05-19-2015, 10:23 AM | #1 |
Rep 513
This was just (a week ago - thx alz0rz) posted over on N54tech. Anyone try it yet?
The last thread for v3.2 was a success with user reviews. N55_FSERIES_EWG_3_3: 1) Changed map 1 to additive map that targets around 4psi over stock maximum, suitable for unmodified cars, lower grade fuels, etc. 2) Changed map 2 to additive map that targets around 6psi over stock maximum, equivalent to the previous map 2. Suitable for most modified cars on 93+ octane, PPK equipped cars, etc. |
05-19-2015, 10:27 AM | #2 |
What goes here?
453
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
3.3 was actually posted last week, I've been using it since then with Map 2. Not sure why he says that the target is '6 psi over stock, eqv to map 2', when the previous Map 2 was only 4 psi over stock. At any rate... yes, it feels that much stronger.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
05-19-2015, 10:33 AM | #3 | |
Rep 513
Have you run any logs on v3.3? Also it seems some on N54tech are getting drivetrain malfunctions. Any with you? |
05-19-2015, 10:52 AM | #4 |
Rep 4,521
IIRC Terry at BMS advised that v3.3 map 2 is the same as v3.2 map 1.
v3.3 map 1 toned down a tad to be more tolerate of fuel grades.......
Current '22 X3M LCI.. |
05-19-2015, 11:25 AM | #5 |
Rep 513
05-19-2015, 11:33 AM | #6 |
What goes here?
453
Rep 1,356
I've gotten no drivetrain errors. There is no way Map 2 on 3.3 is the same as Map 2 on 3.2.
2019 G30 M550i
05-19-2015, 11:34 AM | #7 | |
Rep 513
05-19-2015, 12:01 PM | #8 |
What goes here?
453
Rep 1,356
So what would be is the distinction be between Map 1 and 2 now?
2019 G30 M550i
05-19-2015, 12:05 PM | #9 | |
Rep 513
05-19-2015, 12:12 PM | #10 | |
What goes here?
453
Rep 1,356
So should 2) say '... equivalent to previous map 1.'?
2019 G30 M550i
05-19-2015, 12:24 PM | #11 | ||
Rep 513
Can't seem to get an answer on this. My 235 and a buddy with v3.2 on a 435 flaps only stay open for 10-15 seconds then close again. |
05-19-2015, 12:59 PM | #12 |
What goes here?
453
Rep 1,356
So I've never enabled/used the JB4 flap feature.. I just let the car do it's thing.. are you saying the JB4 is overriding stock behavior or that the feature is not working correctly?
2019 G30 M550i
05-19-2015, 01:00 PM | #13 | |
Rep 513
It's not functioning correctly in that with either option enabled, even when you force it open, it will still close after x amount of time. |
05-19-2015, 03:01 PM | #14 | ||
What goes here?
453
Rep 1,356
2019 G30 M550i
05-19-2015, 03:07 PM | #15 | |||
Rep 513
Hold down the voice command button. |
05-19-2015, 03:33 PM | #16 |
What goes here?
453
Rep 1,356
Hmm I am not getting any verifiable confirmation that something changed.. I just revved up to 2000 rpm and held it and tried holding down the voice button for seconds at a time
2019 G30 M550i
05-19-2015, 03:33 PM | #17 | |
Rep 513
05-19-2015, 03:48 PM | #18 |
What goes here?
453
Rep 1,356
Yep, I definitely can hear the valve opening or closing per normal operation in Sport mode but at idle now and in Comfort mode the Voice Command button does nothing for my car.. hmm.
2019 G30 M550i
05-19-2015, 04:45 PM | #19 |
Rep 21
I was actually just trying to figure this out myself...it will open and then close after 10-15 seconds as well.
05-19-2015, 06:07 PM | #20 |
Rep 2,368
On another note of those of you running this, getting malfunctions? I'll probably be updating later tonight.
Follow my builds:
05-19-2015, 06:07 PM | #21 | |
Rep 513
05-20-2015, 06:50 PM | #22 |
Rep 80
I bought a used JB4 used with what i think is the firmware 3.0. From what I read here i am not sur to update. It seems that there are a lot of trouble. What to you advice me ? For each firmware which cable should I use ? FF or EWG?
thank you |
