01-05-2018, 05:29 PM | #1 |
Rep 832
Trunk Dimensions...help?
Hi folks,
We will be picking up our M240i on ED in a few months and will be spending almost three weeks touring parts of Europe. As such, we need to maximize how much luggage we bring. I am thinking of picking up some large travel duffel bags instead of our usual suitcases. In order to decide on the right bags, I am wondering if someone can measure their trunk for me. I have looked all over the place online and only see volume, not dimensions. I'd like to know opening dimensions, width at wheel wells, depth with the back seats up, and depth with them down as well as height between rear deck and floor when seats are down to figure out what height I can slide through. Thanks for your help!! |
01-06-2018, 04:33 AM | #2 |
Rep 20
Measurements are only a rough guide boot mouth width bottom 700mm max width near top 1030mm
width between wheel arches 950mm depth with seat up bottom 910mm top about 720mm (lied on my back in the boot approx.) depth seat down 1550mm height when seat down floor to deck 670mm Like I said above rough only best I could do. |
01-06-2018, 07:07 AM | #3 |
Rep 176
Remember the entire rear seat area isn't open with the seat down, there is only a pass through. With the seat down there is a substantial storage area but you don't want to leave things here and unattended. We travel lots with ours and there is lots of room for 2 med sized suitcases side by side so soft bags should be no problem. The most important thing is to learn to take only the essentials! You don't need your whole closet.
01-06-2018, 07:51 AM | #4 |
msej449
514
Rep 717
How about asking your dealer if you can drop in and try out one of their used M235i/M240i to see how your intended luggage fits?
Ours is a convertible and acquisition coincided with getting some much-needed new luggage. We didn't consciously try to get the new stuff to fit, but fortuitously, our 2x medium and 1x small hard cases are fine with room to spare. And that's with the storage area for the fabric top in use as well. But their dimensions are pretty optimal - a small change in dimensions and they wouldn't fit so neatly. If you prefer hard luggage the trial at a dealer would allow you to see if your existing stuff or a mix would work. As a guide, and coincidentally, the three hard cases held enough for an anniversary trip to Canada: 12 days Vancouver, Victoria, Rocky Mountaineer and a drive from Jasper via Lake Louise to Banff and then Calgary. And clothing to cater for +32°C on Vancouver Island to -4° and snow in the Rockies.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 01-06-2018 at 08:02 AM.. |
01-06-2018, 08:00 AM | #5 |
Rep 525
Luggage with wheels is inefficient, the structure takes up a lot of space. If you can do without, it will help. If you are staying in B&B you will not use the wheels much anyway. Fancy hotels have porters.
Another point, when you go somewhere, like a beach or a museum, don't put your valuables in the trunk and walk away. It's an invitation to thieves who may notice. They know where you are and where your valuables are. Instead, plan ahead and put your valuables in the trunk then drive there, not opening the trunk when you get there. This will take some practice but it is a good lifetime habit. |
01-06-2018, 09:03 AM | #6 |
Rep 121
I know you asked for dimensions, but here is a picture of my trunk from our 14 day European delivery. Two medium backpacks and one large rolling suitcase for two people. We did do a laundry stop on day 9 of the trip.
2016 M235i BSM, M/T, Sunroof Delete
01-06-2018, 10:17 AM | #7 | |
Rep 832
01-06-2018, 10:20 AM | #8 | |
Rep 832
Thx |
01-06-2018, 10:23 AM | #9 | |
Rep 832
Thanks for the input! |
01-06-2018, 10:24 AM | #10 | |
Rep 832
Thanks a ton! |
01-07-2018, 08:20 AM | #12 | |
Rep 176
The pass through itself represents about 1/3 of the full width along the seat back. I came from Audi were the opening in almost the A5's is the entire width so this looks restrictive to me. Somehow Audi has maintained rigidity without using this divider to accomplish it. Not being wider restricts pushing a suitcase all the through into the back seat area. Other than for something quite long it isn't very useful. That being said, the trunk is quite adequate. We place two sets of golf clubs in it, one through the pass through and one horizontally across the back. This allow space for soft bags on each side of the bag going through the opening and also in the back seat. As one poster has shown, 2 reasonable sized bags can fit side by side into the are with space left on either side near the trunk opening as it gets considerably wider at the back reaching almost full width of the car. When loading, it is much easier if you have the top up and the plastic roof guard in the up position. This greatly facilitates insertion and extraction of items. Its a very good suggestion to visit a dealership and examine one with tape measure in hand or bring in some suitcases. It is quite surprising what you can get in. Enjoy and don't sweat it. |
01-07-2018, 01:56 PM | #13 |
Rep 1,219
Drives: 2015 M235ix
It is apparently inconvenient for OP to get to a dealer, but that is the best solution and I have done it for ED myself. Measurements are fine but they don't tell you how your particular set of bags will fit.
