03-04-2015, 08:10 AM | #178 |
Rep 809
Hey ROBNYC , not yet bro, I was on a business trip last week... but, on Saturday I went to the exhaust shop to install my ER catted downpipe... that little tube combined with the RaceChip made my car a beast , now I'm actually having traction problems when I step on the gas to the floor, the car loose traction so easy man.... I hope it gets better traction when my new tires (I upgraded to 19' wheels and tires) past over 600kms of driving. I'll keep you guys posted
03-04-2015, 11:00 AM | #179 | |
IG @bmwF9xG80
3813
Rep 7,593
Dinan vs Racechip on the same X3 28i (N20) http://f30.bimmerpost.com/forums/sho....php?t=1098282 Hahaha congrats Alex, I am getting Intercooler & Chargepipe before Catted DP and then Intake but have to find out and see which one for N20 will fit the X3 too most makers have 0 for my X, and I can't look into the X5 because its all 35i/50i lol. Would love to see some before and after videos man start uploading on youtube =) rustyminded you see RaceChip w/ SupportingMods + PerformanceMods is going to be fun to see how it matches JB4 =P (No cheating on E85 wires though)
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
03-04-2015, 11:56 AM | #180 | |
Rep 809
The Wagner Performance Intercooler was the second thing I installed after the MPE and before doing any more performance mods btw, you should upgrade your IC too Now about the intake, I would suggest to test a drop in filter either from K&N or BMC before thinking on a $500 investment |
03-04-2015, 08:53 PM | #181 | ||
IG @bmwF9xG80
3813
Rep 7,593
03-08-2015, 04:43 AM | #182 |
Rep 1,040
Just ordered my RaceChips Ultimate controller today. Service with the car went well yesterday and worked enough overtime this weekend to pay for new add-on. Will post my reactions and comments next weekend after it arrives and installed; else I will do like the Dinan Stage 1 and return it back for a refund.
03-08-2015, 08:20 PM | #183 | |
Rep 193
I haven't installed mine as yet... |
03-10-2015, 06:27 PM | #184 |
Rep 1,040
Just finished installing the RaceChips Ultimate on my M235i tonight. The harness kit is excellent and even easier to install than any others I have used (BMS, aFe, Dinan). The plugs are basically the same as the BMS and aFe, but the big difference is you don't have to worry about which plug goes to which MAP sensor in the car! I was confused by this in the instructions not indicating which plug to use on the appropriate MAP sensor so I gave them a phone call (immediate answer). As explained by RaceChips USA over the phone, you don't need to worry about which plug to use, the ECU piggyback box sorts the signals out automatically for you. Now that is really idiot proof for sure.
After I completed the installation I left the reset plug into the end of cable and gave the car a quick start to check for engine codes or issues; wasn't 100% sold that you can plug the cable into either MAP sensor. No codes, and no errors, so I unplug and removed the reset plug and plugged the RaceChips Ultimate computer in. Started up the car and took it for my usually 1 1/2 mile loop test around the neighborhood. Now I have tried 3 other piggyback units on my M235i and each one of them deliver more noticeable power with the aFe being the best of the 3. No bullshit! The RaceChip Ultimate is by far the most torque I have experienced yet. I know you have read from others that "It's the Bomb" and "It breaks traction just after throttle tip in", but I can tell you that they are right on the money. With car in Sport mode I was spinning the right rear wheel through the first 3 gear shifts. It was wet outside, but I never felt torque like this before in the car! Will take the car out again on a dry day this coming weekend and see how my impression fairs. As of now, it is by far the best piggyback I have tried. Makes me wonder if I change the settings even higher what it would feel like, scary. If I wasn't getting rid of the car next year I would consider adding the limited slip differential just to keep the traction even instead of the one wheel spins I'm getting right now in the rain. |
03-10-2015, 06:31 PM | #185 | |
Rep 536
Update to one higher setting and watch what happens !! It will blow your mind how fast the car becomes
03-10-2015, 06:52 PM | #186 | |
Rep 809
I'm having problems with traction too, more torque and lighter wheels for me, bad combination maybe? Now, do you have Downpipe installed? If you don't put that and you'll be more amazed than you are right now, I can assure you that. I've gotten 402HP readings on my ScanGauge II since I installed the DP in combination with the RaceChip (at default settings) |
03-10-2015, 07:10 PM | #187 |
Rep 1,040
Thanks for the good words AlexGT and chaddy74. I will probably bump the settings from the current default setting of "B" to "D" over the weekend. Back to driving my motorcycle to work this week so I won't be behind the wheel until then. No downpipe installed, just the aFe intake and M Performance muffler. If the torque increases much more it maybe too much for the open differential to really enjoy it. Will post my results this weekend.
