BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      05-06-2010, 10:02 AM   #1
///M1
///M1's Avatar
Drives: Many
Are any of these 'tuner' fault codes?
A BT scan done recently revealed a few 'hidden' faults. Any of these relate to a tune? Mostly the first two, the others seem unrelated.
Dynamic stability control DXC8 Plus - E90
Module Identification
5DA3:
Yaw rate sensor: DRS sends signal DrsPSIP2=INITstatus error (DRS-Typ MM 3.x).
Error will cause a warning light
Error is not currently present
Test conditions have been completed
5D93:
Valve relay: Medium or high-resistance short circuit of voltage supply FR or valve after ground registered through start-up test.
Instrument cluster PL2 E8x and E9x
A559:
Clamp 30g_f cutoff
Error will not cause a warning light
Airbags
93FB:
SBR - function - Velocity signal missing
Car Access System 3
A0B5:
Signal identification peed error
Error is currently present
Short circuit or signal interruption
Timeout
2A1A:
2A1A Tank ventilation system, function
Freeze Frame Information
Event 1Odometer 10920kms 6785miles
Engine temperature 99.00 °C
air mass calculated 103.09 mg/stk
Engine speed 640.00 rpm
corrected nominal value flow tank ventilation 0.03 kg/h
Event 2Odometer 11096kms 6894miles
Engine temperature 98.25 °C
air mass calculated 92.24 mg/stk
Event 3Odometer 11112kms 6904miles
Engine temperature 99.75 °C
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      05-06-2010, 10:16 AM   #2
onefastman
Drives: 2009 135i 2011 e92m dct
Dont think so, I understand that tuner codes are stored only in the engine faults. Be sure and check for gas pedal plausibility faults though becuase if you have one of those and your clutch goes out they wont warranty it, even if the fault was a year prior.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      05-06-2010, 10:23 AM   #3
///M1
///M1's Avatar
Drives: Many
Thx, good to know. Will be scanning the car 'prophylacticly' every few months from now on. None of these caused a CEL, in fact, I have never had a fault code since owning the car, knock on wood.
      05-06-2010, 02:51 PM   #4
HPFREAK
Drives: C6 ZO6
Did you have the Traction control turned totally off and put it on a dyno or anything?
      05-06-2010, 02:55 PM   #5
///M1
///M1's Avatar
Drives: Many
Yup, I have, several times in fact. Thx Brad.
1addicts
