03-02-2016, 06:21 PM | #23 |
Rep 569
M Performance Diffuser fitment?
I recently emailed Awe Tuning asking if they had a version for drivers with the M Performance rear diffuser. Mike Romano advised that adapters are needed as the tips do not adjust enough to extend past the M performance diffuser.
Has anyone installed the Awe Tuning exhaust with the M Performance diffuser? Tips work OK or did you need adapters? (If you needed adapters, what did you use?) Anyone from Awe - can you confirm since I have conflicting info here. (Mike recommended I check the various forums... well, there we go. ) |
03-03-2016, 11:23 AM | #24 | |
The Schwab
473
Rep 1,605
Drives: 2020 AW M340xi
I plan to get a few measurements this afternoon so I will let you know! |
03-06-2016, 12:52 AM | #25 | |
Rep 569
Yeah, Mike R just got in touch with me advising y'all were looking to develop some adapters, which is great news! Thanks! |
03-07-2016, 10:17 AM | #26 |
Rep 809
03-07-2016, 10:19 AM | #27 | |
Rep 809
So I already got my answer, it won't fit without adapters , thanks for the info! |
03-07-2016, 12:18 PM | #28 |
559
Rep 1,340
03-07-2016, 01:54 PM | #29 |
Rep 809
03-07-2016, 04:00 PM | #30 |
Rep 310
I have the AWE with the M Performance diffuser. the tips set at the furthest point are basically flush with the diffuser. Doesn't look bad at all but would be perfect if out by half and inch to an inch. Please excuse the dirty car. Just got some rain.
03-07-2016, 11:29 PM | #31 |
Rep 569
Looks OK!
Glad they're at least flush - great pic of the set up. (Ummm... we'll let the dirt sliiiiide this time. ) Was concerned they might sit too far back & then risk damage to the diffuser. But I'm with ya - would rather see them stick out more. Sounds like Awe is going to look into producing adapters - got my fingers crossed. But, guess a good tuner shop could fabricate a couple if we had to go that route; or maybe the M Performance adapters could work.
03-08-2016, 09:40 AM | #32 | |
The Schwab
473
Rep 1,605
A) M Performance adapters do not work, I already tried. They are 3" adapters, whereas the AWE is 2 1/4" piping. B) For some reason my adapters did not sit flush with the M Performance diffuser at all, and were quite sunken in. C) I created a thread a day ago with a good interim solution to this while waiting for AWE. Check here: http://www.2addicts.com/forums/showthread.php?t=1234403 |
03-10-2016, 09:11 PM | #33 | |
Rep 569
05-13-2016, 11:30 AM | #34 |
559
Rep 1,340
I've been receiving PMs asking what the AWE Tuning Touring Edition Exhaust + Performance Mid Pipe sounds like when paired to a catted downpipe. Well, here is a customer video with the aforementioned combination!
Questions? Hit me! |
06-28-2016, 10:47 AM | #36 |
559
Rep 1,340
07-07-2016, 09:40 AM | #37 |
559
Rep 1,340
A bit of Sport+ chatter with the AWE Tuning Performance Mid Pipe and Touring Edition Exhaust (edit: paired to a catless DP):
07-07-2016, 11:14 AM | #38 | |
Rep 809
Is that exhaust connected to catless dp? |
07-07-2016, 11:19 AM | #39 |
Rep 809
Thanks for the reply, I'm actually considering this exhaust to replace my M Performance one but without the midpipe and for sure without changing my catted dp with catless... I really don't like how it sounds, excessive annoying pops for my taste.
07-07-2016, 11:22 AM | #40 | ||
559
Rep 1,340
Yes, sir. System is paired to an aftermarket catless DP. Quote:
It sounds good with the axleback alone, and increases the volume with the mid pipe pretty significantly. With the mid pipe added it essentially makes the system a "track" variant apposed to a "touring." Let me know when you're ready and I'll see what dealers have it in stock and also let me know if you'd like an install done, too |
07-07-2016, 11:24 AM | #41 | |
Rep 809
Cheers, thanks Josh, I'll let you know. |
07-10-2016, 02:46 PM | #43 | |
Rep 1,753