And yes, duffels with no structure are always best for tight spaces. Also, it is not clear if OP has ordered a coupe or cabriolet. Huge difference between them in storage space. |
01-07-2018, 03:50 PM | #14 | |
Rep 2,067
The Coupe has a 13.8 cu-ft of space, the ragtop has 11.8 cu-ft with the top up and 9.9 cu-ft with the top down.
2019 X2
01-07-2018, 04:13 PM | #15 |
Rep 832
01-07-2018, 04:24 PM | #16 | |
Rep 832
Should have mentioned, it is a coupe. I've done the cab thing with my Z4M but was never allowed to track days with BMW clubs so decided to go coupe this time. |
01-07-2018, 07:13 PM | #17 |
Rep 121
There was a little. A 28" may fit. It will definitely fit lengthwise with the room to spare. I put it in that way to make it easier to remove it.
01-07-2018, 08:24 PM | #18 | |
Rep 832
I'm going to try and find a 28" with removable wheels, a 28" duffel beside it, and a larger duffel that will go across the back seat so I don't even have to put the seat down if I don't want to (but cover with a blanket). Cheers |
01-08-2018, 10:58 AM | #19 |
msej449
514
Rep 717
Can I also suggest that you bring along (or order for delivery) one of those small LED rechargeable torches that charge from a 12V car socket? BMW do one (part no 82 12 9 406 650) but there are plenty to chose from on Amazon. The 2 Series boot is not particularly well-lit and this could be useful for finding stuff when the luggage obscures the lights. And handy anyway.
Parking in many European locations requires a parking time card to be displayed in the window: it's just a disc with the hours on it and you turn the disc to show your approximate arrival time. I imagine ED will include this but worth asking. Some countries also require you carry a spare bulb set. For my M235i this was a hefty £80 ($109!) so again, worth checking if this comes with ED. If not, it would be a useful item to order for delivery with the car. Austria and Switzerland require you display a Vignette to use the main highways. Although you can get them at the borders, you might like to get them in advance, so that you've not got a problem if the border is unmanned or it's late at night etc. Both countries highway police are very hot on stopping people without them. Also be aware that the Swiss fine excessive speeding in proportion to your income - hence the Swiss record of the highest speeding ticket of close to $300,000 for a rich Ferrari owner (don't let this put you off, this guy was doing 85mph in an 35mph zone in a small village. Just be aware.). 2 Series like to be refilled with BMW windscreen washer concentrate and BMW strongly recommends against mixing BMW and non-BMW. This is another item that would be useful to have in the car when you pick it up.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 01-08-2018 at 11:09 AM.. |
01-08-2018, 11:20 AM | #20 |
Rep 55
On our 3 week 2016 M240i ED we easily fit 2 suitcases one size larger than carry-on as well as a backpack in the trunk with plenty of additional room. One of the suitcases went over half empty so we'd have room for items we wanted to buy.
Slightly off topic but our experience in 2 long (a 3 and a 5 week) ED's as well as the experience of anyone who travels a lot is that you do not need much luggage, and you will regret packing too much more than you will regret forgetting something and buying it there..... My wife was able to go 5 weeks with only a suitcase just 1 size larger than a carry-on. I went 5 weeks with a carry-on and backpack. If you apply discipline you will really appreciate being able to carry everything you bring in one trip.....There are many places to get laundry done and just as many stores to buy things as here! Rick Steves has a 'Europe Through the Backdoor' book with excellent tips for how to pack light. |
01-08-2018, 02:45 PM | #21 |
Rep 12
Looking to buy a 2 in the coming weeks / months and my wife's only concern is the trunk space (going from my hatchback now), so I hear you OP.
Totally agree with mecodoug via Rick Steves -- we did two weeks in Europe with only backpack-sized (very large backpacks, don't get me wrong) bags and were so much happier. Every time we saw tourists dragging wheels luggage down cobblestone streets we were appreciative of that advice. |
