of how it measures. Taken together, those factors make GPS more accurate for steady speed readings, when the GPS is accurate from 10 feet and under (I did read that somewhere). |
02-24-2015, 01:16 AM | #68 |
Rep 869
Can't be as bad as the amg speedo on the a45... The proportion is ridiculous BUT they have digital speedo as well...
02-24-2015, 11:42 AM | #70 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
I, too am biased by coming from an RX-8, so my brain may be "retrained" to a degree.
In my view, current speedometers, with their compressed displays and non-standardized orientations, are much more difficult to read than digital speedos. This is especially true when going from one car to another since 45 MPH is not going to be the same orientation in most cases. I find myself looking more than once to establish my speed when I use our Honda minivan, Mazda3 or a rental car. For my tach, temp gauge or pool pump's pressure gauge, the analog dial is much easier to process as I am in range or out of range; there are not multiple close points I'm trying to distinguish. The functional range of the 2er's speedo is only 90 degrees of the 260 or so it covers (15-75 MPH), so the difference between 25 and 35 is only a few degrees. I'm contemplating adding an OBDII sourced display in the pod to augment the meager gauges. The display would be electronic, but the format would be analog for temp and digital for speed.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
02-24-2015, 12:37 PM | #71 | |
Rep 721
Thats mine showing the coolant temperature |
02-24-2015, 12:39 PM | #72 |
Rep 242
02-24-2015, 02:30 PM | #73 | |
Rep 193
02-24-2015, 06:35 PM | #74 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
That's an option I'm considering, but I'm going to wait until I get the car to see what sight lines are like.
02-24-2015, 10:28 PM | #75 |
Rep 109
I agree with the folks that think BMW should have added a digital speedo some where in the cluster, for me it easier to read quickly. I will miss mine on my current GTI.
02-24-2015, 11:33 PM | #76 |
Rep 917
Drives: 2015 BMW M Sports Convertible
Buy heads up display if you are such a driver who cannot do without or don't buy BMW.
2015 220i M Sport convertible.
2016 225xe M Sport. |
02-24-2015, 11:41 PM | #77 |
Rep 835
I really don't see the problem with the gauges. I do like the contrast of the needle in the audi gauges, but having driven a BMW the past 5 years I feel very comfortable with the orange cluster. I like that at 90 degrees you are at 80 mph instead of having a more condensed gauge (Audi). If you care enough you should be able to code the digital speedo which should solve the problem. If that is not enough for you then make an appointment to see an eye doctor. The orange is classic BMW, but you could always get an M and have white gauges.
2020 X3M Comp., Alpine White on Black/Beige
RETIRED: 2018 440xi GC, Carbon Black on Black/Blue 2014 M235i Black on Black, DINAN Stage 2 |
02-25-2015, 12:01 AM | #78 | |
Rep 5,262
03-10-2015, 01:25 PM | #79 |
Rep 438
03-10-2015, 01:55 PM | #80 |
Rep 533