03-10-2015, 09:23 PM | #188 | |||||
IG @bmwF9xG80
3813
Rep 7,593
I agree the surge of Torque is unbelievable Quote:
You got obdlink or scangauge too ? Post some video guys of stepping on the Accelerator with RaceChip =D
03-10-2015, 10:51 PM | #189 |
Rep 193
Hi Delnari
This is an awesome review, the RC sounds like the ultimate... Lol If traction is an issue then that is a problem indeed... Need bigger tackies then but the m performance rim ones are crazy expensive... Plus the Std Mag rims are great looking as is I'm keen to hear how it is in the dry weather! |
03-10-2015, 10:58 PM | #190 |
Rep 193
From RC Germany head office below-reply to my query on the quoted performance figures on therei Eur website-
' The race chip is inserted between the ECU and fuel injection. Normally, the engine control unit sends the data directly to the injection system. With the Race chip data from the engine control unit are intercepted and optimized depending on driving conditions. In addition, the Race chip is active only when you need the power. To shut down and consequently motor sparing. With RaceChip we change the values of the vehicle, the injection, the injection quantity, injection time and the injection timing can be optimized. Also the boost pressure will increase to max 0,2 bar. This optimization results in an increase in output and a fuel economy. The values indicated on our website are calculated maximum values are reached. Not every vehicle reaches these values as it is also dependent on the tolerance of the vehicle series. Our chip is mainly active in the acceleration and pulling phase. The working range is approximately 1500-3500 r / min. The speed limit does not change normally. We supply the chip with a basic setting for your vehicle. With this starting point, you have a power increase of about 18-20%, this is the best compromise between fuel economy and more power. ' |
03-10-2015, 11:03 PM | #191 |
Rep 193
18 to 20 percent... Massive
I'm sure the tyres are in for some smoking... Can you imagine on Max settings...it'll be like the m4... If codes don't Appear on Max then I'll be amazed |
03-10-2015, 11:08 PM | #192 |
Rep 193
Hi guys. A quick question-
Have you found your performance exhaust to become much louder with the rc? and have the exhaust flap sounds become much louder on gear changes? |
03-11-2015, 01:52 AM | #193 |
Rep 69
I'm feeling like I want to give this a shot. Who was the member that was saying we could pm for a discount code or discounted price? Delnari's review sold me since he has tried every piggyback for this car.
03-11-2015, 07:49 AM | #194 |
Rep 1,040
ROBNYC can hook you up with a discount. I went directly through RaceChip so I could take advantage of the full warranty they offer when purchased directly. You can save $79 through the discount though. I read on the 3 Forum where a early user had trouble installing the cables correctly and RaceChip USA gave initial help, but after a while they referred them to a policy of buying direct gives extended warranty services.
03-11-2015, 07:52 AM | #195 |
Rep 1,040
The exhaust is as loud as it is with or without the upgrade. To be honest the M235i is a very quiet interior and if you disable Active Sound through coding you would not hear very much at all. This car is way different than my WRX were you could feel the upgraded exhaust given the cars lack of installation.
03-11-2015, 09:22 AM | #196 | |||
IG @bmwF9xG80
3813
Rep 7,593
Going to Dynojet end of the month will see if baseline to stock setting to other settings runs.
03-11-2015, 09:26 AM | #197 | |
Rep 809
So my advice is, stick with the OEM wheels if your doing Racechip and Downpipe upgrade |
03-11-2015, 10:23 AM | #198 |
Rep 57
I installed my RC about two weeks ago so here is my short review:
Installation was straight forward ( honestly the hardest part was to unlock the sensors) I let the car sit for 20 min prior to disconnecting anything. i put the unit on the top right under the black plastic cover - it sits great and not moving. first start- no CEL or issues. first drive- took around the block on the way to the highway- did not notice a big change but there is a million stop signs in my block . Noise- can def hear the whistle/air suction more ( i have an aFE as well) on the highway -first drive on the highway - nice difference in acceleration biggest change that actually got me by surprise was when i floored it at around 40MPH and the car jumped forward ! 200 miles on it now- No issues at all. very happy with it i send a email to paul from RC regrading upping the map after i found a gas station that sells race gas so now i can mix to get higher octane. He is super responsive and customer service is great. he is looking into what mix i should do and what map to use to maximize the chip . Right now i am using 91 octane and AFE intake. i am waiting fir dinan to finally release their S2 Power kit and see whats that all about , although it will prob be around the 5-6K |
