05-30-2023, 05:11 AM | #1 |
Rep 618
(LCI) M2C yellow DRL modules from ebay?
I’ve been looking around for yellow drl modules for my m2c and I found 2 options from reputable vendors (IND and Bayoptiks) and 2 more on ebay. IND and Bayoptiks seem to be listing their yellow drl modules at around $300-350 while ebay ranges from $120 (from China) to $200.
Are these all the same thing? Anyone have any experience with the ebay ones? Thanks
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
05-30-2023, 09:22 AM | #2 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
I just ordered mine from aliexpress... as well as the heatsink housing covers so I could just modify those without touching the OEM ones. Its about $215 all in. Even came with thermal glue.
Stylin.M2270.00 |
05-31-2023, 02:37 AM | #3 |
Rep 866
Drives: OG M2
+1 I also got mine from Aliexpress - they're all the same Chinese stuff. Some vendors are literally just doubling the price and reselling lol
Just get the IceDriver from Ali
OG M2 with the OEM M mirror retrofit
05-31-2023, 06:16 AM | #4 |
Rep 1,609
I think it all used to be ice driverz, the ones from ali express and then all the ones sold in US online shops. Ice Driverz are great, I got them from ali express and also got the modules like Wah, I think all in was $160 and have been good and can always go back to OEM if I get tired of them. Also Ice driverz is a great shop, I ordered the wrong ones (got OG ones) and they took care of me which I really appreciate.
However... now there are a bunch of others, can't comment on quality there. These have black boards from what I can see and now they are all over google groups (using other peoples pictures to sell their stuff) and on ali express. Personally I would buy the ice driverz from ali express because they are tried and true. |
05-31-2023, 08:27 AM | #5 |
Rep 35
Drives: LSB E46 M3, AW F87 M2, Model 3
Although mine is not LCI. I bought my drl in the US for $250. It took 4 days to arrive. Pm me if you would like to know the vendor name.
I have a white f87 m2 and a blue e46 m3
06-04-2023, 08:21 AM | #7 |
Rep 618
Any issues with the DRL modules overheating? I’m assuming installing these is like installing any component in a computer that has a cooling system (aka it needs thermal paste). Do the boards come with thermal paste or is any computer thermal paste good enough? (Arctic MX-5)
I watched a video of some guy who had the RGB drl modules from IceDriver on his OG M2 LCI and he said in the comments that you should disable the daytime running lamps function in iDrive. But wouldn’t that defeat the point of getting this mod in the first place? Any input is appreciated, thanks
06-04-2023, 11:58 AM | #8 |
Rep 3,806
It's always a roll of the dice going direct to AliExpress. They may all come from the same factory, but with difference quality requirements and components. China can make anything in the world, from the lowest quality possible to the highest level of components. If you have an issue, a reputable vendor will offer warranty support.
That's going to have a different value depending on the person. For me, I know I'm not getting junk if I order from IND, and that has value. |
06-04-2023, 02:09 PM | #9 | |
Rep 866
Drives: OG M2
If you get a single colored aftermarket chip (e.g. CSL yellow), then you simply replace the OEM chip and use OEM wiring. Simple plugnplay with zero issues and you DON'T disable the DRL in iDrive. Also, don't use thermal paste. You need to use thermal adhesive. Thermal paste won't secure the boards tight enough to the heatsinks to prevent them from moving. Any thermal adhesive should work - just make sure you use a similar amount to OEM and give it 24 hours to cure properly before installing the heatsinks back into the car. Good luck and lmk if you have any more questions!
turnsignalslol274.50 |
06-04-2023, 05:50 PM | #10 | |
Rep 618
Alright thanks for the info man
samsamdar584.50 |
