2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Engine / Drivetrain / Exhaust / Bolt-ons Wavetrac Complete Final Drive for your M235i & M240i
      09-06-2016, 11:11 AM   #45
HP Autosport
Supreme Allied Commander
Drives: F80 M3
bump
      09-06-2016, 11:17 AM   #46
jpnh
jpnh's Avatar
1425
Drives: NA
This is definately at the top of the list of upgrades for me.
Estimates on cost of installation?
Generally speaking it looks like about 2-3 hrs of work
      09-06-2016, 12:11 PM   #47
HP Autosport
Drives: F80 M3
3 hours at the most for the complete final drive install. Call your local shop to get a quote to confirm.
      09-09-2016, 12:28 PM   #48
HP Autosport
Drives: F80 M3
bump
      09-11-2016, 08:41 PM   #49
HP Autosport
Drives: F80 M3
bump
      09-12-2016, 04:23 PM   #50
HP Autosport
Drives: F80 M3
bump
      09-13-2016, 05:42 PM   #51
HP Autosport
Drives: F80 M3
bump
      09-14-2016, 03:47 PM   #52
HP Autosport
Drives: F80 M3
bump
      09-15-2016, 06:22 PM   #53
HP Autosport
Drives: F80 M3
bump
      09-20-2016, 04:07 PM   #54
HP Autosport
Drives: F80 M3
bump
      09-22-2016, 03:33 PM   #55
HP Autosport
Drives: F80 M3
bump
      09-26-2016, 10:34 AM   #56
HP Autosport
Drives: F80 M3
bump
      09-29-2016, 12:14 PM   #57
HP Autosport
Drives: F80 M3
bump
      10-04-2016, 10:43 AM   #58
HP Autosport
Drives: F80 M3
bump
      10-05-2016, 03:16 PM   #59
Beartato
Beartato's Avatar
882
Local shop quoted me 3.5 hours for install.
Just ordered one of these from you guys, I'm so excited.
      10-05-2016, 03:33 PM   #60
HP Autosport
Drives: F80 M3
That is not too bad. Make sure they have the proper gear oil.
Shipping today or tomorrow! Thank you!
      10-05-2016, 05:34 PM   #61
Beartato
Beartato's Avatar
882
It's just standard BMW differential oil right? The Wavetrac website says it will work fine with the recommended oil for the car.
http://www.wavetrac.net/technical.htm
What gear oil should I use? [-]
Your new Wavetrac® differential is incredibly durable and will withstand the harshest environments...as long as suitable oil is used. Many customers ask what oil we recommend for use with the Wavetrac® differential. We feel the best answer is:
Use the "factory fill."
In other words, use the gear oil spec that your car manufacturer recommends for your car. The Wavetrac® is compatible with virtually all factory-installed gear oils used today. If you are racing your vehicle, and wish to upgrade the gear oil to improve performance or durability in racing conditions, choose the oil carefully: be aware that some gear oils have additives that are not recommended for use with your Wavetrac®.
Some have friction modifiers designed for limited slip differentials. These modifiers generally increase slipperiness and are intended to reduce clutch disc chatter in conventional clutch-type LSDs. Some gear oils such as Red Line Oil's Shockproof® type have microscopic solid particles in immersion in order to "cushion" transmission components, acting as an extreme pressure agent. The Wavetrac® and all helical gear differentials in general, operate using friction. The friction generated between its internal gears and its housing are what allow this type of differential to function.
Gear oil additives that drastically reduce friction will actually reduce the performance of gear differentials. The internals of the diff get too slick to generate adequate friction - reducing the differential's effectiveness - reducing its ability to drive both wheels.
In conclusion, when using a Wavetrac®:
•Use factory spec oils for your car
•Use Motul Synthetic high performance oils if you wish to upgrade the oil. Please consult Autotech Driveline for recommendations.
•Avoid gear oils with limited slip additives.
•Do NOT use RedLine, Shockproof® or similar gear oils.
Performance Gear Oils we recommend:
Requirement Oil
75W90 Motul Gear 300 (100118 1l)
75W140 Motul Gear Competition (101161 1l)
Motul Gear Oil is available from Wavetrac dealers
Please note that you will void the Wavetrac® Limited Lifetime Warranty if incorrect gear oil is used.
Just checking. Looking forward to receiving it.
      10-05-2016, 05:43 PM   #62
HP Autosport
Drives: F80 M3
Yes, follow their recommendations. OEM oil is synthetic.
Beartato881.50
      10-05-2016, 08:25 PM   #63
jpnh
jpnh's Avatar
1425
Drives: NA
Forgive the question but for a 2 series whats the difference between this unit and a factory new unit I can purchase from a dealer for roundabout the same price?
      10-07-2016, 05:10 PM   #64
HP Autosport
Drives: F80 M3
bump
      10-10-2016, 01:19 PM   #65
HP Autosport
Drives: F80 M3
bump
      10-10-2016, 01:22 PM   #66
jpnh
jpnh's Avatar
1425
Drives: NA
So I guess my question is going to be ignored?
